Mounting an Outside Shelf - Page 2 - Fiberglass RV
Old 10-09-2015, 11:21 AM   #15
We use a folding camp table much like this one.
http://www.amazon.com/Outsunny-Alumi...+table+outdoor
While not what you asked for we find it much more useful and easy to pack.
We had a pop up trailer for a while that had an outside rail and you could remove the cook top and mount it outside.
We added a 120 volt outlet outside by the door and we could use electric appliances out on the table without cluttering up the trailer. Our 13 foot Scamp counter space can get cluttered up real quick if you don't expand outside a little.
Old 10-09-2015, 11:24 AM   #16
Originally Posted by Larry C Hanson View Post
...I have considered an outside table too.
Here is hardware to mount o the side of the rig.
You would have to rig up a stout leg?...
The leg would probably need to be adjustable, since the terrain around the trailer may not be perfectly flat.
Old 10-09-2015, 11:29 AM   #17
Trailer: 2016 -13' Scamp
Massachusetts
Joy, that's the look, yes. I found an aluminum Z channel that would work well for mounting a small table.
By the way, is your PVC black tank hose mounted down on your tow bar in the photo?
[QUOTE=Joy A;552799]I have a table that I mount to the outside. I had my welder add a 1" interior square tubing (receiver) to the frame. Then had him make a 1" exterior bar ...
herons is offline   Reply With Quote
Old 10-09-2015, 11:44 AM   #18
There is also a kit (or separate parts) available from RV supply sources that is used to mount dinette tables. It has a male/female channel system for the wall side, and an adjustable leg for supporting the other end.
Here's what the wall part look like: https://www.google.com/search?q=rv+t...O5Nj6fVfr2M%3D
Here's one that will fit your 2" receiver
And there's another idea, it's detachable I think:
Old 10-09-2015, 12:22 PM   #19
Trailer: 2008 17 ft Casita Spirit Deluxe/'78 Trillium 1300
Arkansas
Roselyn, I immediately thought of that table when I read the title! I also think there are several posts on here by folks who have duplicated it. That's what I'd do.
Ruth C. is offline   Reply With Quote
Old 10-09-2015, 12:27 PM   #20
David Tilston's Avatar
I have issues with perforating the fibreglass shell, so I really like this idea:
Wheel Well Table
Old 10-09-2015, 12:30 PM   #21
Patrick Metals Table Support 30" 499 2 Pcs 2 164922 | eBay
Old 10-09-2015, 12:32 PM   #22
Wheel Well Table
Only issue I have with that is it is a pain to move the table into the sun for morning coffee and to move it into the shade in the hot afternoon.
Old 10-09-2015, 02:36 PM   #23
light duty....
not going to barbque on this....just a little table to hold/keep whatever small items in one place at the campsite...and out of the rain if it happens...dead simple... using what was already there
Old 10-09-2015, 04:46 PM   #24
james kent's Avatar
Trailer: Boler 1984
Name:	ImageUploadedByFiberglass RV1444430324.398904.jpg
A rail on the outside of your trailer allows you to mount your table there. A boon when on the road. At a roadside stop just mount the table, pull out the cooler and sandwiches are a snap. Reload two items back into the trailer and you're back on your journey. In camp you don't have to use some grungy, crap covered table left in deplorable condition by the last user.
Old 10-10-2015, 11:44 PM   #25
Joy A's Avatar
[QUOTE=herons;552942]Joy, that's the look, yes. I found an aluminum Z channel that would work well for mounting a small table.
By the way, is your PVC black tank hose mounted down on your tow bar in the photo?QUOTE]
Peg, you threw me for a bit....I went "what PVC black tank hose". I didn't realize it showed in that photo. But Yes it is, actually it's for my gray water. In fact, that was a second holder which had an extension in it. The picture was taken some 14 years ago. I now have a box I built on the tongue for the generator and propane tank. Both the original sewer hose holder and the extension are mounted on both sides of the tongue under the overhang of the box painted black. Thank goodness for hose clamps, actual I think these large ones were for Dryer hoses.
Joy A. & Lily
and "Puff", too
No. Ca. Sierra Foothills
Old 10-10-2015, 11:48 PM   #26
Joy A's Avatar
The use of the back receiver is a great idea but the bike is there. So my side table works great. Plus it's under the awning if it ever decided to rain again here in CA.
Joy A. & Lily
and "Puff", too
Old 10-11-2015, 02:24 AM   #27
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Come on El Nino!!!!!!!!!!!!!
Borrego Dave is online now   Reply With Quote
Old 01-19-2016, 02:33 AM   #28
Trailer: Scamp 16ft
Alabama
I mounted a 2in. Receiver for a 4wheeler on the corner of bumper using a bolt it will swivel to side or to back that I have a BBQ for "tailgating" in no holes in fiberglass.
I'm late in throwing in my .5 cent.
Darrell in Al is offline   Reply With Quote
Permanently mounting a microwave in a trailer RosemaryBurrows Problem Solving | Owners Helping Owners 12 04-08-2006 08:16 PM
Mounting an Awning on a Burro (double shell) S Sato Modifications, Alterations and Updates 17 03-05-2006 07:16 PM
Mounting propane tank Legacy Posts Problem Solving | Owners Helping Owners 7 07-13-2003 03:23 PM
Mounting air conditioner Legacy Posts Problem Solving | Owners Helping Owners 9 04-16-2003 10:47 AM
Permanently mounting a microwave in a trailer General Chat 0 12-31-1969 07:00 PM
