12-07-2012, 06:43 PM
#41
Name: Borden and Carole
What is in the car is still being transported by the car. In the car, trunk or trailer same engine is pulling it all. The axle on any trailer should manage any reasonable amount of contents .
Car rules are a bit different than truck rules the car has a max gross weight.
Ours is 825 this must include the driver, passengers, cargo in car and trunk, hitch weight, draw bar or WD system and tongue weight.
eg.. self 180 lbs, wife 155 lbs, dogs 2 total 27 lbs, hitch 40 lbs, WD unit 66 lbs, tongue weight 169 lbs. (grand total 637) 825-637=188 lbs to spare
So just load the trailer, also do not know rules for your area but should be similar
Our postage stamp in heaven.
#42
Name: You can't call me Al
Trailer: SOLD: 1977 Scamp 13'
Massachusetts
A long time ago I wanted to modify a car for electric use. (Before Prius etc.)
I took some NHTSA and DOT information and built a table of horsepower vs. vehicle here
The number in the second column is the horsepower required to push the vehicle down the road at 50 MPH.
From the all vehicles list, you can see that it takes between 4.6 HP and 29.4 HP just to push the vehicle down the road at 55 MPH.
So that's going to come into your equation also.
12-07-2012, 06:48 PM
#43
In Ontario the MTO requires that if the trailer is 50% or more of the weight of the towing vehicle you need tailer brakes. Electric bakes require a breakaway switch. The car and trailer have to be level not sagged in the middle that is why some would need a WD system to level the load or cargo coils.
12-07-2012, 06:50 PM
#44
Trailer: 2015 Escape
Sure would be better to be lightening a trailer to be lightning it.
12-07-2012, 06:56 PM
#45
Agree with you, hp and gearing are important, you have to be able to pull the load at speed and not just on the flat but also up hill as well. We have some steep hills in our area. Just did a 3 hour drive back on Tuesday.
A car with higher gearing or less hp could not pull our trailer uphill or at speed (I do not go over 90/95 kph)
12-07-2012, 07:09 PM
#46
Agree with you on this count but it is hard to do; every time we lighten one item is seems we add something else.
The back upper bunky is so heavy it is going to go, we do not use it as a bed so will make it much lighter and still fold down for storage.
We are adding a new hot water tank and it is heaver than what was offered when the trailer was built; so the bunky savings will be lost but other areas are much heaver than needed so room to work. Will have a drain on the hot water tank to drain it before we travel.
Have the last of the parts needed so this winter it will happen.
12-07-2012, 07:28 PM
#47
Originally Posted by orangeboar
...maybe I should also clarify my "need" to lighten the trailer.
I noticed on another thread that actual weights for some of the trailers can be closer to 1500 lbs, instead of the advertised 1000 lbs weight (with the 13" scamp trailer). My wife and I currently have two cars, a. Scion xb and a matrix, so lighter weight would help reduce strain on the car (probably the matrix) and help with gas mileage - I'm kind of a mileage junkie too (I'm always trying to see what I can do to improve the gas mileage on my car.
So a few specific questions: (answers for our setup)
- what are the heaviest components in the trailer?
(ours is the seats and cupboards they will be lightened as possible)
- what have other users done to reduce weight?
(travel without water at start and empty tanks often, load light)
- what have other users done to improve gas mileage (wheels, drag/aero dynamics?)
(boler is aerodynamic in design and thinner fiberglass than newer units, and we have new radial trailer tires)
- is it better to carry weight (water, gear, etc) in the car or the trailer?
(pull the weight in the car or trailer same total, so travel light with water tank empty and get food as needed) note: cars have a max weight
- what is the smallest car you have pulled with?
(Echo small tent trailer) Current trailer required a larger car.
- what's the lowest mpg that you have achieved?
(28 mpg best no head wind and flat road) not exactly the question "uphill against the wind would be the worst possible"
- what toll does it put on the car when climbing hills (speed, strain, etc.)?
(we have as transaxle cooler part of tow package) Note: you can add after market but it adds to the car weight total.
I hope this makes some sense?!
(hope this is of some help; remember keep it legal)
Thanks for the help!
Tried to answer your questions as best possible
12-07-2012, 07:37 PM
#48
P.S. matrix is smaller than our car in wheel base and may have a higher center of gravity but no problems with a 13' trailer. We have found a sway-bar to be good to have even with the smaller old trailer behind our Echo in the past.
Personally from towing experience needed or not by law (50% rule and over 3500 lb rule) feel any load over 500 lbs it is good to have some sort of brakes on the trailer.
12-07-2012, 11:30 PM
#49
No difference - both cars and trucks have - Gross Axle Weight Rating - Front (GAWR-F)
- Gross Axle Weight Rating - Rear (GAWR-R)
- Gross Vehicle Weight Rating (GVWR)
- maximum payload
- Gross Combination Weight Rating (GCWR)
The first three are shown on the vehicle's placard. All but the GCWR also apply to the trailer (with its own numbers, of course). A travel trailer's payload may be even less than that of a compact car, although some are very high.
That's the payload, not the Gross Vehicle Weight Rating (or "max gross weight").
12-07-2012, 11:52 PM
#50
Toyota Matrix and Corolla facts
matrix is smaller than our car in wheel base...
The Matrix hatchback is built on the same platform as the Corolla sedan (Borden's car), and has the same wheelbase; in some markets the hatchback is apparently sold as the "Corolla Matrix".
See Wikipedia: Corolla and Matrix, or check a more authoritative source (such as the references quoted in the Wikipedia pages), but for this sort of detail I believe that Wikipedia is usually accurate.
The Matrix is shorter overall (4394 mm versus 4540 mm in the current generation), and the difference is primarily in rear overhang. That should make the Matrix better for towing, as the forces on the tow ball (due to trailer tongue weight and inertia) have less leverage on the tow vehicle.
12-08-2012, 12:04 AM
#51
You're a Hypermiler?
12-08-2012, 04:21 AM
#52
Trailer: 1984 19' scamp
Kansas
Wow, that website makes me twitch just reading it. Park at the high point of a parking lot so you can roll out of it? Shut your car off at stop lights? Purposely drive slow to make people pass you and trip red light sensors so you don't stop? Good grief.
12-08-2012, 05:58 AM
#53
You probably want to learn to accept that idea - it's becoming common in Europe for cars to have stop/start fitted and if/when the EPA includes the effect in the official fuel consumption tests, you will probably get it too.
I'm on my second car with this feature and after a little acclimatisation, you get used to it and start to wonder why others have their engines running when they're not moving. The car is fitted with a stronger starter motor and has a sort of regenerative braking (normally the alternator only charges the battery when the brakes are being applied - so electrical power is 'free'). It's good for something like 1-2mpg in urban use of European cars, so maybe ½-1 mpg on North American-sized vehicles.
If I come to a stop, put the manual gearbox in neutral and let up the clutch, the ECU decides that I don't want the engine temporarily and, if a long list of conditions are met, it switches the engine off. As soon as I touch the clutch pedal, the engine restarts itself - with a small petrol/gas engine, it is just about possible to stall the engine by letting the clutch up too soon, but now I've switched to a diesel, I can't 'beat the system'.
Many people believe that this is bad for engines, because they know cold starts cause lots of wear, but one of the conditions for the ECU to operate the stop/start is that the engine is up to temperature. There are many, many other conditions - which are fun to try to 'reverse engineer' from the car's behaviour.
Apparently some manufacturers have worked out how to apply this to automatic gearboxes, but as yet it's only fitted to cars with manual gearboxes.
From your alien correspondent
12-08-2012, 06:06 AM
#54
Trailer: Trillium 4500
For me there are other factors affecting my MPG that have recently come into play. Having Vegas as my home base I spend a lot of time driving long stretches of desolate desert with temps ranging over 110 F. I notice a huge decrease in MPG when my truck's operating temperature increases even modestly (never in the red or dangerous range). I purchased and installed an electric helper fan which helped considerably but the truck still runs hotter than average in extreme conditions. My next project will be a transmission oil cooler which I've been told by many experts should have been my first purchase.
12-08-2012, 01:20 PM
#55
Trailer: 2008 13' Scamp
...but, after that... What can be done to make it lighter??
Any obsessive weight weenies out there?
Any fan of Colin Chapman (designer of the first Lotus cars) would fall into that catagory. His design rationale was "add lightness".
I followed that principle building a replica of one of his cars. Every piece that went into the car was lightened to remove unneeded material. My on the road weight is 1260# I don't have a lot of horsepower but the performance is awesome.
If I had bought an older trailer needing a major rehab it's fair to say that, as a starting point to lighten it, there would be no OSB or MDF.
Ron
12-08-2012, 01:48 PM
#56
I think the full quote is "simplicate, and add lightness" - on the grounds that engineers have an awful tendency to complicate and add weight. I believe he 'borrowed' the phrase from common use at the time in the US aero industry.
12-08-2012, 05:09 PM
#57
"Simplicate and add more lightness."
A quick Google search strongly suggests that the saying "Simplicate and add more lightness." was popularized by William Bushnell Stout, although perhaps originated by Stout's aircraft designer Gordon Hooton. Chapman later adopted the philosophy.
"Simplicate" is not proper word, of course. Logically, the statement should be "simplify, and reduce weight". My guess is that it is a negation of something like "complicate, and add weight", used to suggest an approach which is the opposite of common trend.
Applied to a travel trailer, this philosophy implies the elimination of unnecessary components or systems, which results in weight reduction. That is, perhaps leave the microwave oven and television at home, and thus be able to leave out the AC electrical system as well.
12-08-2012, 05:14 PM
#58
Another option being, to just stay home.
12-08-2012, 05:18 PM
#59
Trailer: FunFinder
The trouble with, simplifying the engineered pieces to 'add lightness' is that it typically adds astronomical costs. That's fine in an aeroplane, and especially so in a combat aircraft, because every pound of saved weight in the plane itself, is another pound of fuel or munitions you can carry, which of course is the purpose of the mission.
You want to build a lightweight camper trailer, you surely could do it using exotic materials ( titanium, etc ) for the frame, perhaps magnesium for the wheels and carbon fibre for the shell. Bring money. Whole wheelbarrows full of money. Before you do all that you'd do well to run some honest numbers of what it's possible to save in fuel costs and vehicle costs, then compare it to what is already commercially available. Come back and tell us how many miles you will have to tow to reach the pay off point.
Interesting discussion. Would certainly make a real conversation camper around the campground. Who's gonna step up and do it ! ???
I still say a teardrop camper may make the most overall sense from a towing standpoint when it comes to dragging something down the road with a very small tow vehicle. Whether you actually want to camp in it becomes a personal decision. I met a couple in Texas last March that were traveling with a teardrop behind their Land Cruiser suv/wagon. The little camper was "well used".....and they told me they loved it.
12-08-2012, 06:30 PM
#60
Trailer: In the market
Originally Posted by Frederick L. Simson
Well, by definition I am not a hypermiler, but I can certainly appreciate the concept of efficiency. Generally I take a pragmatic approach to most things:
Improving MPG:
- I don't turn off mp the engine at red lights, depending how long the light is, it may take more fuel to do this. And then there's the added stress to the starter - cars aren't really designed for this.
- I don't purposely antagonize other drivers to influence their driving: sounds like a recipe for road rage
- in California (where I live) it is almost unsafe to drive below 55mph. But I don't go much over 60 when cruising.
- I have a standard trans and I do have the habit of coasting wherever safe and appropriate (this does a great deal to improve MPG).
- I do have a ScanGauge that helps me learn the big gas wasting tendencies (pretty much all hard accelerations and hills!!)
Lightening a trailer:
I don't really want to give up too much comfort (one of the reasons I like the idea of a trailer is comfort and convenience), but there may be some unneeded or unnecessary things:
- I don't think I need a TV when I have an IPad (works great for watching movies while traveling)
- I'm not sure if I need a full stove when there are many self contained lightweight camping stove on the market (there are even some ovens!)
- I'm not sure a microwave would be needed, generally works fast but I'm not crazy about what it does to food!
- a jug of water seems to be plenty for two people over a couple of days (handy wipes are great as well!)
- bedding: I have a really nice set of lightweight down sleeping bags that zip together if needed (really warm and cozy!)
The things I like about a small stand-up trailer:
- a comfortable bed!!!!!
- a place with a table to eat, play games, check maps, read, watch movies, etc.
- an enclosed place to cook (even if its cold and raining).
- almost no set-up time, it's ready to go immediately (makes those spontaneous weekend trips even more enticing!!)
- you can leave the gear in the trailer all the time (again, ready to go at the drop of a hat!)
- it is safe (or feels that way)
- it is quiet (more so than a tent anyway)
- it is private
One of the reasons I want a trailer is so that I can have a good "home base" for my cycling events, without needing to pay for a hotel every time I leave my neighborhood. I'm an ultra distance cyclist and most of my events are all day events, so having a "sanctuary" waiting for me after a long hard day on the bike seems very appealing! Sometimes (most of the times) it's difficult to really rest in a tent, and then there is all the time required to set up and take down. Even a teardrop seems inconvenient for cooking or changing clothes (essential for my needs!)
Hope this clears a few things up (at least in terms of needs)...
