More Updates! - Fiberglass RV
Old 09-11-2009, 04:40 PM   #1
April Wilcox's Avatar
Trailer: 13 ft Scamp 1983
So with all this rain we've been having, I have been working on fixing up a few mods on the inside of our trailer. I have added a front bunk flip up "table" top and a flip up counter top:
also covered the not so nice carpeting with some of that roll out plastic runner,
that I plan to cover with a 2x3 oriental style rug, for comfort.
I wanted a surface I could easily clean, and the carpet adds to the insulation so I didn't want to remove it. I figured this would be an easy solution, that can be easily removed if needed.
next in line is the upper cabinet and awning installation... come on sunny weather!!
April Wilcox is offline   Reply With Quote
Old 09-12-2009, 07:29 PM   #2
Trailer: U-Haul CT13 ('Pearl')
SW Ohio
Go Girl! I just started on Pearl and plan to add 3 tables like yours.
Pat B Ohio is offline   Reply With Quote
Old 09-14-2009, 07:59 PM   #3
Whew! I got the second set of LED brake lights installed today, glued them in the bottom corners of the back window (on the inside). Connected the wiring, and changed the 4 prong pigtail to a 5 prong so we can make the running lights work. Steadily moving along! I just love our trailer, still don't have a name for her yet. I'm sure that will come in good time.
Old 09-14-2009, 08:56 PM   #4
Don N's Avatar
Trailer: 1989 Bigfoot 17'
April, where did you get the single support arm for the counter extension. The ones I had were too strong for the extension and wouldn't work.
Don N is offline   Reply With Quote
Old 09-15-2009, 08:46 PM   #5
There are actually 2 supports under the counter extension, I guess only one is visible in the photo. I found them on line after googling "folding shelf bracket" and hitting the shopping feature.
We installed the awning rail and awning today I hope we can keep this momentum up! Next is the upper cabinets
Old 09-16-2009, 11:49 AM   #6
Got the screen room basically fitted around the new awning this morning. Seems to work well, not bad for $9.99 + shipping!! I am using the discounted ez up screen that I found on line last year, a portion has been removed to make what was my old screen door, till the zipper broke, then I used more of the excess screen to fill in the panels of the new screen door.
Old 09-17-2009, 02:08 PM   #7
Attachment 23405
Attachment 23406
Attachment 23408
April, love what you are doing and the pop-up tables are a great idea. I too have put the plastic down and it works great. We call our little trailer Lucky as we were very lucky to find it and bought it from and man named Lucky.
karen lm is offline   Reply With Quote
Old 09-17-2009, 04:38 PM   #8
We got one of the two upper cabinets installed today
Bit by bit, we're moving right along...
Old 09-17-2009, 07:53 PM   #9
CliveAlive's Avatar
Trailer: Boler American #3104
Nice work!
What size awning is that? A 7' ?
Old 09-17-2009, 08:39 PM   #10
Thanks!
Yes, it's a 7' Trimline, and I sure am glad I didn't go for the 8', it would have been way too long. Our awning rail sticks up about 3" on both ends, due to the curve of the body.
Old 10-27-2009, 01:55 PM   #11
We got the upper dinette cabinets installed!
Old 10-27-2009, 02:05 PM   #12
Next we have started the prep for the 2 way fan install.
So far, I have measured 14in from the existing vent, then traced the square using the inside of the insert, cut the ensolite with a sharp blade, and peeled it back. I plan to save it for any patch work we might need to do in the future.
Before we cut the hole, we plan to get the wood for the spacer, build it and seal it up with fiberglass resin. We want to have everything ready to install before we make any cuts. I will post photos as we get more work done.
Old 10-28-2009, 11:57 AM   #13
Last night I added a small shelf with a suspended wire basket that slides in and out, which is held in place with a strong magnet (the basket not the shelf), and a paper towel holder on the right of the upper cabinet . Also put in this little wire, catch all shelf on the side of the closet, above the bed/dinette. Little by little... we are still working on getting the parts together to build the spacer for the 2 way fan.
Old 11-09-2009, 01:37 PM   #14
We got the 2 way, variable speed roof fan installed and it works great! I had to use my cell phone to get the pictures, so they are a little blurry.
and to top things off, our 3 way norcold 1.7 cu fridge showed up tonight! I know what we are doing this week.
Recent Updates for the EggCamper Ron F Modifications, Alterations and Updates 27 07-29-2012 06:18 PM
New updates on our Project 19 bill&sandra Modifications, Alterations and Updates 4 03-20-2010 12:23 PM
Mods & Updates on the Horizon Tim Wood Modifications, Alterations and Updates 13 07-18-2009 05:45 AM
Updates and Cool Things Nancy in Oregon Rallies, Get-togethers, Molded Meets (Archive) 11 04-24-2006 07:03 PM
Some inside updates james kent Modifications, Alterations and Updates 7 04-21-2006 04:43 PM
