LIL Snoozy Fresh water tank gauge - Fiberglass RV
Old 09-19-2014, 01:05 PM   #1
charlsara's Avatar
Trailer: 2014 Lil Snoozy
I drilled 1.5 inch holes in the trim panel in front of the fresh water tank, which is located under the couch. I added a trim panel for looks. Now you can see at a glance how much water is left in the tank.
Old 09-22-2014, 07:21 AM   #2
greg489's Avatar
Trailer: Just looking
NC
Nice idea Charlie!
greg489 is offline   Reply With Quote
Old 09-22-2014, 07:34 AM   #3
Smile
I kinda did the same thing on the tank itself with 1/4" holes. That way I could tell how much water was in the tank by which hole the water was coming out of. LOLOLOL
Old 09-22-2014, 06:09 PM   #4
charlsara's Avatar
Thanks Greg,
A slot would be better but it would be hard to rout without taking out the panel. I slid a thin piece of plywood between the panel and the tank to prevent drilling into the tank.
Old 09-23-2014, 06:25 AM   #5
greg489's Avatar
NC
...or removing the tank, which would be a pain. Either way it is effective and looks professionally done. We have elected to leave off the fresh water tank on our build and utilize the space for storage drawers. In all our years of camping up and down the east coast we have never needed a fresh water tank. Most of our favorite campgrounds are all electric/sewer/water. We usually take along enough bottled drinking water to cover our long weekend trips. If we find we need it down the road it can always be added. I remember you being a pretty tall fellow. How's the shower fit for you? Just curious.
Old 09-23-2014, 07:41 AM   #6
charlsara's Avatar
I have used it one time. I wouldn't say it was comfortable but I can manage. We will use campground showers whenever possible but it is nice to have the option.
Old 09-23-2014, 08:03 AM   #7
greg489's Avatar
NC
I agree. I'm around 6' - 210lbs. I tried it out for fit and would do better sitting on cassette while showering, but I agree, it is nice to have when no other option is available.
Maybe Richard could incorporate your water gauge slot idea into the campers when customers want the FW tank. Would be fairly easy to cut in the slot before the tank is installed.
Old 09-23-2014, 11:10 AM   #8
Very well done Charlie. As someone who does use the water tank in their trailer a lot I love this idea.
If you find you have trouble seeing the water line, at one of the fiberglass trailer meets someone had done something similar on a Scamp - but they added a small LED light into the hatch behind the tank so when they turned the light on via a small outside switch, they could see the water level in the tank a bit more clearly.
Old 09-23-2014, 07:46 PM   #9
peterh's Avatar
Nice job. I like the viewing ports.
I did something similar with our Scamp 5er.
It's part of the U-Shaped Dinette project I did a few years ago. The post showing how it works is here: Converting dinette into a "U" with more accessible storage.
Old 09-23-2014, 09:13 PM   #10
charlsara's Avatar
I like that Peter. I went with the portholes to keep from having to disassemble the couch and related. The light is a good idea but so far I can see good without one. I enjoyed reading about your Scamp upgrades.
Old 09-23-2014, 09:18 PM   #11
charlsara's Avatar
Greg, one of the other things I did was make a platform for the bath to get the floor closer to the toilet. It can be removed when using the shower. At least one LS owner has done something similar.Click image for larger version
Name:	ImageUploadedByFiberglass RV1411528682.163551.jpg
Old 09-23-2014, 10:48 PM   #12
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
[QUOTE=greg489;484129]I agree. I'm around 6' - 210lbs. I tried it out for fit and would do better sitting on cassette while showering, but I agree, it is nice to have when no other option is available.
I couldn't see paying the extra $500.00 for the Theadford cassette toilet, because it is essentially the same as the standard Theadford portable toilet (empties the same way). I always remove the toilet (very easy) prior to showering, as it gives a lot of room to be able to turn around, bend over, etc.
With all the problems Theadford has had with the "blue" hose bursting, I'm glad I did not go that route.
Dave & Paula
Old 09-24-2014, 07:41 AM   #13
greg489's Avatar
NC
Hey Dave, we also use the portable battery flush model in our popup and like it too. I've considered what you did to save money. The only problem would be not including it with the sale of the popup. Most see it and would want it to stay. Certainly something I'm considering.
Charlie ~ I like the platform. We must be a lot a like. Always coming up with improvements.
Old 09-24-2014, 09:47 AM   #14
David B.'s Avatar
Trailer: Lil Snoozy
Greg, if I'm not mistaken, the portable toilet (hand pump, not electric flush) comes as standard equipment in the Lil Snoozy, and the cassette toilet is a $500.00 option.
Dave & Paula
lil snoozy
Propane Tank Level Gauge -- Anyone know of a good one? camping_mama Modifications, Alterations and Updates 51 04-21-2014 07:41 PM
Advise about grey water tank on Lil Snoozy Melanie B in NC Plumbing | Systems and Fixtures 64 04-12-2014 02:39 PM
For Sale: stabilizers(2),fiberglass propane tank/gauge kit-$225 cpaharley2008 Parts: Buy | Sell | Trade 6 09-30-2012 04:11 AM
Auxiliary Fresh Water Tank, Transferring Water Adrian W General Chat 0 09-05-2010 02:36 PM
Trouble adding water to a fresh water tank Dan Tracy Problem Solving | Owners Helping Owners 1 05-05-2008 08:11 PM
