LED Light Installation in UHaul CT13 - Page 3 - Fiberglass RV
Old 02-11-2013, 06:33 PM   #29
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by rabbit View Post
Explanation of the rationale for addition of capacitors to the reg circuitry can be found by searching Google for LED regulation topics.
jack
I don't know what they are for either.
Thomas G. is online now   Reply With Quote
Old 02-11-2013, 07:40 PM   #30
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Most comprehensive explanation here:
How to Connect a Voltage Regulator in a Circuit
I find you "train drivers" pretty scary!
Old 02-12-2013, 07:51 AM   #31
Thomas G.'s Avatar
Thanks Jack. I was half kidding, but I'd think the capacitors would minimize the interference in electronic devices like radio and TV.
My high school friend told everyone that he wanted to be an engineer and then proceeded to try to get a job with the railroad operating locomotives.
Old 03-21-2013, 10:27 PM   #32
rabbit's Avatar
Delaware
My heat sinks finally came from Thailand. I didn't bother with the capacitors. The solder joints are pretty rough; I shouldn't have used stranded wire. Did solder the the regulator last and it was much the easiest to heat and get a fast flow. Anyway I've got lights which I guess means I've got continuity thru the things. I did my three dual fixtures and I have three other flat panels in single fixtures without the regulator for a comparison of "bulb" life.
I have had no problem with the 3M double sticky stuck to the aluminum reflector in the Bargman duals or to painted back panel in other fixtures. I even have one in the range hood and it has stayed put while exhausting the heat air from three burners. I wish I knew why.
jack
Old 03-21-2013, 10:47 PM   #33
rabbit's Avatar
Delaware
bump
Old 03-22-2013, 06:33 AM   #34
Thomas G.'s Avatar
jack
Way to go Jack. Your soldering skills won't get you a job on the iPhone assembly line, but it looks solid. You used a little heavier wire than I did, but I installed a second 1 amp fuse in my light fixture to protect the small wire.
I gave up on the Chinese "3M" foam and used a thin aluminum sheet with edge flanges to trap the light panel. The foam's only function is to insulate the electrical contacts from the aluminum.
Let us know how these work out for you.
Old 03-22-2013, 03:20 PM   #35
rabbit's Avatar
Delaware
Doing better with the solder on 18awg solid conductor. Yes, I know I used black hot and green common. It's what it is and that's what Ratshack had. The conductor doesn't know the difference. I'll have to use pink butt conns on both the feed side and the output this time to avoid soldering stranded from the fixture into the pc board. It was a PITA to prop up the light fixture to do the former. I also did not use the screw terminals I bought because of limitations of hole spacing and copper trace on these little chips of board.
Old 03-23-2013, 08:56 AM   #36
rabbit's Avatar
Delaware
Ttt
Old 03-23-2013, 09:02 AM   #37
Thomas G.'s Avatar
Ttt
I think that you just might qualify for a job on the iPhone assembly line.
Old 03-23-2013, 12:10 PM   #38
rabbit's Avatar
Delaware
I ordered another envelope load of these gizmos to do the rest of the lights now that I'm certain I can get them in the fixtures. I will have to insulate the underside of the board for the remainder as they have metal shells. The Bargmans are all plastic and a single wire tie was enuf to restrain the uninsulated board to avoid shorts.
The only advantage I have soldering at this scale is that I am nearsighted and have extremely clear vision at 6 to 9" distance. I have a magnifier hood but didn't use it. The joints do look a bit more reliable.
jack
Old 03-23-2013, 12:31 PM   #39
Thomas G.'s Avatar
........ I will have to insulate the underside of the board for the remainder as they have metal shells. The Bargmans are all plastic and a single wire tie was enuf to restrain the uninsulated board to avoid shorts. ..........jack
I use the brush on electrical "tape" for this. It covers up my sloppy work.
Performix LT14023 4OZ Black Electrical Liquid Tape - Amazon.com
light, uhaul
New UHaul CT13 owner Thomas G. Hi, I am.... 42 04-14-2017 09:32 AM
UHaul CT13 Brakes Thomas G. Towing, Hitching, Axles and Running Gear 83 03-29-2012 08:07 AM
Installed Smart Light 1000 Motion Activated LED porch light Fran L Modifications, Alterations and Updates 2 02-01-2012 02:05 PM
newbee with a Uhaul ct13 dmerkel Hi, I am.... 15 01-26-2012 08:15 AM
Uhaul ct13 ScottG Classified Archives 1 11-30-2010 11:46 AM
