Lil Bigfoot Floor Replacement - Fiberglass RV
Old 11-30-2010, 10:27 AM   #1
Trailer: Bigfoot 13.5 ft
I am just about ready to install a new subfloor in my 1987 Lil Bigfoot. After adhering the bottom fiberglass pan to the bottom of the subfloor using thickened epoxy, I will will glassing the entire top surface of the floor to the sides of the trailer using 7 1/2 oz. E-glass cloth with epoxy resin. How many layers of this cloth will be sufficient?
Thanks,
Carl
Carl G is offline   Reply With Quote
Old 11-30-2010, 07:31 PM   #2
Matt in SV's Avatar
I don't know but I did some reading. I found these threads were interesting. I still don't know and can't confirm that it's even necessary to fiberglass the top surface. It seems it would depend on your intended use and where you live.. or play! Some people have epoxied it and others have used marine grade plywood and not worried further.
Regards,
Matt
Rotten subfloor
Sealing/Repairing Underside of Floor
Types of Wood Flooring for a Trailer | eHow.co.uk
WISA Plywood and Veneer - Advanced high-strength solution for trailer flooring
Trailer Boats Bulletin Boards: Marine grade vs treated plywood
Planning our next Escape!
bigfoot
Floor Replacement Lil Bigfoot Carl G Care and Feeding of Molded Fiberglass Trailers 11 03-07-2014 03:25 PM
Bigfoot floor replacement SandraD Problem Solving | Owners Helping Owners 14 03-07-2014 03:09 PM
Lil Bigfoot so far... Mike Whitney Modifications, Alterations and Updates 9 09-26-2010 09:10 PM
Lil Bigfoot Floor Replacement Carl G Problem Solving | Owners Helping Owners 2 05-09-2010 08:43 AM
floor replacement ralph s Problem Solving | Owners Helping Owners 2 07-25-2008 11:47 PM
