Mount for 1 gal propane tank - Page 2 - Fiberglass RV
Old 07-17-2015, 02:57 PM   #15
2.6 gallon LP Tanks
[QUOTE=The Minimalist;535310]The 11 pounders,2.6 gal, are $56.97 through Home Depot with store delivery.
I paid $73.85, tax included for a new 2.5 gallon shorty tank, that included purging and first time filling.
For those that don't know, there is a purging process that has to be followed with new tanks, otherwise you will never get them properly filled.
Local LP outlet charges $10 to purge a new tank. <40 lbs.
Also, when swapping tanks there is a good chance, unless you have two tanks and run them dry every time, that you will be giving them back LP in your tank.
Speaking of LP Stations.... In Prescott, AZ, the COSTCO store has an LP filling station, only one I have seen in a COSTCO, super cheap as well
Old 07-17-2015, 03:27 PM   #16
The Minimalist's Avatar
Louisiana
Watched them purge and fill the first time. No charge for the purge. Some do, some don't.
Clif
Old 07-17-2015, 10:25 PM   #17
Louisiana
WDavidG: More to the point, you have a very clean installation. Have you put lock nuts on the turnbuckles? Be careful about quick release. There may be others who would want to use your feature too.
Clif
Old 07-17-2015, 11:33 PM   #18
I've never heard of propane tanks being referred to in gallons only by weight.
Old 07-18-2015, 12:21 AM   #19
Borrego Dave's Avatar
Trailer: Casita SD17 2006
A newer valved 20Lb tank holds less than 5 gallons because of safety concerns. I was told they only can be filled to around 80% now. I've heard them referred too by either name forever. When you have them filled it shows the gallons, not the pounds. No matter what you want to call it, I don't want to run out....I like cold beer
Old 07-18-2015, 06:32 AM   #20
LP Tanks
In the U.S. you almost always buy LP by the gallon, hence the common interchange of the two measurements.
Old 07-18-2015, 07:22 AM   #21
Thanks guy's just the difference between Canada & the USA I guess.
I was confused when I started reading the thread the one gallon for me is really a five pound tank.
Old 07-18-2015, 08:10 AM   #22
Briantb's Avatar
Trailer: 2015 Scamp 13 Front Washroom, Van Camper
New Brunswick
Ah but the tare weight will be in kg in Canada
Sent from my XT1028 using Fiberglass RV mobile app
Briantb is offline   Reply With Quote
Old 07-18-2015, 08:53 AM   #23
I'm old but use both, its the young today that can't convert so they are very metric.
Old 07-18-2015, 09:04 AM   #24
Trailer: 2014 13' Scamp -standard w/ front bunk
Vermont
I too find the nomenclature confusing - particularly since neither the stated poundage nor the volume is in fact accurate.
And, Clif, definite yes on the lock nuts. Good point on not making it too easy!
WDavidG is offline   Reply With Quote
propane
Scamp GREY Tank - NOT 26 GAL! Darral T. Plumbing | Systems and Fixtures 53 04-29-2015 10:48 PM
replacing the 10 gal water tank with something smaller chse Modifications, Alterations and Updates 13 10-21-2012 07:42 PM
12 gal H2O tank removal in Burro? Armymomma Problem Solving | Owners Helping Owners 4 03-05-2012 05:58 PM
Propane tank / Battery mount Trillium 4500 1978 Gumpit Modifications, Alterations and Updates 14 11-20-2010 09:15 AM
Hott Rod install in Atwood 6 Gal Water Heater Michael Pupeza Modifications, Alterations and Updates 3 04-27-2009 09:14 AM
