LED lights in Original light sockets - tail lights - Fiberglass RV
Old 03-29-2007, 02:55 PM   #1
Manitoba
My tail lights are not very bright. The Surfside has 8" not-quite square lights that don't seem to be easily replaced with the new LED tail light units (which was my first choice). Plan B - I was thinking of replacing the bulbs in the stock tail light units with LED replacement bulbs. Anyone with experience or comments?
Old 03-29-2007, 03:26 PM   #2
Trailer: 1987 Casita 16 ft / Dodge Dakota Sport V6
Hi,
leds would work ok but if your regular bulbs are not as bright as they should be I would make sure all the grounds are in good shape> I found that in redoing my wiring and cleaning up the ground connections in both the trailer and the tug my regular bulbs lit up as they should and were very visable even in daylight. this may be a more economical fix than going to leds. also if the grounds are not repaired the leds will not function as they should as well.
regards, gerald rush
gerald rush is offline   Reply With Quote
Old 03-29-2007, 04:00 PM   #3
Alf S.'s Avatar
Hi: Try going to www.grote.com and then to product catalogue- then stop/ turn/ tail lights. They list a 2.5x6.5 oval l.e.d. that might fit inside your old lenses...That's what I did ... I took in my lense and asked if they had anything that would fit inside my old lenses sort of a retro look for our old Boler round lights!!! I drilled out the old sockets and screwed in the 10 Diode 4" round stop/turn/tail lights on the base of the old fixture/cut a hole for the pig tail to go through with a 1" hole saw on my drill. At the same time I changed the clearance lights to 13 diode l.e.d.'s. I also made sure that the wire was cut back to untarnished copper ...Neat thing about l.e.d.'s is if you hook them up wrong they just won't light Boy what a differance!!! All my lights were supplied by Traction Heavy Duty Parts Div. of U.A.P. Ontario. Hope this helps Alf S. North shore of Lake Erie
Alf S. is online now   Reply With Quote
Old 03-31-2007, 03:58 PM   #4
Brian B-P's Avatar
LED units which fit in incandescent bulb sockets are not ideal, because their directional light output pattern is not like the all-directions scatter of a bulb, so they do not work with the reflector and lens as intended.
In my Boler's Reflect-O-Lite tail lights, the reflector design is so crude that it's hard to imagine that it would hurt to use the LED unit, but I haven't tried it.
In my old Civic, I put a common (from Canadian Tire, about $8) LED 2057 replacement unit in place of one of the four brake/tail positions. I don't think the light pattern is quite as good, but it's hard to tell the difference, so based on that experience I would rate the swap as acceptable if perhaps not ideal.
There is at least one brand of LED unit which emits light in all directions, and thus look to me like they would likely be even better... but I haven't tried it. Have a look at the page of 1156 and 1157 replacement units at Autolumination.
Old 04-06-2007, 08:58 PM   #5
I asked a guy at an RV store here in Yuma about the 1156/7 replacement LEDs and he said he wasn't planning to carry them because of the liability - claimed they have caused fires. Has anyone heard that?
BruceB is offline   Reply With Quote
Old 04-06-2007, 11:08 PM   #6
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
there is a 'conversion' plug in that puts the new leds at a 90 degree turn (facing rearward, avoiding the 'directional issue). I don't know IF this conversion device would allow clearance to put the tail light lens back on or not. As for the potential fire hazard.....LEDs put out NO measureable heat.
Old 04-07-2007, 01:16 PM   #7
Brian B-P's Avatar
Doug, good catch on the angle: my Civic bulb sockets face rearward, so the common LED replacement units work, but in my Boler's Reflect-O-Lites, the socket faces vertically, so the LED unit would need to be one of the right-angle units, or be in an adapter. I doubt an adapter and the "bulb" would fit under the lens.
Even mounting at the correct orientation doesn't really address the directionality issue - with some reflectors and lenses, the light pattern will not be right with a single directional LED.
Since LEDs are more efficient than incandescent bulbs, they produce less waste heat. In addition, they do not use heat to make light, so they run relatively cool. At higher powers heat dissipation is an issue for reliable operation of LEDs, but in straight replacement of incandescent bulbs with LEDs of similar light output, there will be much less heat. I've never heard of this fire hazard issue, but I assume that it would be related to failures of some devices, rather than the heat of normal operation.
Old 04-09-2007, 05:43 PM   #8
Chuck-H's Avatar
Trailer: 17 ft Oliver Legacy Elite
Send a message via Yahoo to Chuck-H
With our Casita, the Bargmann Led conversion is just a plug n play 5 minute conversion that is fantastic! LEDs light a moment before a conventional bulb giving that tailgater behind you an extra few feet to stop! And stop they will when you tap your brake pedal, they're a lot brighter. Superbright and TMItechnology web sites give the band width of the light (narrow or wide) to help in decision making. If the tail lite housings are 90 degrees off and I believe most are, I would consider going to complete light units designed for LEDs. IMHO Chuck H.
Chuck-H is offline   Reply With Quote
Old 04-09-2007, 07:28 PM   #9
Sounds like the guy is confused...and is thinking about the Halogen Torchieres that [b]were a true fire hazard.
Old 04-10-2007, 03:09 PM   #10
Trailer: Traveler
If you have a directional beam LED, it's easy to make it a non directional. Scuff the LED across the top and sides, this will diffuse the directional beam and make a more 360 degree beam out of it.
I do it all the time on my R/C airplanes.
Brad J. Mitchell is offline   Reply With Quote
Old 01-24-2009, 01:11 PM   #11
Roy in TO's Avatar
Thanks for posting that Chuck. I missed that line the first time around. I just found a similar statement while reading about LED's on Wikipedia and thought that it would be worth repeating, the page says:
"The significant improvement in the time taken to light up (perhaps 0.5s faster than an incandescent bulb) improves safety by giving drivers more time to react. It has been reported that at normal highway speeds this equals one car length increased reaction time for the car behind."
Definately a good reason to convert to LED tail lights that is worth repeating.
Old 01-27-2009, 12:14 PM   #12
ddayton's Avatar
Trailer: 2007 Casita 17 ft Spirit Deluxe
Send a message via Yahoo to ddayton
<snip>"The significant improvement in the time taken to light up (perhaps 0.5s faster than an incandescent bulb) improves safety by giving drivers more time to react. It has been reported that at normal highway speeds this equals one car length increased reaction time for the car behind."
True, and given the increased brightness - it they can't stop in time then nothing would have worked!
LED TAILIGHTS
LED BRAKELIGHTS
Don
ddayton is offline   Reply With Quote
Old 01-27-2009, 12:35 PM   #13
Raya's Avatar
There are many good things about LED taillights, but the one thing that drives me nuts is how bright the taillights are (as opposed to the brake lights). Regular old taillights always seemed perfectly visible to me, as they should be, but they never screamed "I'm doing something unusual; LOOK at me!" That's what brake lights did (and do). To me, that's as it should be. If I'm driving along, "monitoring" 50 other vehicles in front of me on the freeway, I don't want them ALL shouting that, unless they're all doing something special, like braking.
I find that with the LED taillights, they're so bright, that they look like brake lights all the time. So what happens is that for the first few minutes, I find myself constantly "starting" in my seat, because my driving sub-conscious says "That car is doing something besides just driving along." That happens for a while and then finally I have to put my brain in "ignore" mode, so that I can quit mentally (or physically) leaping for the brake (while my brain processes exactly what is going on).
So now I've got an "ignore" shield on for the vehicle with the LED taillights, and am focusing my attention on the vehicles with regular taillights, which impart meaningful information without freaking out my subconscious. As a result I actually end up paying less attention to the LED taillights than to regular ones (of course LED taillights probably don't have to be so bright, but it seems that they are so bright in their current iteration).
So... I love the "quick on" of LED taillights, and I love really bright brake lights; but I don't think that taillights should necessarily be "as bright as possible just so you see me." There's a place for lower-level "I'm here but everything is going along as it should; I'll let you know if anything special is happening" lighting.
/rant
R.
Old 01-27-2009, 12:48 PM   #14
ddayton's Avatar
<span style="font-size:12pt;line-height:100%">R I hear and understand what you are saying. </span>
<span style="font-size:12pt;line-height:100%">You sound as if you are not the person that caused me to mod my lights to LED. That person is one who has put their driving brain into sleep mode while they have cranked up their music to maximum, are talking/texting on their cell/blackberry while air-heading down the road as if they were the only one in the world. It is that person that I want my lights to drill through the other stuff and get their attention before my rear bumper does.</span>
<span style="font-size:12pt;line-height:100%">Sorry to say but I meet too many drivers like the latter and not enough responsible, attentive drivers such as yourself. Wish everyone would put driving as job #1 and not something that will take care of itself.</span>
<span style="font-size:12pt;line-height:100%">(my return rant) </span>
<span style="font-size:12pt;line-height:100%">Gosh, I am ready for spring and getting back on the road!</span>
Don
led lights, lighting, lights, tail lights
Very Dim Tail Lights Will Wi Problem Solving | Owners Helping Owners 2 07-16-2008 09:23 AM
New Original Trillium Tail Lights D Martin Modifications, Alterations and Updates 9 01-23-2007 03:29 PM
LED lights in Original light sockets Gerry Modifications, Alterations and Updates 21 01-05-2007 02:03 PM
Adding 12v Sockets & Lights peterh Problem Solving | Owners Helping Owners 17 12-13-2006 04:24 PM
Original 1976 Boler interior Lights Gord Plowright Classified Archives 0 06-20-2006 08:11 PM
