I saw this little guy (Not so little, not so big) on eBay and thought.. "Thats about the perfect size for the Burro". (OK, I have a Goldilocks sydrome)
It's a SlantFin K-25 air cooler.. in most circles known as.. a swamp cooler.
The size is ideal, it's 19 inches wide and about 9 deep, maybe 10 tall. Runs on 120v (50w) and weighs 14 lbs. Invertor use will have to be well thought out.
I have avoided getting an air conditioner because I rarely have a need for one, but they are nice to have, admittedly. This one does not weigh in at a bizzilion lbs, and requires no installation. It will run for 20 hours on one tank of water. I have plopped it full of ice cubes and ice water and am basquing in it's coolness by my couch now. Seems to work well. If I get about 10 feet away from it, it is ineffective, but the
Burro coach is only 10 feet, so it should do well.
Haven't quite decided how to stow it. Will probably go under the bed and get set in front of the closet when needed.
I need to clean the outside. Oddly, the inside was scrubbed and is imaculate, but he neglected to wipe down the outside
Gonna go try it in there now. It's still record heat here.
