LED tailight mod..... - Fiberglass RV
Old 06-17-2008, 09:23 PM   #1
Trailer: 1978 Surfside
This is something that I just tried out. I didn't want to replace the stock tailights so came up with this idea and due to the LED lights being so bright its still a huge difference even with the extra red lens. The LED lights came from Princess Auto on sale for $9.99, the angle bracket is something from Home Depot that cost a $1.50 that I found in the fence department, and then glued with some two part epoxy glue and epoxy putty. Only other mod which was needed was to remove the blub assembly and cut some of the stock plastic out from the light fixture. Let me know what you think.
kentj is offline   Reply With Quote
Old 06-17-2008, 11:10 PM   #2
Ian-Vicki's Avatar
Name: Ian or Vicki
Trailer: 17 ft Burro Widebody / 2007 Explorer Sport Trac
I'm assuming these are running lights, not brake lights. Look great!
How did you maintain the seal for the trailer?
cheers
Ian
Ian-Vicki is offline   Reply With Quote
Old 06-17-2008, 11:40 PM   #3
cheers
Ian
Nope they are both running/brake/turn (see the three wires) As for the seal not much will change there, because the wires came through the shell, so I'm going to pull the new wire to the inside and splice the new with the old. I'll fill the hole up with some marine caulking, (it doesn't have to look that great as it would never be seen)
Kent
Old 06-17-2008, 11:51 PM   #4
Daniel V.'s Avatar
Trailer: -
Do you have a separate light for the license plate? In my case one of the rear lens is made partly transparent at the bottom so that the original incandescent bulb running light also lights up the license plate through the transparent part, since the bulb sheds lights in all directions unlike the LEDs. So I was wondering if you were in a similar situation and how you would deal with it.
Daniel V. is offline   Reply With Quote
Old 06-17-2008, 11:58 PM   #5
Didn't really think about it, but I'm sure I could get a single white LED light in there too. But don't really plan on towing or being on the road in the dark. But good catch!!
KJ
Old 06-18-2008, 08:57 AM   #6
Scott S.'s Avatar
Trailer: 1975 Surfside TM14 (front kitchen)
Manitoba
Send a message via MSN to Scott S. Send a message via Yahoo to Scott S.
KJ
mine came with LED's thanks to the previous owner so I don't even know what the stock lights look like. here's what they look like on mine. also shows the new decals we discussed Kent. they turned out great.
Scott S. is offline   Reply With Quote
Old 06-18-2008, 09:48 AM   #7
Hey Scott those lights look pretty stock to me...did the previous ower just replace the bulb with a LED one? By the way that new decal looks great!!!
KJ
led lights, lighting
Scamp LED Tailight Replacement Greg A Modifications, Alterations and Updates 11 11-06-2007 10:32 AM
Broken Boler Tailight Mario H. Castillo Problem Solving | Owners Helping Owners 0 05-17-2007 06:33 PM
Tailight Question Ken Ford Problem Solving | Owners Helping Owners 5 05-14-2006 03:28 PM
