Is It Possible to Add a Front Cabinet to Scamp 13? How? - Fiberglass RV
Old 11-11-2013, 08:04 PM   #1
CampyTime's Avatar
Trailer: Scamp 13' Standard
Hi Everybody,
I recently purchased a 13er with side cabinets over the dinette. I have the sofa/bunkbed in the front but would really like to install the overhead cabinet that Scamp sells for above. I am imagining a nightmare of taking off the "rat fur" and all of this kind of thing, but is it easier than I expect? Not even advisable? I see Scamp sells it, but maybe only to replace for those that have been damaged, yet already were in the trailer?
I would appreciate the insight of anybody with experience with this, as I'm a newb with lots of ideas, but no prior knowledge. Thank you very much!
Sincerely,
CampyTime (Wendy)
Old 11-11-2013, 08:30 PM   #2
honda03842's Avatar
Name: Norm and Ginny
The Marine carpet does not have to come off to install an overhead cabinets.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 11-11-2013, 09:02 PM   #3
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
Wendy Lee, you well have to cut out small pieces of carpet and glue in wood blocks. The cabinet will mount to the blocks. That wasn't so hard was it?
Old 11-11-2013, 09:17 PM   #4
honda03842's Avatar
I 've done it two ways. Supporting it off the top of the front window and side cabinet and using the more standard thru shell rivets.
In our Scamp we have shelves and cabinets off the rear Window and side windows as well as over the door.
See Modifications /Preparing a 1991 Scamp for some examples.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 11-11-2013, 10:00 PM   #5
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
This is what we have done, based on Norms work. We really like it. Bought it a Home Depot and trimmed it to fit using a cut off wheel on the wire. L-shaped aluminum is screwed to the window frame using the existing screws.
David B. is online now   Reply With Quote
Old 11-11-2013, 10:24 PM   #6
deryk's Avatar
New Jersey
well I would use epoxy the 2 part for fiberglassing. cut out the carpeting where you want the blocks to go, sand it down to the raw glass with a heavy grit sandpaper so its rough, clean it with acetone. Roughen up the back of the wood blocks and mix the epoxy per instructions and put them in place...will need something to put pressure on them to hold in place till it cures but once cured its now part of your fiberglass hull.
Its what I did on my boat when adding shelves to the fiberglass hull..read it in a trailer sailing book and it worked out well for me.
deryk
Old 11-12-2013, 01:06 AM   #7
Actually Scamp just installs them using rivets - three on the top front section (one in the centre and 2 off to either side of centre. Three on the bottom rear section - all though the outside shell. If done at the factory they actually often use the same rivet for holding the upper cabinet as they use to hold the front curtain rod holder - thus resulting in one less rivet through the hull.
The bin installs right over the rat fur. They will cut the hole opening on the front of the cabinet as big/long as you want it to be & sell you a custom door to match.
Lots of people add them after the fact so they do not need to have been in the trailer originally.
Old 11-12-2013, 08:49 AM   #8
Keep in mind that there are 13' Scamps and there are also 13' Scamps. Between several mold changes to the basic hull, as well as creep in the cabinet mold(s), a cabinet you buy new may not, as several have already learned, fit.
Check with the factory, as well as several peeps here, about what will and won't fit.
If it will fit, the factory rivet mounting technique has worked well for 1000's of Scamps. Just be sure that they are properly sealed.
Old 11-12-2013, 11:36 AM   #9
What Bob mentioned is correct regarding getting the overhead to fit really well into an older trailer. Scamp will probable ask about the age of the trailer and its size when you order - if they dont you should ask them.
I had another party pickup a front overhead bin at Scamp last year that I had hoped to use. Unfortunately Scamp precut the door hole in it and as they didnt know I had a 16 side bath Scamp (long story as to why they didnt know) the hole for the door was cut to large - basically if I put a door on it I would not have been able to open it fully as it would hit the front wall of the bathroom. It did appear other wise to fit my 16' 1992 Scamp fairly well though. Scamp hasnt changed the molds on the 16' over the years so if the trailer is in good shape and not experiencing any sagging etc (if your door isnt straight you may have a fiberglass wall sage issue happening) then it *should* fit.
I took that overhead bin to a number of rallys and a few folks tried it out on 13' trailers - both Scamps and Boilers. That was a different story. Scamp after the factory fire did change the molds on the 13's . On the older 13' Scamps it was tried out in the bins fit the rear area well but not the front area - lots of big gaps around where it should have been snug to the wall. Tried it on several older Bolers - a couple of them had the same issues as the older 13' Scamp - but two of the 13' Bolers which were also older it fit fine and at the end of the day my overhead bin found a home in one of those.
Old 11-12-2013, 12:09 PM   #10
My 1986 Scamp has rat fur over 2 layers of reflextic bubble insulation and Scamp just installed the fiberglass end cabinets on top of it all and pop riveted it in place just like the fiberglass side cabinets. Its been there 27 years on its origional rivets. I replaced a few rivets last month due to lost snap cap bases. so seems installed good enough.
Old 11-12-2013, 12:21 PM   #11
Trailer: '77 Scamp
I'm curious Steve, did you have Scamp custom install the double layers of insulation when you ordered it from Scamp??? How well has it worked in cold conditions?
Otters is offline   Reply With Quote
Old 11-12-2013, 02:15 PM   #12
Otters,
I didnít buy my Scamp new I bought it from a nice elderly couple last November. When I installed the Fantastic fan I found the 2 layers of reflextic insulation under the rat fur. I have nothing to compare on how well it works as my 13 has so many windows and the windows are cold. Without a front bath I have the front window, the stove window, door window and 3 windows in the back. Not counting the escape hatch and Fantastic Fan that are not insulated. At 30 degrees F those windows are cold. My trailer didnít come with a heater. I installed the heater and it runs about 10 to 15 minutes then off for about an hour and then runs about 10 to 15 minutes again in cycles to take the temperature back up maintaining 60 to 70 degrees inside. Most of the heaters run time is the fan starting up and hearer cooling down before shutting down and not much time with the actual burner on. I can tell you that their is a fair amount of insulative value as the inside is about 2 hours behind the outside temperature. If it warms up outside there is about a 2 hour lag before it affects the inside.
Old 11-12-2013, 03:21 PM   #13
Trailer: '77 Scamp
Otters,
I didn’t buy my Scamp new I bought it from a nice elderly couple last November.
Now that you mention that Steve, I do remember you buying it last year right after I bought mine. You lucked out getting that bonus insulation. I just experienced my first really cold camping trip in the Scamp last week. Brrrrrrr! Next time I go during cold weather I'm going to put some reflectix insulation in the windows and foam mats on the floor. I'm such a woos.
Old 11-12-2013, 04:12 PM   #14
Otters,
I dont know how people tolerate the floors in these things when they rip out the carpet and foam backed flooring and put in wood or vinyl. I still have the origional flooring. I knew when I bought mine no heater wasn't going to do so I installed the Atwood 2 heater and its been nice when its cold. I do not use a sleeping bag but sheets and a couple of light cotton blankets. Propane use has been good last trip my regulator switched bottles at the Lake Casitas rally for the first time. one bottle in 6 3-4 day trips is pretty good. Lake Casitas was the first time I camped and had 120 volt power. I have an electric cube heater but wont use it as I perfer the propane heater. The cube scares me.
add toilet to scamp 19 Rob in Vista Modifications, Alterations and Updates 9 01-11-2013 09:34 AM
removing scamp cabinet wjquigs Modifications, Alterations and Updates 4 10-10-2012 10:17 AM
Anybody add a step on a Scamp? iplumb Problem Solving | Owners Helping Owners 10 02-07-2012 07:48 AM
Scamp 13 - Add Shower? Steve R Plumbing | Systems and Fixtures 5 09-08-2007 11:00 PM
Scamp 13 - Add Shower? Steve R General Chat 0 12-31-1969 07:00 PM
» Virginia Campgrounds
