led trailer lights - Fiberglass RV
Old 10-23-2012, 04:35 PM   #1
jim ellis's Avatar
Name: jim & mary
Trailer: scamp 13 1999
led trailer lights
Where can one purchase led taillights for a 1999 scamp 13 ft trailer,or conversion boards?
thank you
Jim ellis
jim ellis is offline   Reply With Quote
Old 10-23-2012, 05:57 PM   #2
Dennis Clinton's Avatar
Trailer: Scamp 16'
Utah
If your current lights are the rectangular ones(bargman), etrailer.com sells a bargman LED that will fit over the same holes as the ones on your trailer. If it's the round ones, look at the commercial listings here-good inexpensive ones)
Dennis
Dennis Clinton is offline   Reply With Quote
Old 10-23-2012, 06:04 PM   #3
Thomas G.'s Avatar
Can't you just buy LED bulbs to replace the incandescent bulbs in your current tail lights?
LED Lights for Cars | 12v | Super Bright LEDs
Old 10-23-2012, 06:41 PM   #4
Trailer: Scamp 16'
Utah
You can buy replacement LED bulbs for the lights. I did that and found that they are not as bright as replacing the whole fixture and you still have the problem of older bulb sockets that no longer make good contact. When replacing just the bulb, much of the light is still reflected light. When I have the chance, I am replacing the entire fixture.
I did replace the interior lights with flat LEDs wired to a base that fit in the old fixture.
Dennis
Old 10-23-2012, 06:55 PM   #5
LED Light | 7" Round Red | Fiberglass Travel Trailers RV
Old 10-23-2012, 09:33 PM   #6
Deb & Chuck's Avatar
I have the LED 7" round tail lights that fit Scamps and Bolers.
Chuck
Deb & Chuck is offline   Reply With Quote
Old 10-24-2012, 05:12 AM   #7
Trailer: 1991 17 ft Horizon
I can attest to the ones Chuck sells, they are excellent and at a great price too.
Old 10-24-2012, 05:30 AM   #8
Chucks LED 7" lights are great. Just remember you may have to fabricate a lic plate holder and add lic plate lights but that goes for any of the 7" transit lights.
Eddie
Old 10-24-2012, 05:30 AM   #9
Steve Hammel's Avatar
Trailer: Trillium 4500
If none of the others work for you go to the RV section at Walmart. They have very inexpensive LED side marker and tail lights that are the perfect size and did I mention cheap.
Old 10-24-2012, 05:50 AM   #10
Raz
Raz's Avatar
Be aware that the Bargman LED replacement fixtures are sealed and not repairable. I had one fail after two years. The cost was over $40. I am a big fan of LED lights. I think having the full lens illuminated is safer. But they are pricey. Raz
Old 10-24-2012, 08:10 AM   #11
Fran L's Avatar
Trailer: 2007 Scamp 16 ft
We replaced the rectangular Bargman's (apologies for the dirty Scamp in that photo!) with the Bargman 07's. Two of the holes from the old lights lined up with the new lights, one was hidden under the new fixture and one we plugged with butyl tape.
The new lights DO have a license plate holder although we had to get slightly longer bolts. There are no backup lights but we decided that wasn't as important as brighter taillights for going forward!
The part of the unit that houses the lights IS sealed. The lens does come off.
It is really nice to have brighter taillights!
Fran in NM
Fran L is offline   Reply With Quote
Old 10-24-2012, 06:22 PM   #12
I like the shape of those tail lights. Look like lil tennis shoes. Cool! Much better to be one of one, than one of many IMHO!!
Old 10-24-2012, 06:26 PM   #13
Fran L's Avatar
Thanks Donna - we like them too! And they weren't hard to install. You can also mount them in any orientation you like. This worked best to use and cover the existing holes.
Fran
Old 10-24-2012, 06:43 PM   #14
Jim Bennett's Avatar
Fran, check the plastic license plate tabs fairly frequently, as I had a friend lose a license plate when they broke off after a few years of use.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 10-24-2012, 07:56 PM   #15
Fran L's Avatar
Thanks for the warning - we'll make sure to check that!
Old 10-26-2012, 09:21 AM   #16
Trailer: 1984 UHaul CT13
Tom, did you use these in your UHaul? Now if we ever get the new tailight lenses.
keekers is offline   Reply With Quote
Old 10-26-2012, 10:10 AM   #17
Originally Posted by Eddie Longest View Post
Chucks LED 7" lights are great. Just remember you may have to fabricate a lic plate holder and add lic plate lights but that goes for any of the 7" transit lights. Eddie
Actually I found a way to use the original lic plate holder without any modifications needed. You can purchase from a motorcycle or ATV shop small bolts for attaching the lic plate to the holder that have LED lights built into the bottom half of the heads which light up the lic plate.
lights
LED trailer lights / Non LED lights on tow vehicle Kevin K General Chat 20 11-24-2010 12:05 PM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 11:54 PM
led lights Pat C Problem Solving | Owners Helping Owners 2 07-16-2008 11:22 AM
NEW LED LIGHTS!! Christi V. Modifications, Alterations and Updates 12 05-10-2007 09:10 PM
LED Reverse lights - inside trailer ? Kurt in BC Modifications, Alterations and Updates 3 04-18-2006 04:09 PM
