It Started as a Kitchen Reno- Project Boler - Page 23 - Fiberglass RV
Old 07-06-2015, 05:16 PM   #309
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Great job you did there, Ian.
Originally Posted by Ian G. View Post
Thank you all, I am not sure if this is an obsession or a passion.
Or a bit of both?
I find designing to complement the unique shape of the Boler very inspiring .... I love curves.
I am kinda fond of various kinds of curves myself.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 07-07-2015, 07:14 AM   #310
Johnny M's Avatar
Deep South
Nice job Ian, love the look of the tongue box, gives me some ideas for ours!
Old 07-13-2015, 06:38 PM   #311
Ian G.'s Avatar
Although I am sure this project will never be finished I am feeling right now that any changes from here on will be quite minor. Here are a couple pictures as I get ready to leave for the Prairie Egg Gathering
Old 07-13-2015, 07:30 PM   #312
Johnny M's Avatar
Deep South
Your Boler should be in a museum, it is a work of art!
Old 07-16-2015, 11:00 AM   #313
Luis's Avatar
Trailer: Boler 1300 79'
Great work Ian
Would love to meet sometime in YYC and share Boler passion/ obsession stories!
You have made your trailer your own and am sure there is a lot of pride and satisfaction that goes into that Ian, kudos.
Luis
Luis is offline   Reply With Quote
Old 07-23-2015, 10:53 AM   #314
Luis's Avatar
Do you have the old metal tongue box available for fellow boler enthusiast?
Pls let me know.
cheers,
L
Old 07-29-2015, 05:33 AM   #315
Ian G.'s Avatar
Luis
Pls let me know.
cheers,
L
Thanks Luis
Maybe you could make it to the Fall Omelette in Rosebud Alberta in September.
Sorry the aluminum tongue box sold in less than an hour when I mentioned it in a Facebook group.
I cannot tell you how much I love the ShadyBoy Awning, it is amazing. I will post some pictures.
Old 08-02-2015, 07:08 AM   #316
Ian G.'s Avatar
At the Alberta Bolerama (a.k.a. Prairie Egg Gathering) I used the Shady Boy Awning for the first time. It worked great. I mounted the awning so it centered over the side window and NOT the center of the trailer (previous pictures in this thread show the mounting location). This resulted in the door being covered by the front of the awning but a lot more usable awning space towards the rear of the Boler. The weekend weather put the awning through a good test, ranging from hot sun, to rain (downpours), and wind. The awning performed flawlessly.
Old 10-04-2015, 01:12 PM   #317
Ian G.'s Avatar
Wanted to provide an update on the Shady Boy awning ... in simple terms I LOVE IT!!!
I made a short video at this years Alberta Omelette event to show how easy and fast it is to set-up, i can do it in about 3 minutes.
Old 10-19-2015, 10:55 AM   #318
Trailer: Scamp 16'
Hi Ian, looks like you are attaching the support beams right on the door edge. What type of replacement door trim/seal are you using since the original door trim/seal needs to be inserted at the door edge. I am trying to add roof support to my Scamp to create more living space as I have taken out the closet. Thanks.
Scamping G is offline   Reply With Quote
Old 10-26-2015, 04:29 PM   #319
Ian G.'s Avatar
Hello George
Yes I placed supports epoxied directly to the fiberglass shell on each side of the door. I am using the following door seal from Vintage Trailer Supply, I have tried a lot of door seals and this one works great. When you first install it the door is almost impossible to close, force it closed and leave it for a few days, this compresses the seal and after that it works fantastic.
Airstream Door Gasket
Old 10-26-2015, 06:28 PM   #320
Trailer: Scamp 16'
Hello George
Thanks, Ian. I ordered the new Scamp door seal literally yesterday. I will try it out first. If that doesn't do a good job, I will try the one from Vintage trailer.
Old 11-27-2015, 10:13 AM   #321
TheWanderers's Avatar
Trailer: 1988 Bigfoot Fiver
Kentucky
Ian, love the Shady Boy look. Thanks for all your work and advice.
"Not all those who wander are lost." J.R.R. Tolkien
TheWanderers is online now   Reply With Quote
Old 12-19-2015, 04:02 PM   #322
Kentucky
Any special trick to installing the spigot?
The water system uses an external 5 gallon insulated cooler that I installed a quick connect fitting in place of the spigot. The braided steel line leads directly to the electric water pump. We have used this system for the past 2 years and it works great, easy to refill, in really hot weather we add a block of ice.
Ian, we've just pulled the moldy old fresh water tank from our Skank and need to replace it with something a little easier to maintain and I love you solution here. Did you have to do anything special to thread the spigot/valve into the water cooler?
boler, cabinets, custom, frame, renovation
76 Boler Reno/Rework kgingeri Modifications, Alterations and Updates 99 06-24-2013 09:21 PM
Boler reno help needed randyl Modifications, Alterations and Updates 18 05-19-2012 10:09 AM
Boler Reno Don A Modifications, Alterations and Updates 1 03-25-2011 09:40 AM
Started gutting the 74 boler....pics! thenoob Problem Solving | Owners Helping Owners 21 10-13-2010 09:30 AM
Finally started on the Boler American CliveAlive Modifications, Alterations and Updates 5 10-18-2006 11:18 AM
