LED Brake Lights for '86 Bigfoot B17 - Fiberglass RV
Old 03-28-2017, 09:41 AM   #1
I have A 1986 Bigfoot B17 and was curious if anyone had replaced the brake lights with LED versions. My brake lights are intermittent where the bulbs insert and would like to replace the whole fixture if one is close to the existing size.
Dave Gray is offline   Reply With Quote
Old 03-28-2017, 09:59 AM   #2
John in Michigan's Avatar
Many on this forum have done this. On my Boler 13 (now sold) I replaced the old wedding cake incandescent fixtures with sealed LED fixtures and they worked great! Much brighter and more reliable.
Old 03-29-2017, 05:12 PM   #3
Trailer: G30 Elite Class C
:check your local RV stores, Camping world, maybe remove it and take to a LED store and have them convert it to LED lights for you, nothing is impossible today to get things done if you cannot do it yourself.
Stude
stude is offline   Reply With Quote
Old 03-29-2017, 05:52 PM   #4
WHY?
Why would you want to replace the brake lights with LED lights?
All running lights including brake lights, tail light, marker lights and back up lights are powered by the tow vehicle. I see no benefit in replacing the existing lights with LEDs.
Old 03-29-2017, 06:09 PM   #5
Byron is probably right. Far more benefit using LED fixtures in places such as Michigan where dampness and road salt wreak havoc on exterior fixtures, to the point where I am constantly spraying electronic cleaner on the terminal contacts and sockets, walking around having to tap fixtures that don't light up every time I perform the light test, etc. Gee, come to think of it, I have the same problem with the 7-blade connector...
Old 03-29-2017, 06:56 PM   #6
Borrego Dave's Avatar
Trailer: Casita SD17 2006
The biggest advantage to LED brake lights is how much brighter they are and easily seen even in full sun.
Borrego Dave is online now   Reply With Quote
Old 03-29-2017, 07:00 PM   #7
I prefer a sealed LED tail light and running lights. (all the lights really ) mostly for reliability since if they are soldered in there is no corrosion in the sockets to worry about.
While it doesn't fit in you setup I installed a set of Harbor Freight round tail lights inside the original tail light setup.
Sealed.
I also installed new sealed side lights as well and every other light in the camper as well.
Old 03-30-2017, 04:29 AM   #8
Tom Trostel's Avatar
Trailer: 1980 Bigfoot 17 ft
I replaced all exterior lights with LEDs and was not pleased with the brightness of the tail lights. Since LEDs draw a fraction of the current of incandescent, I installed several LEDs under the original tail light lens. One LED is wired to the tail light circuit and the other to the brake/turn light circuit. I've now pleased with the light level.
LEDs Under Original Tail Light Lens Photo by tomNjo | Photobucket
http://s293.photobucket.com/user/tom...tml?sort=3&o=6
Old 03-30-2017, 05:45 AM   #9
Gilles's Avatar
Trailer: Bigfoot 25B21RB, 2004
Quebec
I replace the original 1157 with this quality led and it looks o.k..
$28 / cad for 2 lights, and the lighting is correct.
https://www.superbrightleds.com/more...fit/2625/5697/
At the seller he had different qualities of led and he strongly suggested me to use the high quality, similar to that in the ad that accompanies this message.
Gilles
Bigfoot 25B21RB.
Towed with Dodge RAM 1500 Echo-Diesel, 3.0 L., 8 speeds.
Old 03-30-2017, 06:42 AM   #10
using 1157 led bulbs in the taillight
I tried using 1157 led bulbs in my new old stock Trillium taillights. Resulted in insufficient brightness, so I added 2 additional 1157 sockets to each taillight for a total of 2 1157 sockets in each taillight. See thread:
Glowing Results - 70's Trillium Taillight Improvement
The improved Trillium taillights are still not as bright as sealed LED taillights. I am thinking of trying the Tom Trostel solution ...
Old 03-30-2017, 07:29 AM   #11
Trailer: Bigfoot 17' DLX
Alaska
I don't know how the 1986 is but I suspect it's the same as my '89 where the fiberglass tub is molded with a flat area to fit the tail lamp assembly (see photo). It's a pretty specific fit for the Miro-Flex tail lamps. I was never able to find a replacement LED lamp assembly that fit the mounting area properly so I just replaced the old, tired Miro-Flex lamps with new ones which can still be found in the RV marketplace. I also tried LED bulbs but was underwhelmed with the performance compared to the original incandescent bulbs. The best way to improve reliability IMHO is to get a fresh set of lamps, mount them with a fresh 'bead' of butyl tape under the base plate and around the wire holes, and coat all the electrical connections with dielectric grease. Reapply the grease periodically to keep the connections clean and insulated from the dirt and elements. I never had any issues with mine after I did this.
trainjunkie is offline   Reply With Quote
Old 03-30-2017, 07:36 AM   #12
Carl V's Avatar
Trailer: 1981 Trillium 5500
Quebec
Few years ago I installed LED panels similar to this one in the tail lights of my popup:
Boy are these bright!!
Absolutely no comparison with the old 1157 bulb.
I left the original 1157 socket in place and spliced the LED in. If the LED ever fails I can still put in an incandescent bulb to get me home safely.
I plan to do the same mod to my Trillium.
Old 03-30-2017, 04:11 PM   #13
Trailer: 1993 Bigfoot 17 ftCB / 2011 Toyota Sienna
Bargeman LED replacements.
My 1993 Bigfoot 17CB had Bargeman rear tail lights and I was able to find the exact LED replacements. Same screw holes and all. They are brighter and replace the corroded cracked ones I had. Good improvement.
Mike .....>
Michael Pupeza is offline   Reply With Quote
Old 04-02-2017, 07:19 AM   #14
Trailer: Newmar
I do a lot of maintenance work on trailers. In general LED lights are better simply because they have no filaments to burn out and break. However, there are several other things to look at when repairing/replacing trailer lights.
Corrosion issues in light sockets can be prevented by using dielectric grease on the bottom of the bulb and in the sockets. This prevents corrosion between the bulb and the socket. I highly recommend that it be used whenever replacing bulbs, whether with LED's of regular bulbs.
Secondly, when replacing any of the many clearance and other lights on the exterior of trailers, consult the online catalogs such as Grote:
http://www.grote.com/wp-content/uplo...talog_Full.pdf
Grote products, as well products from other suppliers of lights/LED products for automotive and trucking purposes are readily available from most places like NAPA, etc. and are competitively priced.
KT
skinorth is offline   Reply With Quote
bigfoot, light, lights
Trillium Original tail lights/marker lights to LED Cassie Trill Modifications, Alterations and Updates 13 07-23-2016 09:04 AM
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 10:10 AM
LED trailer lights / Non LED lights on tow vehicle Kevin K General Chat 20 11-24-2010 12:05 PM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 11:54 PM
Bigfoot b17 dlx Kenny&Jackie General Chat 5 05-03-2007 09:35 AM
