Leak - Fiberglass RV
Old 04-25-2012, 09:54 PM   #1
Trailer: 1977 13' Scamp
NY
Leak
Hi all,
I'm back after a winter hiatus of not really thinking nearly enough about restoring my trailer. But now that Spring is here, and I'm intending to use my 1977 Scamp quite a bit this summer, I am back to working on it when I can.
I have discovered a couple of small leaks, which correspond right to where I had some damage to the plywood floor. I did the best I could with the floor by removing the worst of the damaged layers of plywood (not all the way through, of course), then pouring a good deal of wood hardener over those areas, and then filling in the areas with Bondo brand fiberglass filler. That has worked well. The areas are pretty small, and under where the benches go. (The benches are currently on my porch.) But now I can see when it rains that I am getting very small trickles of water down the interior walls and the water collects right where the plywood was damaged.
My theory is that the leaking is coming from the belly band. A friend is going to come over some day soon and we are going to try to figure it out with a hose.
Any advice on how to fix any leaks that I do discover? I am thinking that I will remove the old, brittle caulk and then recaulk around the belly band.
Thanks for whatever advice and wisdom anyone has!
Celeste is offline   Reply With Quote
Old 04-26-2012, 06:26 AM   #2
Trailer: scamp 13
my bet is windows not belly band
john warren is offline   Reply With Quote
Old 04-26-2012, 06:40 AM   #3
NY
The windows are out, and the openings are thoroughly covered with plastic. And the leaks are clearly in the same place they were in before I removed the windows. That's why I am thinking that it is the belly band.
Old 04-26-2012, 10:26 AM   #4
Trailer: Trillium 13 ft (green grape)
I had a few leaks around the b/band of my 75 Trillium and it was coming away from the body in spots. I found a few of the rivits had rusted and let go. I cleaned all the space behind the band as much as possible, left the r/rivits in place, laid a good caulk (not silicone) behind and drilled and add more new rivits. This pulled the b/band tight again and the access caulk I removed. I will lay a small new band of caulk (good rubberized type) along the top of b/band and hopefully this should seal all.
Ron
RRJR is offline   Reply With Quote
Old 04-30-2012, 06:06 PM   #5
Fortunately if it's a leak at the belly band you won't be dealing with rusted backing plates like on a Trillium. The two halves of a Scamp are "supposed" to be fiberglassed together and the belly band (which is "U" shaped) is riveted over the lip.
Leak Kip in Ga. Care and Feeding of Molded Fiberglass Trailers 44 02-14-2011 09:42 AM
My first leak... Monica M Problem Solving | Owners Helping Owners 2 04-27-2009 09:14 PM
Leak! Help! BOBSMITH Problem Solving | Owners Helping Owners 7 10-02-2008 11:38 PM
A leak! Rarebird Problem Solving | Owners Helping Owners 15 04-19-2007 06:59 AM
A/C leak? Linda R002 Problem Solving | Owners Helping Owners 7 03-11-2007 04:50 PM
