Keep old door hinge or buy new one? - Fiberglass RV
Old 05-20-2013, 05:50 PM   #1
BarterBoler's Avatar
nova scotia
I have removed the door hinge from my Boler and thought I would just buy the replacement pin and ball but now I'm wondering if I should order the Scamp hinge and replace the whole thing....
The door was sagging, as is common, so I had to take it off to rehang it straight. The question is, does the hinge have anything to do with the sagging door or is it just wear on the fiberglass over time?
I've cleaned them up; do they look to worn to reuse?
BarterBoler is offline   Reply With Quote
Old 05-21-2013, 05:00 PM   #2
nova scotia
hmmm...no thoughts on this? anyone??
Old 05-21-2013, 05:08 PM   #3
Trailer: Boler 1300
Manitoba
I just purchased two new scamp hinges, because it looks like the hinge pin on mine is too small, possibly worn, or replaced with the wrong size.
JohnFHelmer is offline   Reply With Quote
Old 05-21-2013, 05:16 PM   #4
Brian B-P's Avatar
The Boler/Scamp hinge does not have a pin, it has a ball. The bolt (and spring and nut) is just for holding the parts together so they don't bounce apart over bumps: the bolt is not supposed to be anywhere near a snug fit to the holes in the ball or hinge halves.
Old 05-21-2013, 05:50 PM   #5
nova scotia
Right. I can simply order a new ball and pin for $5 but I'm wondering if the old hinge has anything to do with the sagging? If it doesn't I will just buy the new pins and reuse the Boler hinges....
Old 05-21-2013, 06:17 PM   #6
Angela, I'd buy the parts and use the original. Unless there's a crack, I see nothing wrong with using them. YMMV Now would be the time to spiff them up too. Besides Scamp hinges are three bolt, Boler hinges are two bolt... if that makes a difference to you.
Old 05-21-2013, 06:47 PM   #7
nova scotia
Thanks Donna! Appreciate it!
Oh, and what does YMMV mean?
Old 05-21-2013, 06:49 PM   #8
YMMV = Your Mileage May Vary
In other words, you may think differently
UHaul door hinge keekers Problem Solving | Owners Helping Owners 10 03-05-2012 06:38 PM
Boler door hinge repair kit and fridge access door John Jesse Problem Solving | Owners Helping Owners 5 05-27-2011 12:32 PM
Door hinge/molding RicK M Classified Archives 0 10-07-2006 10:25 PM
Door hinge Spacers Legacy Posts Problem Solving | Owners Helping Owners 0 07-11-2003 07:45 PM
Door hinge/molding Wanted: Molded Fiberglass Travel Trailers 0 12-31-1969 07:00 PM
