Old 07-15-2012, 06:09 AM   #1
Jack TV antenna install
I recently removed the Delta antenna from my Scamp and installed an aluminum cover plate. I have been looking at installing a King "Jack" antenna but it looks like it needs a roof that is at least 1 1/4" thick. Has anyone installed a Jack antenna on a thin fiberglass roof without glassing in a spacer block. Attach is the Jack inst. instructions. I found several threads about the antenna but I did not see where anyone had actually installed their antenna onto a fiberglass roof.
Thanks
Eddie
http://www.kingcontrols.com/userfile...2011-11-10.pdf
Eddie Longest is online now   Reply With Quote
Old 07-15-2012, 08:26 AM   #2
mszabo's Avatar
Name: Mike & Sara
Trailer: 86 17' Bigfoot
You can make a spacer out of wood or your favorite material.
It doesn't have to be glassed onto the roof.
I much prefer the Winegard Roadstar 1500 install it and forget it.
Amazon has them for $68.00
Old 07-16-2012, 07:07 AM   #3
Thanks for the reply. The 1500 antenna solves a lot of issues. I can get rid of the cable running across the roof, it will mount directly to my cover patch and no aiming. I just use the on board antenna when on the road. If I will be in one place a couple of days I use an external antenna mounted on a pool cleaning pole.
Eddie
Old 07-16-2012, 11:10 AM   #4
mszabo's Avatar
Name: Mike & Sara
The 1500 does it all, install and forget it.
And you get all the local HD channels too!
New use for an old TV antenna P. Raz Modifications, Alterations and Updates 1 04-09-2012 08:28 PM
Radio Antenna Sebastian H Modifications, Alterations and Updates 13 02-26-2010 09:31 AM
target antenna TonyB Problem Solving -- Owners Helping Owners 9 03-11-2008 03:17 PM
Antenna Question Chris C Problem Solving -- Owners Helping Owners 31 03-11-2008 11:05 AM
T.V. Antenna Scamp jhornsby Problem Solving -- Owners Helping Owners 2 09-11-2007 11:10 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
