interior doors - Fiberglass RV
Old 08-20-2014, 01:51 PM   #1
Wallo's Avatar
Utah
interior doors
I am enlarging the door opening to one of the closets. Called Scamp to see if they could mfg. one to the new measurements. They no longer have the oak, only dark cherry. He could not provide any info as to who their supplier was, where they were located...nada. Would any one here have any clues where I could locate the MDF covered with the oak looking front? Thanks.
Alice
Wallo is offline   Reply With Quote
Old 08-20-2014, 01:57 PM   #2
Rick Mooyman's Avatar
Trailer: 1971 Boler 13' / 2013 Ford Escape
Manitoba
A pic would help. But if it is MDF then it probably has a oak veneer over it. Either real wood or plastic covering. I would take one of the doors to a cabinet maker and see what they can do for you. Or if it truly is MDF, could be a good time to get all the doors redone out of real wood.
Rick
Rick Mooyman is offline   Reply With Quote
Old 08-20-2014, 02:03 PM   #3
Post a wanted ad in the "parts" section. You may find someone changing out their stock MDF doors for custom. Anything oversize could be easily cut down.
Old 08-20-2014, 03:19 PM   #4
Saw your "wanted" post with the size of the door. May be hard to find, because I'm not sure any Scamps have doors that big. Have you already cut the opening? If not, you might consider having two separate doors (upper and lower) rather than one large door. My Scamp (also an '08 13' standard) has a horizontal stiffener across the inside front of the cabinet. You can see the bump if you look inside the cabinet and look down. Knowing that the cabinet is an important structural component, I'd hesitate to cut out the stiffener.
Something like this:
Closet Modification: Shelving and Lower Hatch Entry - 13' Scamp
Old 08-20-2014, 04:47 PM   #5
Wallo's Avatar
Utah
Rick
It is an original door on the scamp I want to replace. It is MDF with an oak veneer. I have the tools and the ability to create one myself if I could locate the material that would match the other cabinet/closet doors. I have priced new ones from cabinet makers and they are outrageous. I would only like to have to make one door and not change everything out. I would enjoy my time/money more camping, than working on the camper.
Alice
Old 08-20-2014, 05:00 PM   #6
Wallo's Avatar
Utah
Not narry a cut has been made yet. One large door would be more practical because there is already a small door above. The one door would cover both openings. The purpose for enlarging the area is to put shelving inside that cavernous space and make it useful. The width is only 12" wide and I need 15" to get the pre made storage unit inside. The area could also be brought up to just about the shelf above and almost to the floor below. I am going to glue stiffeners around the perimeter of the opening for strength and to allow longer screws to hold the door. The Scamp is a nice unit and great for traveling, but the space in that corner is totally useless with such a small opening. BTW, why does everyone think I'm describing the closet over the wheel well?
Alice
Old 08-20-2014, 06:32 PM   #7
Because the standard Scamps have the closet over the wheel well. You have a front bath, so the closet is just to the right as you enter the trailer.
Old 08-20-2014, 07:02 PM   #8
interior doors
Yup, my bad. I was picturing the big closet to the right of the door (the only closet in the no bath layout). I like your plan for the front closet. Afraid I don't have any ideas about sourcing a door panel that matches the stock cabinets in the size you indicated.
Old 08-22-2014, 06:54 AM   #9
Did you happen to see this ad? I wonder if the bathroom door might work for your enlarged closet? And Oregon is not too far from Utah…
16'/19' Scamp cabinet door and overhead cabinet
Old 08-23-2014, 08:06 PM   #10
Carl Pa's Avatar
They sell oak ply up to 3/4" thick at the box stores, just stain to match close. It is not like the doors are all close together, so a little shade diff will not be to noticeable. I plan to change all the doors on my scamp on order. I have thousands of $$$ invested in woodworking tools when LOML wanted a $2.00 spice rack years ago, who new. Carl
Carl Pa is offline   Reply With Quote
Old 08-24-2014, 02:17 AM   #11
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Alice if you should do as Carl said and buy 3/4 oak for a new door I would suggest getting enough stain so you can color all the new doors your going to make cuz the new one looks so good . Carl, I understand about the tools and bucks. I've got a couple $200.00 new and unused router bits for a project that got kixed......but I've still got 'em .
Old 08-24-2014, 07:02 AM   #12
Trailer: 2014 Escape 21
Virginia
For Scamp doors I use 1/2 oak plywood and stain it with Min-Wax golden oak stain and I use 3/4 oak for table tops. For the lighter Casita woodwork I use no stain. I coat with several coats of poly. Lately I have been using the water based poly. Dries quicker and less odor. Home Depot has 1/2" 4x8 sheets of oak for around $40 in my area. Lowes only carries 4X4 sheets for about the same price.
Eddie
Old 08-24-2014, 11:41 AM   #13
Wallo's Avatar
Utah
I did see the add for the doors. Oregon is pretty far from my part of UT. I was up that way this spring and it was a long 2 day trek. It would cost about $300 in gas alone. Shipping would probably be cost prohibitive also. If worse comes to worse, I'll cut a 1/2" plywood door and paint it white. At least it will blend in with the surround.
Alice
Old 08-24-2014, 11:51 AM   #14
Wallo's Avatar
Utah
Eddie/Dave/Carl...thanks for your input on wood & stain. I'll see what I can come up with. Not sure if I want to go for making new doors for the whole kit and kaboddle. If any other, it would be the ones over the sink and stove. Would be better to open one door and see inside all three cubbies at once rather than open one, not find what I want, close, open the next, etc. Seems more practical, just sayin'
Alice
Wanted: Wanting Uhaul doors and hardware for interior Higginra Parts: Buy | Sell | Trade 2 05-09-2013 12:26 PM
Trillium Interior Reno - O/head cabinet sliding doors peatle Modifications, Alterations and Updates 11 03-06-2013 11:23 PM
rehanging the cabinet doors Kelly G Modifications, Alterations and Updates 4 05-22-2009 11:14 PM
Used Trailer appliances & doors Dana T Problem Solving | Owners Helping Owners 3 05-18-2009 10:29 AM
boler overhead doors Rarebird Problem Solving | Owners Helping Owners 0 02-09-2009 07:46 AM
