Mounting a spare tire - Fiberglass RV
Old 05-05-2017, 07:38 PM   #1
Trailer: compact jr
Hey all. I am thinking about adding a spare tire mount on my compact junior. I saw this which would go in the back https://www.harborfreight.com/traile...ier-93341.html but was also thinking a U bolt in the front under where the propane goes. Which I currently do not use and have completely off. I have heard the front of the trailers is the weakest point though in terms of the frame. Thoughts? Thanks!
raddar is offline   Reply With Quote
Old 05-06-2017, 02:20 AM   #2
Borrego Dave's Avatar
If you're not using the LP tank, the weight of the tire should probably be less than the tank. The A frame will be fine.
Old 05-06-2017, 09:08 AM   #3
Trailer: Compact Junior
I just lay my spare flat on the front.....
and secure it with web straps. and keep it covered at home from the sun.
I, too, removed the propane tanks.
john madill is offline   Reply With Quote
Old 05-06-2017, 10:08 AM   #4
Trailer: compact jr
John, did you mount it under or to the side?
Old 05-06-2017, 03:08 PM   #5
Just sitting on top....
Of the vee shaped part of the tongue, laying flat.
Old 05-06-2017, 07:54 PM   #6
Jay H's Avatar
Trailer: Boler 1300
I used the same carrier as is in your link last summer on my Boler. I had it on the tongue with the battery and the propane tank. It was just fine for towing although I did scuff the tire cover coming out of a steep gas station. I found that with all three items on the tongue the trailer was awkward to move about in the campsite. Without a propane tank on the tongue I think you would be fine to put your tire up front, however you mount it.
I did move mine to the back this spring.
Jay H is offline   Reply With Quote
Spare Tire Mounting for Lil Snoozy JBB Problem Solving | Owners Helping Owners 10 12-04-2016 06:01 AM
Spare Tire Mounting jack smith Problem Solving | Owners Helping Owners 12 03-17-2013 07:19 PM
Trillium 4500 spare tire mounting Joe Loiacono Problem Solving | Owners Helping Owners 4 07-20-2007 09:36 PM
Spare Tire Rack Legacy Posts Problem Solving | Owners Helping Owners 20 07-01-2003 10:41 AM
Spare Tire Rack Legacy Posts Modifications, Alterations and Updates 5 05-15-2003 07:39 AM
