Minor Egg Camper mod...no photo - Fiberglass RV
Old 08-14-2011, 05:42 PM   #1
Trailer: 2015 Escape
After travelling over 2000 miles to and around Montana, I got tired of our clothing boxes (both smooth plastic) sliding up to the toilet/shower. I bought a shower curtain compression rod, put a closet pole bracket on the wood storage doors opposite each other and put the rod in them. The rod alone didn't always work hence the pole brackets. Installation about two minutes if I don't count the time spent buying the rod, buying the brackets, and getting my tool box out. First long trip with the Egg Camper and we love it.
Old 08-15-2011, 04:53 AM   #2
Ron F's Avatar
Trailer: Eggless for now.
Formerly NH, now full timing
Please sir, can we have a photo?
I have an expansion rod that I use to keep my under-bed modification in place when we travel, but it doesn't always hold. I'd love to see the bracket mod.
Here's my mod. Each drawer rolls out on wheels (from Rockler) and is set up to hold 2 plastic tubs. The latch handles at the top aren't sufficient to hold the weight of the drawers over bumpy roads.
Ron
Old 08-15-2011, 05:44 AM   #3
honda03842's Avatar
Name: Norm and Ginny
We have made similar modifications to most of our trailers, slide out drawers under the bed capable of holding plastic bins.
To keep the drawers locked we use locking slides similar to those used for most motorhome drawers. These drawer slides require to the drawers to be lifted about a 1/4 inch before they will roll.
Norm
Norm
Old 08-15-2011, 03:07 PM   #4
james kent's Avatar
Trailer: Boler 1984
I see a carpet seam just in front of the drawer faces. How about a piece of seam moulding that the drawers would have to be lifted over to pull out?
Old 08-15-2011, 03:29 PM   #5
honda03842's Avatar
O rings
One approach we used on a fridge not meant for travel was to mount an eye hook on a frame above the fridge door and a screw in the door below it. Between them we had a two inch rubber o-ring (available at must stores in the plumbing section).
You may be able to just wrap it around your latch.
Norm
Old 08-18-2011, 12:30 PM   #6
Trailer: 21' Escape - former owner of 17' "other brand."
Would this work? Often on sale for under $10. I find one of these very valuable for use in my pickup truck. I don't see why it wouldn't work in your EggCamper. Cargo Holding Bar
Old 08-18-2011, 02:22 PM   #7
cpaharley2008's Avatar
I think the above item is too long, I tried to use the one I have, but you can make your own. I bought a plastic closet kit @ HD, 2 sticky plastic ends one open and one closed and cut a wooden closet rod to fit, slip one end the closed and it drops in the other end.
Old 08-21-2011, 08:08 PM   #8
My guess also is that it would be two long. Actual distance where I have it is just a tad over 36 inches. The curtain tension rod that I used is less than that and extends far more than I need. Works great and cost under $7.00 at Walmart.
Old 09-22-2012, 12:04 PM   #9
Trailer: eggcamper
South Dakota
simple solution to boxes sliding forward - chocks
We have an EggCamper, and store some plastic rolling drawers and a big plastic box under the bed, all of which would love to slide forward when we come to a stop. We have 2 yellow chocks which we put by the wheels to keep the egg stable when in a campground. The perfect storage place for them when we're on the move is shoved under the box and the forward set of drawers which keeps them happily in place.
Judy K is offline   Reply With Quote
Old 09-23-2012, 07:06 AM   #10
Judy, I love that idea. My tension rod worked very well but it won't hold at the length I need any more. Holds fine in lengths that are too long for the space.
Old 09-24-2012, 05:29 AM   #11
Bonnie and Claude's Avatar
Name: Bonnie and Claude
Trailer: N/A
Originally Posted by Judy K View Post
...We have 2 yellow chocks... The perfect storage place for them when we're on the move is shoved under the box and the forward set of drawers which keeps them happily in place.
Sounds like a great idea. I tried the tension (shower curtain) bar but was afraid to make it too tight and damage the paint so it fell down in transit. Was thinking of putting a piece of rubber matting under the bins but we already have the wheel chocks.
Bonnie and Claude is offline   Reply With Quote
Old 09-24-2012, 05:45 AM   #12
Ron F's Avatar
Although the photos above don't show it, here's how I hold things together on the road:
I didn't use a "spring-loaded" shower curtain rod. Instead, I used a rod that is lengthened by twisting the two sections to the correct length ( Amazon.com: Carnation Home Fashions Adjustable 41-to-76-Inch Steel Shower Curtain Tension Rod, White: Home & Kitchen ). I attached closet pole sockets ( ULTRA 69000 Hi-Im. ABS Plastic Closet Pole Socket, 1 Pair ) to the sides. The sockets keep the pole in place when travelling. It it holds things in very well.
Old 09-24-2012, 06:52 AM   #13
Trailer: N/A
Thanks, Ron. I'll check locally for those closet pole sockets.
Old 09-24-2012, 07:04 AM   #14
I use the closet pole sockets with the tension. The sockets I have are attached with one screw through the center of the socket. They rotate part of the time and when the one with the opening turns, the rod drops out. Probably be a good idea to anchor the one having the opening with a second screw. Otherwise, the idea works very well.
eggcamper
Scamp 5er Hitch Mod w/Photo Link Taylor Kissinger Towing, Hitching, Axles and Running Gear 32 10-29-2016 06:08 AM
My first mod to our new Egg Camper rgrugg Modifications, Alterations and Updates 6 05-30-2011 02:44 PM
SOLD-2006 EGG CAMPER EGG CAMPER Pat B Ohio Classified Archives 9 01-18-2009 08:43 PM
Mod to an Element not a camper Paula Bindrich General Chat 10 02-15-2008 07:25 PM
