More mods: a/c window install, microwave shelf - Fiberglass RV
Old 09-05-2010, 08:05 PM   #1
Vickie B.'s Avatar
Trailer: 1988 Perris Pacer ('Bean') / 2004 Element
Air conditioner install consists of 3 pieces. Shelf rests on window ledge (routed out a little channel to sit on the ridge of the window), 2 little hinged feet rest on belly band of Perris Pacer, 3rd piece of wood goes inside camper and is bolted to outside piece, making it nice and stable. So far, duct tape seals the openings. Can't find something we like that works better.
(Holes are for drainage.}
Vickie B. is offline   Reply With Quote
Old 09-05-2010, 08:13 PM   #2
Vickie B.'s Avatar
Microwave shelf is just board (wraped in vinyl) with hinged leg. Leg fits between couch cushions. Edge of shelf rests on edge of cabinet by the burners. I drilled a hole in the corner of the shelf and in the fiberglass counter, and just drop a bolt thru the holes to secure it. It needs another hole/bolt on the other edge of the shelf, or I may go to velcro.
Old 09-08-2010, 03:05 AM   #3
Trailer: Uhaul CT-13
Ohio
You bought the same micro that I just picked up ($39 at Wallyworld?) I am going to do a similar AC install next spring using an of the shelf window AC bracket.
Panoz77 is offline   Reply With Quote
Old 09-11-2010, 06:33 PM   #4
Trailer: 76 13 ft Scamp (fits in my Garage...Yeah)
do you have a bigger picture is that the front or back of your rig
is your window plexiglass how did you cut it?
how do you have the wiring on the inside
looks great
jimtesla is offline   Reply With Quote
Old 09-11-2010, 09:01 PM   #5
Vickie B.'s Avatar
Thanks Jim!
Believe it or not---the a/c is in the side window---that's the beauty of a Perris Pacer---it has that BIG side window, and we simply opened it! Slid the glass and the screen to the right and had a nice big opening for the unit.
And then the a/c is just plugged in the outlet on the side of the kitchen counter.
Old 09-11-2010, 09:23 PM   #6
very nice
microwave
Boler front window rock guard install RogerH Problem Solving | Owners Helping Owners 15 01-29-2024 11:37 AM
Yet another Scamp window A/C closet install. Allen Howell Modifications, Alterations and Updates 6 08-23-2014 05:39 PM
Shelf under front window Joy A Modifications, Alterations and Updates 13 11-21-2009 09:43 AM
Budget rear window a/c install Phil Underwood Modifications, Alterations and Updates 7 10-10-2007 07:09 AM
front and rear window install JIMZ Problem Solving | Owners Helping Owners 1 04-19-2006 08:02 AM
