more mods - Fiberglass RV
Old 05-23-2003, 02:57 PM   #1
more mods
window tint for summer.
<img src=http://www.fiberglassrv.com/board/uploads/3ece8b026b4afwindow tint.jpg/>
Old 05-23-2003, 03:00 PM   #2
bath mat
Some scraps left over from the carpet job make a nice bath mat- they are glued to a piece of 1/8" neoprene.
<img src=http://www.fiberglassrv.com/board/uploads/3ece8bbba6e62bath mat.jpg/>
Old 05-23-2003, 03:13 PM   #3
battery monitor
This is a prototype battery monitor (no affiliation)that a developer sent me for a road test- it reads voltage, per cent charge, and keeps track of low cycles. An LED will blink when the battery hits 55% capacity letting you know that it's ready for a charge. If the voltage drops below 50%, (low cycle) the LED remains on and the cycle entered into memory. It pulls only 28mA so I cut the plug off and hardwired it straight to the hot side of the battery. Now I can disconect the battery when hooked to shore power (always at home), run off the converter and let the battery rest. When I need a charge just close the disconnect and the converter will fill up the tank.
<img src=http://www.fiberglassrv.com/board/uploads/3ece8ec5bfb19battery monitor.jpg/>
Old 05-23-2003, 03:15 PM   #4
table clips
no more wobbly table. Casita sent me the clips used on the TV shelf. Seems to me that these should have been there to start with!
<img src=http://www.fiberglassrv.com/board/uploads/3ece8f630a048dinette table clips.jpg/>
Old 05-23-2003, 03:20 PM   #5
dinette table
Another recycle job. The large table left over from the bedboard project was trimmed down to make a 3 inch oversized small dinette table. The extra length makes quite a difference.
<img src=http://www.fiberglassrv.com/board/uploads/3ece9059c199edinette table extended.jpg/>
Old 05-23-2003, 03:22 PM   #6
cup holders
There was room for some big cup holders from a surplus yard.
<img src=http://www.fiberglassrv.com/board/uploads/3ece90fa487c1cup holder.jpg/>
Old 05-23-2003, 05:25 PM   #7
Come on Phill
I want to go out camping. We all can't keep up with all these mods.
:laugh :laugh :laugh
Old 05-24-2003, 10:06 AM   #8
Impressive Phil! Everything looks so nice and is so functional in your trailer. I really like the battery level indicator, too.
Nancy
Old 05-24-2003, 11:07 PM   #9
Scamp 5th wheel
Thanks Nancy- it's fun to come up with cheap ideas for raw materials on hand. Now there is a considerable piece of big table left over plus the original 2x2 small dinette table. They might be cut to make a permanent counter for the galley (to replace the folder shown) and maybe a slide out coffee table from under the bed.
I sure am looking forward to the rally and seeing a Scamp 5th wheel up close......leery of the old two-foot-itis syndrome though:o
<img src=http://www.fiberglassrv.com/board/uploads/3ed04eb7b5343counter dropped.jpg/>
Old 05-25-2003, 06:17 AM   #10
Aha! The hole for access to the electrical plug in the folding counter top appears to be off center!
See, see? That's why I leave my trailers stock ... factory fresh. I mean, I know all of you admire and are jealous of all Phil's wonderful modifications ... but an off-center electrical plug access hole?
Besides, doing all those modifications seem like work ... at least to me. ;)
(And Phil, you know I'm joking. You set the high-water mark for modifications!)
(If you get twofootitus, just figure out a way to modify your existing rig, adding two feet off the front or back. I have faith in you!)
Old 05-25-2003, 08:28 AM   #11
Prediction
Phil will be the first to add a two foot slide-out to his small, molded fiberglass travel trailer.
Seriously, with all of the amazing work some of our members accomplish, this idea is not far-fetched...
In fact, Janifer might beat Phil to it!
:cblob
Old 05-25-2003, 09:12 AM   #12
My latest idea
Hey, I might even put a trunk on mine! It'd look like the rear engine comparment for the old VW bus.
Seriously: I took the spare tire off the back and I leave the back dinette made up like a bed all the time, so I am thinking about installing a rear access door and have a closed in space under the bed. Although the door would be permanent, the 'trunk' could be removed if I ever wanted to use the four person dinette.
Old 05-25-2003, 12:26 PM   #13
VW rear hatch
Hey Suz,
I have a couple spare hatches if you ever need one ;)
Old 05-25-2003, 12:30 PM   #14
rear hatches
Cool!
On second thought, I think I need a miniature rear hatch.
Mods Harry Berry Modifications, Alterations and Updates 8 07-25-2007 09:58 AM
Anyone want more mods to do? Lainey Modifications, Alterations and Updates 0 06-22-2007 07:35 AM
Pop-top mods DonInChatt Problem Solving | Owners Helping Owners 12 02-21-2007 11:31 AM
outside mods james kent Modifications, Alterations and Updates 3 04-19-2006 09:57 AM
Bed Mods Legacy Posts Modifications, Alterations and Updates 16 03-13-2003 09:13 PM
