Life Caulk - Fiberglass RV
Old 12-12-2013, 01:10 PM   #1
Trailer: 1998 14' Burro WB
Illinois
Life Caulk
Has anyone ever used Life Caulk to reinstall windows and doors?
I picked up my Burro from the fiberglass shop a couple weeks ago. I told him my next step is to pull out all the windows and reseal them because I was sure they were in with putty and not butyl. He told me to use life caulk instead of butyl tape. It remains flexible and seals better. However, I am pretty nervous about using it. It gets mixed reviews but, most of the ones complaining were complaining because it didn't work because they had not done the proper prep and they thought it should still have worked.
I would like opinions from others working on FG trailers.
Thanks
Jim
Do not go where the path may lead, go instead where there is no path and leave a trail - Emerson
jetalkington is offline   Reply With Quote
Old 12-12-2013, 01:26 PM   #2
Trailer: Scamp 13
Life caulk done properly will work great until the next time you want to take it apart. While it remains flexable it is solid and unreleasing. At least with Butyl you can heat it up and push the gooey mess apart.
Remember that the Life caulk you will have to clean off the mold release from the fiberglass under the seal flange for it to stick to the fiberglass and seal. It is used on boats under the water line it seals so good when properly done.
Old 12-12-2013, 04:39 PM   #3
I've used Life Caulk on boats but I would never use it to seal a window. If you ever have to remove the window again you would probably destroy the window frame or the fiberglass on your trailer.
I would use butyl tape.
Old 12-12-2013, 04:49 PM   #4
Carol H's Avatar
Someone at one of our meets used it on a rear window once but they broke a window and had to remove the frame to get it fixed. As I understand it that wasnt an easy thing to do and they indicated they would not be using it again as a result and would stick with butyl tape.
Old 12-12-2013, 07:08 PM   #5
Originally Posted by jetalkington View Post
......and seals better.
How can something seal "better" than 100%? Butyl, if using the right kind, and applied correctly will last years.
Old 12-13-2013, 03:45 PM   #6
Illinois
Thanks. Life caulk is great stuff that will last for years but the point being made is the right one. Life caulk's great strength is it's downside for us. It is hard to get it to release if you ever want to remove an item.
Plus in my research I stumbled into this article. It has a great description on how to use butyl tape and on the different types of butyl tape.
After getting my Burro into the garage I got a chance to inspect it and found water inside. It was raining the day I picked it up from the fiberglass shop. I traced it back to the two side windows and the front window. So, my hunch about the windows leaking has been confirmed.
When I removed the vent, to get it in the garage, I found it install with putty and silicon sealed around the edges.
So, I am ordering some butyl and pulling all my windows.
Jim
Old 12-13-2013, 08:12 PM   #7
Smart, very smart Jim. Get the butyl that sticky! I mean the kind that sticks to everything it touches including your fingers... like soft bubble gum. Some is more like old plumbers putty, you want the shiny stuff. You'll know when you get the right stuff when you stretch it out and it gets thinner and thinner without breaking. I usually buy what I need at Camping World because they sell so much of the stuff it's fresh. Even at full price it's less than $10 for about 25 feet.
And for heavens sake never use silicone on the exterior!!!
Old 12-13-2013, 08:48 PM   #8
David B.'s Avatar
Thank you Jim for the article in the link. I ordered 2 rolls of the butyl tape from the linked marine supplier, and should have it in about 4 days. The rear window and vents are coming out to be done properly.
Dave & Paula
Old 12-14-2013, 09:47 AM   #9
Trailer: 2015 Scamp 16' deluxe 2008 FJ Cruiser
I get my butyl at the auto parts. Comes in rolls of different sizes. Its used for putting in windshields.
Ken
Ken in Pa is offline   Reply With Quote
Best Butyl caulk? Craig D. Thompson Care and Feeding of Molded Fiberglass Trailers 7 02-25-2012 08:02 AM
The Caulk Option Roger C H Care and Feeding of Molded Fiberglass Trailers 18 02-13-2010 09:16 AM
Caulk Steve Dunkel Problem Solving | Owners Helping Owners 4 07-19-2009 04:33 AM
which caulk to use Isaac Problem Solving | Owners Helping Owners 1 06-06-2007 11:31 PM
Caulk deidre falin General Chat 0 01-01-1970 12:00 AM
