LED interior light bulb replacement - Fiberglass RV
Old 03-09-2012, 01:07 PM   #1
Trailer: 2010 13 ft Scamp
I have a 2010 13 foot Scamp. The interior lights (except for the 110v flourescent light over the sink) are 12 volt bulbs with an 1141 base. I have seen LED light bulb replacements with an 1141 base that could simply replace the original bulbs. They vary by light output (lumens), and by price.
I'm not sure if I'm searching this sight properly, but I don't see any discussions or experiences with this. The lights appear to be pricey, but the power savings seem impressive enough to pursue, especially if you're concerned with running down your 12 volt camper battery.
So, am I not searching this site correctly ?
If I am searching correctly, there must be someone out there that has "been there/done that" (I hate this expression too, but it's a good fit here).
Thanks
Larry
Larry Singer is offline   Reply With Quote
Old 03-09-2012, 01:35 PM   #2
Greg H's Avatar
Trailer: 72 Boler American
Indiana
Larry, It's here somewhere. There have been several discussions about changing to LED's so keep searching. Donna D will be able to find it for you.
Old 03-09-2012, 01:42 PM   #3
Dennis Clinton's Avatar
Trailer: Scamp 16'
Utah
Just for a little more information. I bought mine at superbrightleds.com. They have every base. Puts out plenty of light for me when I replaced mine. I also bought color changing LEDs for my low voltage landscaping lights too(cool!).
Dennis
Dennis Clinton is offline   Reply With Quote
Old 03-09-2012, 01:46 PM   #4
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Use the Google site search as opposed to the site's own search engine to search for LED conversions.
eBay also has LED lights, though the quality may vary.
Old 03-09-2012, 02:00 PM   #5
Is it this one??? LED replacement lights
If you search for LEDs, use this search term... LED* (That's LED with an astrisk.)
Old 03-09-2012, 02:27 PM   #6
Thanks, Donna.
There's good info here. And I'm going to pursue this.
But I tried "LED*" in the "search" box, both under "posts" and "threads" and it retrieved alot of unrelated posts and threads. Nothing like what you sent. What am I doing wrong ?
Larry
Old 03-09-2012, 02:37 PM   #7
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
Try this thread: http://www.fiberglassrv.com/forums/f...ing-49741.html
Spanke
Trilliums Rock!
Old 03-09-2012, 04:53 PM   #8
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
If you are going to compare LEDs from different suppliers, this information may be useful:
Probably far more than you want to know about light, but when choosing LED replacement lamps there are lots of variables. Most modern LED lamps are made of collections of SMDs attached to different lamp bases.
One of the difficulties is there are many different SMDs. SMD stands for Surface Mounted Device. There are many different electronic components that are SMDs, one type is a LED. They are usually identified by a number, and different SMDs produce different amounts of light, different color temperatures, etc. The only way you can compare how much light a lamp will produce by the number of SMDs is if they are the same model. Otherwise, a 9 SMD lamp may produce more light than a 24 or 36. Since many suppliers do not include the model # of the SMD they use, it's tough to compare.
The best method of comparing light output is by looking for the Lumen specification. That is the total light produced by the lamp. If you want the same amount of light produced by your current incandescent lamp, you need to go to a site that lists the different types & their lumen output, for example, Service Lighting. In most cases, LEDs produce less light than incandescent lamps, but they are getting better.
If you are purchasing a fixture that includes the lamp you may find the specification of light output is Lux. Lux describes the amount of light on a surface at a specific distance. The important point when comparing fixtures by Lux is distance & coverage area. Two fixtures with the same Lumen lamp may produce very different Lux because one spreads the light over a wider area. This is why a reading light (with a narrow beam) seems much brighter than a general area fixture with the same Lumen lamp.
If you are concerned about color, Warm White is the description most often used to compare to an incandescent lamp while cool white, white, or pure white compare to fluorescents. The technical description for the color attributes of a lamp are complex, but an incandescent lamp produces a color temperature of somewhere between 2800K and 3200K and a CRI of 100.
Color Temperature is given in degrees Kelvin (a scale that starts at absolute zero as 0K and shifts from infrared to red through the visible spectrum to violet and beyond (a clear blue sky without the sun is around 20,000K). A cool white fluorescent lamp produces light with a color temperature around 6000K.
Basically, Color Temperature is a method of describing the color an object will radiate if it is heated until it glows. It is more technical than that, but a tungsten filament will actually be at the same physical temperature as the color temperature it produces, while other types of light sources "manufacture" the color without actually being at that temperature.
CRI (Color Rendering Index) is a number between 1 & 100 with 100 being the equivalent of an incandescent lamp. As the number drops, the source produces light that does not render colored objects correctly. For example a Sodium Vapor street lamp has a CRI of around 24. That is why your red vehicle and lips look black in the parking lot.
CRI specifications are rarely given for LED lamps, but most of them are pretty good. CFLs sometimes have very poor CRIs which is why there are complaints about "green" colors.
One last consideration - many LED replacement lamps have voltage regulators built into the electronics. The good - they produce the same amount of light over a wide range of voltages & are less likely to be damaged by high voltage such as when your converter goes into the equalization stage. The bad - many voltage regulators create RFI (Radio Frequency Interference). They may cause lines in your TV picture or even block weak signals, and produce buzzing noise particularly on AM radio.
One solution is to purchase inexpensive non regulated LEDs & toss them if the burn out. I've used replacements panels such as these from Hong Kong - they are cheap,warm white, and I haven't lost one yet, however be sure they offer the base you need. The suppliers constantly change so you may need to do an ebay search to find a current supplier, and be willing to wait for the shipping time from Hong Kong, but you can't beat the price!
I'll stop rambling now - I'm a retired teacher & once I get started it is difficult to stop!
Old 03-09-2012, 08:22 PM   #9
Trailer: 1973 13 ft Eco Royal X's2!
Arkansas
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
I just made my second order of these from China as someone here on the board suggested.
I'm happy with the first batch. I put 7 of them in my 13' Eco.
These are going in an identical 13' Eco I'm redoing to sell on e-bay. They're $4.69 each with shipping from China.
Isn't is amazing I found TWO 13' Eco's in Central Arkansas? I thought so.
(my first post)
Paul Haney
PaulHaney is offline   Reply With Quote
Old 03-11-2012, 09:14 AM   #10
Steve Hilby's Avatar
Trailer: Compact Jr
We replaced all the incandescent 12V bulbs in my sister's trailer with Superbright LED bulbs. She's happy, and the battery lasts much longer. If I were doing it again I myself would go for something yellower, more like an incandescent; there's something so cozy about incandescent light.
Steve Hilby is offline   Reply With Quote
Old 03-11-2012, 05:37 PM   #11
Trailer: Uhaul CT-13
Ohio
I replaced my interior lights with a couple different types of LED from Ebay, all were less than $3.50 each shipped, here are some pics (I prefer a whiter light rather than a warm light).
These are expensive ones in the following picture (these were $18 each)
Panoz77 is offline   Reply With Quote
light
Found Scamp 7" LED Tail light replacement BruceG Modifications, Alterations and Updates 17 07-06-2015 08:24 AM
LED replacement for a medium screw type bulb. Bonnie Problem Solving | Owners Helping Owners 4 03-31-2008 06:00 AM
LED interior emergency light don bowman General Chat 2 05-22-2007 11:45 AM
New Interior lighting led light strips jimtesla Modifications, Alterations and Updates 2 09-15-2006 08:42 AM
LED Bulb Replacement Steve L. Modifications, Alterations and Updates 6 11-17-2005 06:20 PM
