LED Light Installation in UHaul CT13 - Fiberglass RV
Old 03-08-2012, 03:26 PM   #1
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I wanted to add LED interior lights to my CT13, but wanted to keep the original look. So I added a 48 LED panel that I bought on eBay to the inside of the fluorescent light. Each is switched independently. I also added a small voltage regulator to protect the LED if it is operated when the system sees voltages over 12 volts and a 1 Amp fuse to protect the little wires inside.
Old 03-08-2012, 03:26 PM   #2
Thomas G.'s Avatar
Comparison of lights.
Old 03-08-2012, 05:59 PM   #3
Trailer: U Hall VT
Smile
Where did you get the voltage regulator from?
Roger Kimble is offline   Reply With Quote
Old 03-08-2012, 06:07 PM   #4
cpaharley2008's Avatar
nice job...
Old 03-08-2012, 06:18 PM   #5
Thomas G.'s Avatar
Roger, I built it using an LM2940 voltage regulator.
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
I got a little fancy and stuck a heat sink and a couple capacitors on it, but you can just use the voltage regulator as is. Left terminal is input, right terminal is output and center is a common ground. It keeps the LEDs from overheating when they see 14.5 volts during charging.
Old 03-08-2012, 06:37 PM   #6
D Davis's Avatar
Trailer: u-haul ct13
Virginia
Thomas, you never cease to amaze us.
Now will you please go outside and photo the light show in the sky I am seeing on the news. WOW! Can you see them?
(Northern Lights) Now that's a light.
Love your work.
D Davis is offline   Reply With Quote
Old 03-08-2012, 06:41 PM   #7
I just saw some strip LEDs at Costco today. For use under counters.
Old 03-08-2012, 10:41 PM   #8
djtriceflt's Avatar
Trailer: 1985 U-Haul CT-13
Great led mod!
Once an engineer always an engineer! Sweet!
I replaced the 1157 incandescent bulbs in the tail lights
with amber and red LEDs bought off eBay. Got the higher
# ones (108 for amber and 98 for red) and they plug right in
(no mods) Great increase in brightness. As you know,
much more efficient etc. Only downside is initial cost is
a little more but was very happy to pay a little more for the
better lighting!
don '85 CT-13
"Sometimes the hunt is better than the catch"
djtriceflt is offline   Reply With Quote
Old 03-09-2012, 06:13 AM   #9
Thomas G.'s Avatar
better lighting!
don '85 CT-13
Great tip. I haven't gotten to my tail lights yet, as I bought my CT in December and it won't fit in my garage. No problems with tail light converters?
Old 03-09-2012, 06:13 AM   #10
Thomas G.'s Avatar
I saw these, too. Are they battery powered?
Old 03-09-2012, 07:21 AM   #11
djtriceflt's Avatar
Tom, No problem with the tail light converter switching to the LEDs in the tail lights.
When testing it all out everything worked perfectly but has one one kinda neat side effect that was when using the 4 way flashers the red brakes lights would flash along with alternating amber turn signals! (an unexpected but even increased visibility when
using the emergency 4 way flashers) Did you install a converter already?
don
'85 CT-13
Old 03-09-2012, 07:29 AM   #12
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
Thomas,
Would you mind posting a little schematic or description of the types of capacitors you used and how they tie to the voltage regulators? I have purchased the 48 led panels also and would like to add protection to them for the same reason you did.
Thanks,
Spanke
Trilliums Rock!
Old 03-09-2012, 07:32 AM   #13
Thomas G.'s Avatar
.......... Did you install a converter already?
don
'85 CT-13
My Escape TV has a converter because it has amber turn signal lights. Ironically, I plan to install a second converter on the trailer to convert it back to amber turn signal lights. I have not rewired the CT yet.
I tow a second trailer that has combined stop / turn lights, so I need the Escape to be standardized.
Old 03-09-2012, 07:40 AM   #14
Thomas G.'s Avatar
Originally Posted by Spanke View Post
Thomas,
Thanks,
Spanke
The capacitors are probably overkill, they are for AC ripple. In any case, cheap on eBay as was the heat sink. The capacitors I used are electrolytic, so short wire and marking goes to negative (center) terminal.
light, uhaul
New UHaul CT13 owner Thomas G. Hi, I am.... 42 04-14-2017 09:32 AM
UHaul CT13 Brakes Thomas G. Towing, Hitching, Axles and Running Gear 83 03-29-2012 08:07 AM
Installed Smart Light 1000 Motion Activated LED porch light Fran L Modifications, Alterations and Updates 2 02-01-2012 02:05 PM
newbee with a Uhaul ct13 dmerkel Hi, I am.... 15 01-26-2012 08:15 AM
Uhaul ct13 ScottG Classified Archives 1 11-30-2010 11:46 AM
» Trailer Showcase
Birki2
LauraW
1979 Biggar
Mak
