integral cube heater - Fiberglass RV
Old 01-05-2003, 04:56 PM   #1
After seeing Nevin Lescher's tasty mods, and his disc heater in particular, I decided to install a cube heater in the dinette bulkhead on my 16' Casita. This seemed the perfect space as it is oriented cor<img src=http://www.fiberglassrv.com/board/uploads/3e18c631c004dcube heater 1.jpg/> rectly and does not have any claearance issues- and I won't be tripping over it constantly either.
Old 01-05-2003, 05:04 PM   #2
trimout
The heater is wedged between the 2x2 sill and the top of the dinette seat with wood blocks and 1/4'' rubber. A bead of duct seal keeps the cold out and trims the cut also.<img src=http://www.fiberglassrv.com/board/uploads/3e18c7f53620fcube heater 2.jpg/>
Old 01-05-2003, 06:51 PM   #3
Mounted heater
Man, Phil, that looks like the perfect place for it. I'll be anxious to hear how it works.
Old 01-05-2003, 10:00 PM   #4
Hi
I like that.:ola
Old 01-05-2003, 10:04 PM   #5
I'll bet it's throwing a tiny bit of heat into the compartment behind it, helping prevent condensation and freezing. Nice idea and execution!
Pete and Rats
Old 01-06-2003, 05:42 AM   #6
bedding
It's a good daytime solution, but will not use at nite(this is getting OLD) or pull out the auxiliary cube. Now if I can come up with a good alternative for boondocking heat.............
Old 01-06-2003, 12:28 PM   #7
Check out those Dickensen (sp) vented marine heaters.
Pete and Rats
Old 01-07-2003, 06:20 AM   #8
rheostat??
As it stands I simply plug and unplug to use this heater, with controls on back set at high. I planned on hardwiring the power thru a rocker switch to free up the outlet space.....could I use a rheostat for house lights(rotary dial) to modulate heat or would this damage the unit??
Old 01-07-2003, 07:08 AM   #9
Great modification Phil!
Wish my fiberglass trailer model (Liberty Deluxe) had a similar oriented flat surface.
Hopefully Morgan or another electrical whiz will answer your rheostat question ...
But since you've cut the hole to fit ... if I were you, I'd pick up a spare heater, same make/model/size ... to ease the inevitable replacement of the current cube heater.
Neat idea
Old 01-07-2003, 12:07 PM   #10
I doubt that a lighting controller is beefy enuf to handle the heater; they are for 0.1-0.3 KW than 1.5KW. Prolly find a suitable controller in Grainer catalog.
Pete and Rats
Old 01-07-2003, 02:31 PM   #11
Orginally posted by phil moldovan
:o Phil,
Most of the heaters Iíve seen draw fresh air in from the back, heat it, and then blow out the front. My question is, does this heater take front air and blow back out to the front? ...Or is it taking cabinet air and blowing out to the front?
Old 01-07-2003, 04:00 PM   #12
reply to M Sanders
Michael- -
this unit pulls air out of the cabinet area from the rear. It is of moderate temp back there- not much cooler than the cabin space. If I need i can open a galley cabinet to equalize and perhaps increase the efficency of the heater.
Old 01-08-2003, 04:57 PM   #13
Heater compartment
Phil, ...Great innovation with that cube heater. We've all come to expect nothing
less from you. Keep them coming ..RayBee
Old 01-14-2003, 05:00 PM   #14
switch it
Switch with guards for the heater..........
I need 120V wiring advice. <img src=http://www.fiberglassrv.com/board/uploads/3e24a471931cdcube heater2.jpg/> My plan is to split the cord on the heater (wide spade neutral, narrow hot) and run them to the side terminals on the galley outlet (white neutral, black hot) with the switch of course in line on the hot run. Is this correct or am I going to fry my trusty camper?????? Do I need a ground to frame?? Any advice or suggestions from electricians welcome.
Vu Cube Chester Taje General Chat 20 08-19-2009 03:11 PM
Heater? Lisa M. Oregon Gatherings 6 06-23-2008 11:43 PM
Heater Kevin K Problem Solving | Owners Helping Owners 5 09-29-2007 03:31 PM
Heater Help Joe Mielke Problem Solving | Owners Helping Owners 11 06-13-2007 02:39 AM
Mr. Heater Buddy Portable Propane Heater Legacy Posts Problem Solving | Owners Helping Owners 16 08-03-2003 12:01 PM
