Jack-E-Up jack - Fiberglass RV
Old 11-18-2014, 05:14 PM   #1
Victor Benz's Avatar
Jack-E-Up jack
A few months ago I contacted Kent Madison of Jack-E-Up to order one of his jacks to replace my side-wind jack on my Fiber Stream. The problem was that when I modified the installation to put the spare tire above the frame, I realized that I had to remove the side-wind jack every time I needed the spare. A Jack-E-Up would be the ideal solution.
Jack-E-Up
I was apparently the first Canadian customer for this product, and we had to work out the shipping. Kent was very easy to work with, and the jack arrived promptly.
It was very, very easy to install, and works flawlessly. To install, I just put the trailer coupler on my trailer dolly, blocked the trailer wheels and went to work. Less than 15 minutes total.
I am impressed with an excellent product, well-built, and a customer experience that far exceeds what I normally receive. Check out his product!
An added benefit is that missing the jack makes the trailer a less likely target for thieves.
Vic
Victor Benz is offline   Reply With Quote
Old 11-18-2014, 06:25 PM   #2
Wallo's Avatar
Utah
I also purchased the Jack E Up and had it installed. Unfortunately, the results were not as good as yours. I put a wheel on my jack to move it into and out of the garage. With the wheel in place, the jack wanted to tilt, making it very unstable. Even with the foot on, using the Jack E UP was very unstable and wobbly. I decided to remove and return it. It is better for me to live with the inconvenience of not being able to open the back door, than to have the nose of the trailer crash down, or bend the post of the jack.
The product itself appears to be well made, but the safe application on my trailer did not seem to be what the normal jack provides. Just my experience, yours may vary.
Alice
Wallo is offline   Reply With Quote
Old 11-18-2014, 07:07 PM   #3
I think cpaharley put one of these on his 21' Escape.
The tongue jack on my Scamp swivels and stores parallel to the tongue. Nothing ever hangs down.
Old 11-18-2014, 10:05 PM   #4
The Minimalist's Avatar
Louisiana
You may want to consider this. Works as advertised and we love it.
Ultimate Trailer Jack Website
Clif
Old 07-02-2016, 04:57 PM   #5
hmmm... wondering whether the Jack-E up system can be used with the Ulitmate Jack. I like the quick release for taking the jack down...but removing it while underway like the Jack E up does is appealing as well. ... anyone tried it?
Teal is offline   Reply With Quote
Old 07-02-2016, 05:20 PM   #6
Louisiana
As to whether anyone has used Jack-E-Up with the Ultimate Jack I can't say. There is certainly no reason why you couldn't, since Jack-E-Up has a version to fit a standard A-frame jack, of which the Ultimate Jack is a modified version.
I don't see enough advantage to justify the doubled cost though.
Clif
Old 07-02-2016, 05:31 PM   #7
Louisiana
On second thought, looking at one of the pictures of the Little Joe setup on that trip, it doesn't appear too severe. Never the less, I don't think I could have achieved level without blocks under the jack.
Clif
Old 07-02-2016, 07:31 PM   #8
Mike Magee's Avatar
Trailer: Li'l Hauley
I like the swing-away (swivel) jacks. Harbor Freight sells a couple of them that bolt onto the frame, no welding or drilling necessary.
How to prepare Tofu
Step 2: grill some meat
Old 07-02-2016, 08:05 PM   #9
Trailer: 2008 Casita 17 SD
Wallo,
I have, and use, the Jack-E-Up and have not found any problem with "landing gear" wobble. Curious if you installed the bottom plate with the hole in it for the jack to insert through in addition to the top twist-out fixture? Mine is solid as a rock, and I push it all around the driveway with no wobbling at all.
Old 07-19-2017, 04:37 PM   #10
Trailer: In the market
Replaced a nice electric Jack with a Jack-E-Up so we could haul bikes off the back of our 4Runner. It did a great job allowing that. It also allowed us to raise the rear hatch while hooked up.
However, it proved to be quite unstable. Using the foot, it often moved off the pads despite having real stabilizers in place and stabilizing jacks just back of the tongue. Sometimes, just raising it off the ball, it would lurch forward, even with the tires chocked. Tired to make it work for the past year and we're putting the reliable electric jack back on and will look for a different way to carry the bikes.
Tincanpuller is offline   Reply With Quote
Old 07-19-2017, 07:22 PM   #11
bsedwebt's Avatar
Trailer: Casita "Cozy-Casa"
Central Virginia
love my Jack-e-up - nearly 2 years of use on 17' Casita with 535lbs front weight - no issues at all.
"Cozy-Casa" -- Visualize whirled peas
bsedwebt is offline   Reply With Quote
Old 07-19-2017, 07:37 PM   #12
cpaharley2008's Avatar
There are at least 3 positions using the Jack-E-Up, try removing the bolts and coating the attachment and re-install. After my 2nd realigment it was solid in groove. Worked for 3 years without any movement. Try to fine tune it.
Jim
Never in doubt, often wrong
Old 07-20-2017, 04:12 PM   #13
Mine is still rock solid, from the initial install.
Tongue Jack Stand fits 2" jack FTTRV Commercial Posts and Products 7 06-20-2014 08:53 AM
Atwood Fifth Wheel Jack - Electric Motor instead of Hand cranking Gail Shook Care and Feeding of Molded Fiberglass Trailers 12 07-31-2013 06:26 AM
Trailer tongue power jack The Hobo General Chat 9 02-24-2009 01:52 AM
Center jack on a 13 Scamp Joy A Modifications, Alterations and Updates 2 10-11-2008 05:02 PM
12V electric scissor jack - $49.99 CDN Roy in TO General Chat 9 04-29-2008 08:19 PM
