Light Fixture Ideas - Fiberglass RV
Old 01-17-2013, 04:23 PM   #1
Name: Steve and Rosemary
Utah
Light Fixture Ideas
Hi all, I was wondering if anyone has tried changing out light fixtures. In particular, I was thinking of putting a two-bulb fixture in the bathroom similar to attached. So, my questions are:
1. Is it pretty simple to change out light fixtures?
2. Do you think something like this would work in a Scamp bathroom (toilet/side/16ft)?
3. Do you have any tips on how to update fixtures?
Thanks for your ideas in advance!
SERENITY 1989 Scamp 16' Side Toilet | Steve, Rosemary, Maude Pod & Tripawd Hope | Next trip: The Weber for some fishing
Moab Maiden Voyage 03/10 * The Swell 5/26/11 * Antelope Island 12/31/11 * Strawberry Res 6/12 * Whitney Res 6/14 * Uintahs 07/15 * East Fork of Black's 06/16
Steve and Rosemary is offline   Reply With Quote
Old 01-17-2013, 06:44 PM   #2
I have changed out light fixtures but not 12v to 110v. I did a little google on the photo and see its 110. You would need to run new wire from one of your 110 receptacles to the bathroom light. I am not sure why you would want to do that though. Wouldnt work if you were not plugged in - not to mention the safety issue of having 110 power in what is a wet bathroom. More than the lights might light up during a shower ;-)
Old 01-17-2013, 07:01 PM   #3
David Tilston's Avatar
You could use this fixture with 12 VDC. Bulbs that look like the regular 110VAC variety are available in 12VDC.
DULUX EL 12VDC/WW | Price $19.95 | Compact Fluorescent CFL Lamp 12V/240V/277V | 11W CFL DULUX 12V DC 2700K 4008321118370 OSRAM
Old 01-18-2013, 12:41 AM   #4
Trailer: '77 Scamp
Most folks seem to be going to LED l2v lights. I just ordered 2 to replace the 12v lights in my Scamp. You can find lights that put out nice light if that's your goal going with the 2 bulbs. Just a thought.
Otters is offline   Reply With Quote
Old 01-18-2013, 12:00 PM   #5
Trailer: 1973 Love Bug '13
Am I to understand that a 110 light fixture can be converted to a 12 volt fixture simply by putting in a 12 volt bulb?
Cat futrell is offline   Reply With Quote
Old 01-18-2013, 12:23 PM   #6
Well, there may be some CSA issues, or UL in the states, but a mogul base light fixture is just a way to electrically connect the bulb to the power. As long as the wires in the fixture are large enough to carry the required current then yes, just putting in 12 VDC bulbs will work. On a compact florescent bulb, the current requirements would be small. If it were a 100W 12VDC incandescent bulb, that would be 8.3 amps. This would require at least 18AWG wire. The 11W bulb would require 0.9 amps. Virtually any wire would work for that.
NOTE: This is not the case for any fixture with a ballast, such as a florescent fixture that takes the straight tube type bulbs.
Old 01-18-2013, 12:39 PM   #7
Thanks Dave, that helps!
light
Anyone Have Outside String Light Ideas? barryra General Chat 25 07-15-2012 08:00 PM
Needs ideas for a replacment fixture insert for outer light Panoz77 Electrical | Charging, Systems, Solar and Generators 9 09-02-2011 11:22 PM
Replace tail light fixture? KarenH Problem Solving | Owners Helping Owners 7 09-29-2010 06:48 AM
26-1/2" LED Light bar Fixture peterh Modifications, Alterations and Updates 6 02-26-2009 08:00 PM
Hand Pump Water Fixture Brian T Problem Solving | Owners Helping Owners 1 05-28-2007 05:36 AM
