Lifted Scamp - Fiberglass RV
Old 03-21-2013, 08:51 AM   #1
3Up Adventures's Avatar
Trailer: 1977 13' Scamp
USA
Lifted Scamp
As with most older Scamps, the torsion axle was worn out leaving the trailer practically on the ground. For us here at Team 3Up, this was not a workable situation as we love to take the road less traveled. Fortunately, Forrest was very confident that he could make this a 4x4 Scamp.
We purchased a 2000 pound leaf spring axle assembly, found matching Jeep wheels in Phoenix, and Forrest drew up his plans. The result is really quite amazing: the Scamp sits about a foot higher and tows along behind the Jeep like a dream (more on our shake down trip of the Scamp this afternoon).
Without further ado, 3Up Adventures' lifted Scamp:
Check us out: 3UpAdventures.com
3Up Adventures is offline   Reply With Quote
Old 03-21-2013, 10:08 AM   #2
Trailer: Scamp 19
That looks great,same size wheels = more spares. What type axle or lift? what is your measurement from ground to the bottom lip of the trialer? good job Rob
Rob in Vista is offline   Reply With Quote
Old 03-21-2013, 11:47 AM   #3
USA
I'll have to remember to take a measurement of the trailer lip to the ground sometime today. It's a pretty generous step.
The axle is just a 2000 lb leaf spring set up (spring under). There is no "lift." We're running matching wheels to our Jeep (Cherokee "Ecos") with I *believe* 215s.
Old 03-21-2013, 12:27 PM   #4
Brian B-P's Avatar
I'm usually not a fan of jacking up trailers, but in this case it seems appropriate for the application.
Is this a straight (no drop) axle?
The Scamp frame has a dropped floor section and door opening in it. Are the spring and shackle mounts directly attached to the main frame, or is at least the front end bracketed down to accommodate frame features, or to get the axle tube under the floor? Photos would be interesting...
My guess is that means something like 215/75R15 tires on the Scamp... but does the Jeep have larger tires? My guess is yes, significantly.
Old 03-21-2013, 06:26 PM   #5
Steve_N_Janna's Avatar
Name: Steve and Janna
Trailer: '02 Scamp 13
I love it --- very nice!
I notice you are hauling a little dual sport (KTM?). Do you mind sharing how you mounted up the carrier?
Steve_N_Janna is offline   Reply With Quote
Old 03-21-2013, 06:26 PM   #6
USA
It is a straight axle. It is mounted at the level of the dropped frame with extra steel welded into the rear to make it level.
The jeep runs 31s. The Scamp is on 205/75R15...we started with 235s and decided to come down a bit in size.
Old 03-21-2013, 06:27 PM   #7
USA
We don't actually haul the KTM.
Forrest got the hitch all fabricated and only to find out that the frame was flexing under the load when it was bounced. :-/
Old 03-21-2013, 06:41 PM   #8
Brian B-P's Avatar
Perhaps just as well: it would be a stability problem.
Old 03-21-2013, 06:51 PM   #9
Brian B-P's Avatar
Thanks
The jeep runs 31s. The Scamp IS on 205/75R15...we started with 225s and decided to come down a bit in size.
31x10.5R15 is 31" overall diameter (the size of a 275/75R15)... wouldn't fit the Scamp! 205/75R15 seems like a reasonable choice (about 27" overall)
Old 03-21-2013, 07:06 PM   #10
Too cool! I too have 205/75 R15s on my Scamp with matching wheels to my (soon to be tug). But, I had a torsion axle put on with a 45 degree down Dexter axle. I wanted the 10" brakes. Mine too looks like a four-wheel drive model, but now I have a real step!
NEATO!!!!!!!!!
Old 03-28-2013, 06:01 PM   #11
hellsbay's Avatar
Trailer: Oliver Legacy Elite 17
That looks so much better!!
Steve
Steve Petersen Photography/Facebook http://ning.it/UdDkaV
http://www.stevepetersenphotography.com
hellsbay is offline   Reply With Quote
Old 03-28-2013, 08:27 PM   #12
Tonia's Avatar
Trailer: Scamp 13' (1982)
Wisconsin
Ooh! I want mine to match my wrangler :-)
Tonia is offline   Reply With Quote
Old 03-28-2013, 08:37 PM   #13
carlkeigley's Avatar
NE Oklahoma
After shot looks like a totally different trailer.
Looks great.
Old 03-29-2013, 04:38 AM   #14
Trailer: Scamp 16ft
Alabama
I'd like to do that to mine but can't justify, intill I need a new axle. bet you got less sway now too.
Darrell in Al is offline   Reply With Quote
Can I get some lifted Scamp pics? aaronmt Towing, Hitching, Axles and Running Gear 12 07-18-2014 06:06 PM
has anyone lifted a camper to fit larger tires? ampline Modifications, Alterations and Updates 3 08-01-2012 12:04 AM
My lifted Jeep pulling my Scamp 16 BenB General Chat 5 06-23-2009 07:21 AM
Toronto Travel Warning (LIFTED 4/29!!) Legacy Posts General Chat 22 04-29-2003 02:11 PM
