Lights - Fiberglass RV
Old 12-05-2005, 03:56 PM   #1
Pat And Arleen's Avatar
Trailer: Bigfoot 2500 Series (25C9.6E 'Yeti')
Send a message via Yahoo to Pat And Arleen
In the last trailer we had we tryed some LED lights they worked OK but not to good to read by. So in our new StarPad we put in some new CCFL lights. WOW a real nice white light and now we can read inside all nite and not drain down the batt. They are easy to install and wire in and they draw about 1/4 the power. I have but in 3 at the cost of about $30.00 total. Each Light is about 1/4" X 12" come with P/S switch, run on 12VDC current draw is about 5.0mA and have a lifetime of about 30K hours with a brightness of 30K cd/m2.
Pic of one over table.
Pat And Arleen is offline   Reply With Quote
Old 12-05-2005, 04:46 PM   #2
Pat & Arleen,
Maybe my search is at an end!. Good, inexpensive, yet bright enough reading light. Is it possible that these can be dimmed?
Where might these be purchased?
As someone once said, "inquiring minds want to know"!
Thanks for the picture showing both lamps, good comparison.
Kurt & Ann k.
Old 12-05-2005, 05:10 PM   #3
Bill Abbay's Avatar
Trailer: 2002 21.5 ft Bigfoot / 2003 Chevy Duramax 4x4
Hi, Pat & Arleen,
If you bought these on-line, would you post the URL?
Do you use these in tandem with your incandescents or instead of?
A standard 12 fixture uses about 1500 ma.
Wow
Bill Abbay is offline   Reply With Quote
Old 12-05-2005, 06:04 PM   #4
Ronny W's Avatar
Trailer: 77 Scamp 13 ft
The CCFL lights are used often for lighting pc cases for doing computer mods. I would think any large computer store would cary them and many online stores. Here is coolerguys website they have always been good to me http://www.coolerguys.com/840556012009.html they do require being pluged into a transformer but they also make short wire extensions from transformer to bulb.
I was going to try and use a couple in the cupbord and closet. Should work realy well.
I was thinking the only down side other than the wires from the transformer being relatively short is they take a fiew minutes to warm up and get brite but they do work well.
Ronny W is offline   Reply With Quote
Old 12-05-2005, 06:22 PM   #5
Byron Kinnaman's Avatar
I'm sure about this one. I don't see an input voltage specification. It does state "transformer". Transformers don't work on DC voltages.
Old 12-05-2005, 07:01 PM   #6
The link below is the place I ordered from
http://www.allelectronics.com/cgi-bin/cate...0100&type=store
I also ordered some red ones for under the trailer th light up the ground by the door.
They are bright and run cool when on.
Old 12-05-2005, 07:34 PM   #7
Ronny W's Avatar
well you got me Byron
The site calls them a power inverter not a transformer.... sorry But i do know they work off 12v dc
Old 12-05-2005, 08:42 PM   #8
No problem. I'm pretty sure they ment inverter. But I have seen sites that have either a 12VDC or a 24VDC inverter. That site doesn't which it is.
I think you ment toe "The site calls the a transformer not a power inverter"
I guess I'm one that wants to make sure I understand what I'm buying. Maybe it's engineer in me tries to read and understand specifications. I hate getting stuff that aint what I thought it was. I've done that enough, both with my stuff and professionally.
Thanks for the link though.
Old 12-05-2005, 11:13 PM   #9
Mike Taylor's Avatar
Trailer: Hunter Compact II
I bought 2 pair of these lights earlier this year and installed them in my Compact II. One pair is over the kitchen and other pair is over the table. Another big advantage of these ccfl lights is there is little radio interference with them on compared to a regular flouresent light. Mike
Mike Taylor is offline   Reply With Quote
Old 12-09-2005, 08:13 PM   #10
Trailer: 2003 Casita 17 ft Spirit Deluxe and 1989 Bigfoot 5th Wheel
Talking
This came from the web site
Specifications:
# Dimensions: 300mm x 4mm
# Tube Voltage: 620V .74 Amps (8.88 watts)
# Avg Brightness: 29000 cd/m2
# Very, Very Bright
# Average life: 30,000 hrs
# Dual sealed transformers
Review: Cluboverclocker.com
I was wondering about where the current draw was measured?
At the bulb or at the feed of the transformer.
Harv in Colo.
Harvey Craft is offline   Reply With Quote
Old 12-09-2005, 11:13 PM   #11
The current draw had to be measured at the 12 VDC input. Power in Watts = Volts x Current. 12 x .74 = 8.88. The 8.88 Watts includes the inverter.
lighting, lights
LED lights Francine P Problem Solving | Owners Helping Owners 12 04-03-2009 09:29 PM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 11:54 PM
led lights Pat C Problem Solving | Owners Helping Owners 2 07-16-2008 11:22 AM
LED Lights Dave Mac Problem Solving | Owners Helping Owners 9 07-24-2007 04:44 PM
NEW LED LIGHTS!! Christi V. Modifications, Alterations and Updates 12 05-10-2007 09:10 PM
