Maxx Fan Installation on curved roof - Fiberglass RV
Old 03-07-2015, 12:00 PM   #1
scf
Trailer: 98 Scamp 16
Wondered if anyone has had experience in installing a Maxx Fan on a slightly curved roof and whether or not a tapered shim is required to flush fit the flange. I have a '98 Scamp 16' and am in the process of installing a Maxx Fan in front of stock original escape hatch. There is a slight curve side to side from the roof line center to the outside edge of the mounting flange (approx 1/4" drop from center to outside). I was hoping that between a little flex in the roof flange mount and butyl tape along with rv sealant would take up the variation. Any thoughts or experience with this out there?
Thanks,
Steve
scf is offline   Reply With Quote
Old 03-07-2015, 09:21 PM   #2
scf
hmmm... looks like a non-issue. Cut hole today and both the roof and the mounting flange flex a bit so there should be no problem with the mounting flange sealing flush against the roof. So I guess I answered my own question!
Steve
Old 03-07-2015, 09:23 PM   #3
Well Steve, you made it easy for us. Best of luck and maybe you can post some pics when you're done and let us know if you run into any issues?
Old 03-08-2015, 03:24 PM   #4
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
YES, I changed out the stock exhaust fan with a MAXX FAN. To compensate for the curved roof, I made a hardwood frame, with curved undersides front and back, and straight at the sides. It is about a half inch thick at the center.
The frame is screwed to the roof from below. Calking bead between and along the outer edges on top. That keeps the Maxx Fan frame from being distorted. I see you went ahead without a frame. Good Luck!
WC
Thanks,
Steve
Installing Maxx Air Fan Mate 850 Vent Cover Over Fantastic Fan CampyTime Modifications, Alterations and Updates 7 10-10-2013 10:43 AM
best technique for air flow with Maxx Air Fan with 13 footer lloyd cicetti General Chat 4 06-18-2010 05:04 PM
What if I ran my Maxx Air Fan for 7 hrs off my Rv battery? lloyd cicetti General Chat 7 06-17-2010 01:08 AM
Scamp (curved) front & rear window seal, Help Eddie Longest Problem Solving | Owners Helping Owners 4 02-03-2010 09:57 AM
