more mods - Page 2 - Fiberglass RV
Old 05-26-2003, 07:35 PM   #21
mini table
The rest of my table scraps are used up now....the little dinette table was cut down to a 16"x20" mini table. The hub was mounted off center (like me) so the table can be rotated for diferent uses. The floor socket came from the local RV shop and was easily holesawed into the floor. This is the day table/large nite stand mode.
Old 05-26-2003, 07:38 PM   #22
Here is food prep mode. with the top twisted it will clear the drawer. Note the larger radiused galley shelf by the stove cut from big table scraps. I used the old shelf for a drawer counter.
Old 05-26-2003, 07:40 PM   #23
This is rotated to dinette/computer desk mode.
Old 05-26-2003, 07:45 PM   #24
The table is stored under the bedboard and can be partially slid out to offer a small nite stand or dinette end table.
Old 05-26-2003, 07:49 PM   #25
These metal shelf channels are stick-taped to the bedboard and rubber lined to make a snug friction fit. The battery disconnect is wired in line to the battery hot lead from the converter.
Old 05-26-2003, 08:04 PM   #26
Hi Phil
There you go again.Now I got to play catch up.Oh well I got another old Boler to play with now.
Good Job.
Old 05-26-2003, 08:21 PM   #27
Yes!! Perhaps a small 13 ft guest chalet to go with your 17???
pix please.........
boys toys!!!!! oh boy!!!!
here is the enlarged folding galley shelf left over from a corner of the big table. I shot this pic straight on so Charles could see I ten-ringed the outlet hole:o :o
<img src=http://www.fiberglassrv.com/board/uploads/3ed2cc72b2d19galley counter folded.jpg/>
Jana- the carpet is glued to a rubber backing so I set it in front of the door for a bath mat when showering.....and throw it back in after squeegee- ing the bath.
Old 05-26-2003, 08:35 PM   #28
Hi Phill
This is what I got to work with.The fun begins.
<img src=http://www.fiberglassrv.com/board/uploads/3ed2ce513d844before1.jpg/>
<img src=http://www.fiberglassrv.com/board/uploads/3ed2ce62b71c5before2.jpg/>
<img src=http://www.fiberglassrv.com/board/uploads/3ed2ce73e85d2before3.jpg/>
<img src=http://www.fiberglassrv.com/board/uploads/3ed2ce8600f56before4.jpg/>
Ok Phil.What do I do.Make it a sleeping only unit or a unit for two with permanent bed and table at opposite end.
Old 05-26-2003, 08:55 PM   #29
My opinion? well........Is it a 13 footer??
back end: I see a U-shaped dinette/bed with a just small removable center section at the footwell required for conversion. Upholster it plush and you dont need a mattress. A one-post table will be easy to stash.
At the front, a 2 seat couch with removable back that might accomodate a smaller sleeper. Full length stand up closet in the front corner by the stove. Another thought- take out the front bench and build side-facing single seats at a 2-person dinette. Maybe a porta-potty under the seat by the stove like Ken showed us earlier or is that a bath beside the door???
Old 05-26-2003, 08:58 PM   #30
Hi Phil
13ft---Thats what I had in mind.A permaite big bed with 2 people dinett.No Bath.
Old 05-27-2003, 08:05 AM   #31
That stove top - :omy - it has front knobs :reye2 I thought those only came on ovens. Attention all who care. cook tops do have front knobs, TOO.
Old 05-27-2003, 08:11 AM   #32
Stove top
Orginally posted by Thomas and Janifer
Very astute Janifer! That's a good looking unit, too.
Old 05-28-2003, 07:37 AM   #33
Phil >> ten ringed the hole
My apologies, Phil. I should've figured you measured twice and (hole)cut once.
And I also should have figured that if the hole was off-center, you'd buy another piece of wood and try again ... otherwise it would keep you up at night! :)
Old 05-28-2003, 11:04 AM   #34
No apologies needed Charles.....I know you are ribbing me over my compulsiveness. If I am going to post this stuff I have to be willing to take the heat!!!!! Besides, my piddling pales in comparison to the full-on restoration jobs that some of our associates are performing.
Didja see the Libertyesque mini-table I came up with???? That one is a benchmark. Slideouts may be a stretch, but don't be suprised if you see a tandem axle Casita sometime.:r
Mods Harry Berry Modifications, Alterations and Updates 8 07-25-2007 09:58 AM
Anyone want more mods to do? Lainey Modifications, Alterations and Updates 0 06-22-2007 07:35 AM
Pop-top mods DonInChatt Problem Solving | Owners Helping Owners 12 02-21-2007 12:31 PM
outside mods james kent Modifications, Alterations and Updates 3 04-19-2006 09:57 AM
Bed Mods Legacy Posts Modifications, Alterations and Updates 16 03-13-2003 10:13 PM
