06-07-2014, 01:04 PM
Glade Valley, North Carolina
Man Storage on carrier
Well I finally finished my new storage and carrier Mod. I had been using a couple of plastic storage bins and I would store them in the camper before traveling and after set up I would transfer them to the back of my truck. I took a regular carrier and added rails around and custom fit the rails around the spare tire. I then purchased a water proof lockable truck storage box from Tractor Supply. I mounted the box to the carrier with bolts. I then added new LED trailer lights (Due to the box blocked my rear lights), mounting them flush inside the edge of the carrier. I then wired a new trailer plug by hooking into the wiring under the carpet at the inside rear of the camper. That took the most time because I had to use a wire tester and go back and forth from the truck to the inside wiring to find the correct wire for the brakes, signals and running lights. After hooking up the trailer plug I wired the carrier lights to plug into the camper trailer plug. If you notice I had to mount the box higher in the rack due to my 2" receiver I welded on the carrier. That receiver holds my aluminum fishing cart and carrier when I head to the beach. Wheeeeea! So, now I can leave all my outside man stuff in the carrier and I don't have to transfer it back and forth.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
06-07-2014, 01:37 PM
Trailer: Prius camping - want an Oliver
Virginia
Thank goodness! I thought you had a man in that box!
I don't get lost, I go on interesting side trips.
06-07-2014, 01:38 PM
Trailer: Class A Motorhome
And next, are you going to add a 13' Scamp to your train for a man cave ???
06-07-2014, 02:08 PM
Now, how are you going to remove the spare tire if you get a flat?
I have a cross-style lug wrench and found that I couldn't turn it without hitting the box on the back of my trailer.
I since removed the u-bolts that held the box to the rack and use a cable lock and ratchet strap to secure it. That way, I don't have to empty the box and remove the u-bolts to remove the box to access the spare.
06-07-2014, 03:49 PM
13 Scamp for a man cave. Now Bob there's an idea. LOL Already thought about the spare tire access Glenn. I have it bolted with two bolts. One on each side. If I do get a flat. It would take me less than 5 minutes to unbolt and remove the box.
06-07-2014, 04:53 PM
New Jersey
Looks nice Ted! Now do you get much sway with a trunk out back on a 5th wheel then say a trailer like mine?
I'm not missing mine so much now! Got it off Craigslist for $200! I added a pair of locking handles on the rear and 2 new 3rd brakelight bulbs...so the misc camping stuff is going in there and my generator while I'm driving...so if I pull in late at a truckstop I don't have to climb over it anymore!
deryk
06-07-2014, 09:33 PM
No sway at all. Of course If I loaded it down with a lot of weight it might be different. I keep all the stuff I need for outside work, tools etc. It will be nice to not have to load and unload my stuff now.
07-15-2014, 08:34 PM
I contacted my local decal shop this morning and got him to make me a scamp decal to fit into the tractor supply sign on my box. I took out the tractor supply and added my new Scamp decal.
07-15-2014, 09:04 PM
New Jersey
Looks great!
deryk
07-16-2014, 05:52 AM
That looks great Ted! It looks like you thought of everything. When I saw the TSC label in the first picture, I was thinking it would look better without it. Changing it to read "Scamp" looks much better. I think the box would come in handy to secure stuff that might take a walk when you're out and about biking, canoeing, hiking, etc. It's also a good place to store cooking items that don't need refrigeration while gone or at night away from the raccoon sized critters. Nice!
Tom
07-16-2014, 12:47 PM
Looks like it may obscure your license plate, not good.
Jim
Never in doubt, often wrong
08-17-2014, 06:12 PM
License Plate Replacement
You know that's why I like this site. As Jim pointed out my license plate was hidden by my storage box. So, we are leaving to go gold mining/camping on Tuesday and I remounted my plate today so it was once again visible. Thanks Jim for the notice.
08-17-2014, 06:20 PM
You also need a light on the license plate so that it is visible at night, can you run a wire from the tail light over and attach a small bulb or just do not drive at night….
Jim
08-17-2014, 06:24 PM
I can see it all the way here in Illinois, Ted! Good job.
Tom
08-17-2014, 06:29 PM
I was searching in Amazon for license plate frames for our trailer and came across one that featured LED lights that lit the plate for night driving. I think it used AA batteries. Or... you could just show the officer your own L.E.O. ID and keep on truckin' .
Tom
08-17-2014, 07:24 PM
Yea I was thinking about the plate light. But decided to pass for now. I have never heard of anyone being stopped for no license plate light. At least not in N.C. If I ever get stopped for that; I will then add one.
08-17-2014, 09:26 PM
Trailer: 1985 Uhaul CT
I was once given a ticket because one of two lights were burned out on my plate :-(
08-17-2014, 10:25 PM
Wow, I guess were more laid back in N.C. Was that in Texas?
Maybe I will install one when I return from my trip this week.
08-17-2014, 10:29 PM
I solved the problem on my trailer by using LED License Plate Bolts. Simple taped into the rear lights for the power. You can buy them at most Motorcycle or ATV shops.
08-17-2014, 10:49 PM
Maybe I will get one of theses for the Scamp license plate light.
