Old 08-02-2012, 05:07 PM   #43
Trailer: 1980 Boler Deluxe
Amazing Job!
So how does the bed work? Trying to figure out from the hinges on the table legs how it folds down.... pics would be great.....
ccaffrey is offline   Reply With Quote
Old 08-02-2012, 09:47 PM   #44
Ian G.'s Avatar
Trailer: 1974 13' Boler and 2008 17' Casita Freedom Deluxe
The table legs were an interesting evolution. The bed itself sits on a ledge under the cushions. With the "U" shaped seating the table had to use a pedestal type base. I initially used a single pedestal used by many RVs but found it to be very unstable. Second attempt was to use two pedestals and although that made the table stable enough I found it very difficult to remove and lower the table by myself. The legs you see in the picture are designed as a bi-fold they are hinged at the top, middle and bottom. to fold the table you simply fold the back legs in half then the front legs. although connected in the lowered position they do not carry any weight. It has been working very good, easy to set-up and put down and also very stable. To lock the legs in the upright position I have installed spring latches opposite the hinges which essentially lock the legs in the centre.
Another unique feature with the table is that it slides back to allow access to the far bench, a screw knob under the table locks the slide to prevent movement when needed.
I will take some pictures over the weekend and post them.
Ian & Joan
1974 13' Boler
2008 Casita Freedom Deluxe 17'
Link: my Boler Build
Old 08-05-2012, 09:53 AM   #45
Ian G.'s Avatar
Hera are some detailed pictures of the table legs.
The table is 35" square, cushions removed for a better view of details.
Ian & Joan
1974 13' Boler
Old 08-05-2012, 10:05 AM   #46
Ian G.'s Avatar
A little more detail:
The hinge and leg lock system
Seated on the lowered position
Ian & Joan
1974 13' Boler
Old 08-05-2012, 10:52 AM   #47
Great design! Thanks for the detailed pics. Planning to start my overhaul this winter after the camping season.
Old 08-05-2012, 02:51 PM   #48
Sweet table setup. Ian, do you suppose it would work to NOT anchor the legs to the floor so the entire area under the dinette would be usable space for those that use it for storage? There are some that want it ALL. U-shaped dinette, ample storage and easily deployed table.
Just askin'
Double Yolk
1988 16' Scamp Deluxe
Old 08-05-2012, 03:23 PM   #49
Ian G.'s Avatar
Just askin'
To make it a free standing table where the legs are not connected to the floor the legs would have to lock at the top (similar to the way the single leg does in the original Boler design) or else everything would fold up and collapse. The other problem would be the table would jump everywhere while driving, you would have to tie it down.
Yes the design does sacrifice some storage but I have made use of the space by finding certain items which tuck into the spots.
What I love about this design is the table is so easy to set-up and take down. In a matter of seconds with out any straining, lifting or hard work.
Ian & Joan
1974 13' Boler
Old 08-05-2012, 03:39 PM   #50
Thanks Ian, that's what inquiring minds want to know!
Double Yolk
Old 08-05-2012, 03:58 PM   #51
dylanear's Avatar
Trailer: 2001 Scamp 13'
Very cool!!! Unique, well thought out and really well done!!
I'm amazed and inspired once again by the ingenuity, skills and dedication egg owners have!
dylanear is offline   Reply With Quote
Old 08-05-2012, 04:07 PM   #52
Ian G.'s Avatar
I have always been fristrated with the typical plastic roof vents, seems in our area it is an annual task to replace the plastic vent cover. I came across a 14"x14" all metal vent. Very well constructed and should last forever but I also wanted a fan in the roof vent and the metal vent was not available with a fan so I built my own.
The 2 fans are 140mm computer case fans, they have 2 speeds Very low current draw and a literally silent
The specs Antec TrueQuiet 140:
- Current draw - 0.04 amps on low and 0.1 amp on high.
- Decibels - 9.8 db on low and 20 db on high
- Airflow (CFM) - 40.5 on low and 65 on high
Compared to the Fantastic fan (3 speed):
- Current draw - 1.89, 2.29 and 3.0 amps on low, medium and high.
- Decibels - 39.0, 39.0 and 40.0 db on low, med and high
- Airflow (CFM) - 478, 653 and 920 on low med and high (no comparison on airflow but remember our trailers are only 360 cu/ft total volume without cabinets)
We will be testing them on a trip starting tomorrow, I understand the temperatures will be mid 30C.
Ian & Joan
1974 13' Boler
Old 08-05-2012, 04:53 PM   #53
dylanear's Avatar
Impressive power and noise specs, but I suspect much less air flow (which might not be a problem) given the size of those muffin fans and that they don't cover the whole vent area. Let us know how it works!
Old 08-05-2012, 05:59 PM   #54
Ian G.'s Avatar
For interior lighting I am using 12V LED lights designed for kitchen under counter from Rona. There are 4 bright puck lights (2 on each side mid-cabin) that provide very good general task and work lighting. We have used these at dusk right through to total darkness and they provide all the light that is needed to cook, play cards or read.
In between the bright lights are 2 low intesity lights (one on each side) still have to do the final wiring on these but with temporary wiring they provide enough light to get ready for bed or check the time at night.
Ian & Joan
1974 13' Boler
Old 08-05-2012, 07:24 PM   #55
Trailer: 1973 Love Bug '13
Ian, in the first picture there is what looks like a bracket or shelf under the window. Was that the original bracket from which to hang the table? The PO of our little Love Bug completely removed those at both ends and put in a stationary bed and a non converting dinette. I would like to make them convertible again but can't figure out how they were attached to the end walls.
Cat futrell is offline   Reply With Quote
Old 08-05-2012, 08:05 PM   #56
Ian G.'s Avatar
Yes that is the original table bracket. I left it in because I thought it would look better than patching it insulation. The original table is held by a piece of 3/4" plywood about 2" wide that is cut to follow the curved wall. It is fiberglassed into place. It is covered with a fiberglass trim with the table suppot molding screwed into it.
Ian & Joan
1974 13' Boler
boler, cabinets, custom, frame, renovation
Boler reno help needed randyl Modifications, Alterations and Updates 18 05-19-2012 10:09 AM
76 Boler Reno/Rework kgingeri Modifications, Alterations and Updates 88 08-23-2011 06:52 AM
Boler Reno Don A Modifications, Alterations and Updates 1 03-25-2011 09:40 AM
Started gutting the 74 boler....pics! thenoob Problem Solving -- Owners Helping Owners 21 10-13-2010 09:30 AM
Finally started on the Boler American CliveAlive Modifications, Alterations and Updates 5 10-18-2006 11:18 AM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
