It Started as a Kitchen Reno- Project Boler - Page 5 - Fiberglass RV
Old 03-03-2013, 12:46 PM   #81
Ian G.'s Avatar
Built the final cabinet for the toilet
I have been busy building the final cabinet which will hold the porta-potty.
The top is just set on in this picture, have to do some trimming and final adjusting against the wall and support beams.
Tip open the lower section to access the porta-potty, a PETT toilet
Toilet pulls out of the sleeve
The toilet sets up very quickly
also showing the drawer w/ ball bearing slide
Old 03-03-2013, 03:40 PM   #82
Steve Hammel's Avatar
Trailer: Trillium 4500
Nice! And Solid!
Old 03-03-2013, 08:19 PM   #83
D Davis's Avatar
Trailer: Casita, previously u-haul ct13
Virginia
Extraordinary! Wow!
D Davis is offline   Reply With Quote
Old 03-03-2013, 10:12 PM   #84
Luis's Avatar
Trailer: Boler 1300 79'
140mm fans
Hello Ian, Luis here.
Question for you, did you buy these fans around town? (YYC)
I need some serious CFM movers too!
Cheers,
L
Great rig BTW, loots of internal space, feels very light and open.
Originally Posted by Ian G. View Post
I have always been fristrated with the typical plastic roof vents, seems in our area it is an annual task to replace the plastic vent cover. I came across a 14"x14" all metal vent. Very well constructed and should last forever but I also wanted a fan in the roof vent and the metal vent was not available with a fan so I built my own.
The 2 fans are 140mm computer case fans, they have 2 speeds Very low current draw and a literally silent
The specs Antec TrueQuiet 140:
- Current draw - 0.04 amps on low and 0.1 amp on high.
- Decibels - 9.8 db on low and 20 db on high
- Airflow (CFM) - 40.5 on low and 65 on high
Compared to the Fantastic fan (3 speed):
- Current draw - 1.89, 2.29 and 3.0 amps on low, medium and high.
- Decibels - 39.0, 39.0 and 40.0 db on low, med and high
- Airflow (CFM) - 478, 653 and 920 on low med and high (no comparison on airflow but remember our trailers are only 360 cu/ft total volume without cabinets)
We will be testing them on a trip starting tomorrow, I understand the temperatures will be mid 30C.
Luis is offline   Reply With Quote
Old 03-04-2013, 06:41 AM   #85
Ian G.'s Avatar
Originally Posted by Steve Hammel View Post
Nice! And Solid!
Originally Posted by D Davis View Post
Extraordinary! Wow!
Thank you, appreciate the comments
Old 03-04-2013, 06:47 AM   #86
Ian G.'s Avatar
Cheers,
L
Thanks Luis
The fans are from Memory Express in Calgary, they move air quite well but their main advantage is they are silent with almost no power draw which we need because we usually dry camp. If you want to move a lot of air I would consider a Fan-Tastic Fan, or similar, they move a tremendous amount of air but they are noisy and draw more power.
Old 03-05-2013, 01:20 PM   #87
vics454's Avatar
Trailer: 1973 Boler
Ian, nice work. That table from rv surplus what city is that located in.
vics454 is offline   Reply With Quote
Old 03-05-2013, 02:00 PM   #88
Ian G.'s Avatar
Thank you
The table platform is from:
Factory RV Surplus
1611 W Bristol St
Elkhart, IN 46514
Old 03-05-2013, 04:49 PM   #89
vics454's Avatar
Trailer: 1973 Boler
Thanks Ian for that.
Old 03-05-2013, 09:21 PM   #90
Kenny Strong's Avatar
Trailer: 93 "Lil" Bigfoot 13.5'
Utah
Ian what are the plans for finishing the outside?
Later Kenny
Kenny Strong is offline   Reply With Quote
Old 03-06-2013, 06:43 AM   #91
Ian G.'s Avatar
Later Kenny
Hi Kenny
After complete repair and preperation of the fiberglass shell the plan is to match the original color scheme. White will be a pure white and the yellow will match the buttercup yellow of the interior. Still debating on paint, it will either be a 2 part polyurethane marine topcoat, or an automotive urethane finish.
Front and read windows will be replaced with UV stable Lexan with new rubber molding. I am keeping the original large side windows, I like the full ventaltion from these (although I do like the looks of the radius sliders but don't like the reduced ventilation). I have a second small radius window like the one I installed in the door to replace the kitchen side window.
Old 03-07-2013, 11:49 AM   #92
Utah
thanks Ian
Old 03-09-2013, 12:53 AM   #93
Nat
Trailer: 75 Boler
B.C.
I like your interior layout, its very open and fresh.
How is the new table stand holding up, does it have much flex in it when people lean on it or is it pretty ridgid and strong?
Nat is offline   Reply With Quote
Old 03-09-2013, 09:53 AM   #94
Ian G.'s Avatar
Thank you for you comments, it is amazing how open and big it feels on the inside.
The table is very stable with the new platform, Even considering its' size it is quite ridgid. Definitly not as stable as a kitchen or dining table at home but far better than any RV pedistal table or folding mechanism I have come across. The added bonus is that the table can be removed and moved outside if desired.
Old 07-01-2013, 12:38 PM   #95
Ian G.'s Avatar
Thought I would add a few new pictures of the work in progress as my Boler project is slowly taking shape.
Installed a new cabinet to the left of the door which contains the PETT porta-potty, installed sheet vinyl flooring, base board trim and stainless steel backsplash.
Old 07-01-2013, 12:52 PM   #96
Trailer: '77 Scamp
OMG, that looks amazing. Its hard to believe its a 13 footer with all that space. You've done a fabulous job. Its so bright and happy looking.
Otters is offline   Reply With Quote
Old 07-01-2013, 01:03 PM   #97
Trailer: 1996 16' Casita SD
Louisiana
Agreed X2! Nice and clean!
itlives is offline   Reply With Quote
Old 07-01-2013, 03:06 PM   #98
slavandheather's Avatar
Trailer: 1978 Boler
Wow, super nice work!
slavandheather is offline   Reply With Quote
Old 07-01-2013, 05:36 PM   #99
jen b's Avatar
Trailer: 1980 13 ft. burro
That right there is a work of art.
jen b is offline   Reply With Quote
Old 07-02-2013, 05:47 AM   #100
Ian G.'s Avatar
Thank you for your kind words.
It has been a lot of work but also very rewarding as the plan comes together. There is still lots of work to do, trim and minor details on the inside and the entire outside to do yet.
The priority right now is to go camping and enjoy
boler, cabinets, custom, frame, renovation
76 Boler Reno/Rework kgingeri Modifications, Alterations and Updates 102 11-23-2021 06:05 PM
Boler reno help needed randyl Modifications, Alterations and Updates 18 05-19-2012 10:09 AM
Boler Reno Don A Modifications, Alterations and Updates 1 03-25-2011 09:40 AM
Started gutting the 74 boler....pics! thenoob Problem Solving | Owners Helping Owners 21 10-13-2010 09:30 AM
Finally started on the Boler American CliveAlive Modifications, Alterations and Updates 5 10-18-2006 11:18 AM
