Looking for photos of 3-way fridge install - Fiberglass RV
Old 01-07-2019, 04:55 PM   #1
Bryan L.'s Avatar
Trailer: 1991 Scamp 16 ft
I am currently adding a 3-way fridge to my 16’ Scamp. I have the electricity and gas ready to go. I was hoping to get some pictures of two things:
1. How is the interface between the rear refrigerator cabinet (chute from fridge to exterior vents) and the inside surface of the outer shell accomplished? How is this made so that gas fumes don't leak into the under-cabinet area?
2. How does the gas line and electric line get in through the rear cabinet so that it's also air tight. I'm guessing a hole and copious amounts of caulk?
Hoping someone has access to take a couple of pictures. Thank you!
"The babbling that I brook." - Pink Floyd
1991 Scamp 16'
Bryan L. is offline   Reply With Quote
Old 01-09-2019, 09:54 PM   #2
Bryan L.'s Avatar
So, no one has a three-way fridge installed in a Scamp? Maybe I need to move this to General Chat for more views...
1991 Scamp 16'
Old 01-09-2019, 10:36 PM   #3
It does not need to be a specific make or model of FGRV to give you the type of products and general installation advice for them. No doubt it will take a combination of the suggestions below to get the job done.
To keep the air from the backside of the fridge from getting into the cabin
You can use good quality caulking that remains flexible to seal small gaps. Choose a color that is close to that of your finished cabinets.
For larger gaps you can use closed cell foam weather stripping products. Those are available in rolls with adhesive backing from hardware stores. That type of product comes in different thickness and widths as well as different densities.
Spray foam of course does work but tends to be very messy and you don't want to get it onto the finish on your cabinets.
In some visible areas you may want to add wood trim pieces, stained and finished to match your cabinets, to close up larger gaps then caulk to fully seal the join.
Old 01-10-2019, 07:26 AM   #4
I read the original post but which fridge and Scamp model was not listed. I suspect mine is different.
Side or roof exhaust vent? Which Scamp layout? You asked about a 3-way but I only have a two way (on starboard side with roof vent). But since your questions only deal with the gas use, a 3, 2 or even one way absorption fridge install what we are talking about, but the cabinet and vent arrangement will vary.
You should not have any gas (propane) fumes leaking anywhere. But perhaps you meant combustion exhaust fumes. The thing is that from what I have seen, Scamp fails to do a good job in making sure that the combustion exhaust fumes are always properly channeled. So I would suggest that you do not blindly follow their lead but instead start with it and see where it can be improved. You also get a a better chance at this stage to look at insulating the box better than Scamp does, and make provisions for assisted airflow with small fan(s). In addition to the installation manual (which you should study closely) I found these resources:
https://www.thetford.com/wp-content/...ion-Manual.pdf
https://www.caravansplus.com.au/pdf/...on%20V%205.pdf
The gas line pass through is nothing fancy.. through a fiberglass sheet and caulked.
fridge
Can a 2-way fridge become a 3-way fridge? Rob Carmody Problem Solving | Owners Helping Owners 13 06-24-2016 10:54 AM
3-Way Fridge vs AC DC Fridge? Krista Modifications, Alterations and Updates 44 04-14-2016 06:34 PM
7 way plug to 4 way plug back to 7 way plug immrbill Problem Solving | Owners Helping Owners 3 08-10-2015 11:08 AM
2 way compressor fridge vs 3 way propane aimeelightsey General Chat 9 05-20-2011 05:56 PM
Cool Way to Quickly Resize Photos Greg A Forum Admin, News & Announcements 19 03-05-2009 11:44 AM
