Mounting Solar Panels to Roof ? - Fiberglass RV
Old 06-29-2008, 08:43 AM   #1
Trailer: 2006 (25B21RB) 21 ft Bigfoot / Dodge 2500 Diesel
I am looking for a secure method of mounting two 24 x 50 inch solar panels to the roof of my Bigfoot travel trailer.
Basically, I want it to look good, not cause a leak and not blow off while traveling.
What have you seen work or fail? Thanks, Dean
Dean & Mary is offline   Reply With Quote
Old 06-29-2008, 10:29 AM   #2
peterh's Avatar
I discarded the old frame for my 13x48 inch solar panel and built a new frame out of weather-resistant composite trim lumber that conformed to the shape of my trailer's roof. I made cardboard templates to test-fit the ribs before cutting the more expensive lumber, put a small radius on the downside edges to eliminate a sharp-edge stress point on the roof, assembled my new frame without the solar panel in it, test fit it again and drew the rib layout on the roof with a Sharpie, drilled holes through, re-assembled the frame with the panel in it doped the underside of the ribs with marine caulk and mounted it using stainless steel screws from the inside of the trailer. There's a topic showing how I did it.
Old 06-29-2008, 11:07 AM   #3
[quote]I discarded the old frame for my 13x48 inch solar panel and built a new frame out of weather-resistant composite trim lumber that conformed to the shape of my trailer's roof. I made cardboard templates to test-fit the ribs before cutting the more expensive lumber, put a small radius on the downside edges to eliminate a sharp-edge stress point on the roof, assembled my new frame without the solar panel in it, test fit it again and drew the rib layout on the roof with a Sharpie, drilled holes through, re-assembled the frame with the panel in it doped the underside of the ribs with marine caulk and mounted it using stainless steel screws from the inside of the trailer. There's a topic showing how I did it.
Attachment 14158
Peter,
You might want to re-think your mounting method. PV panels should have free air flow underneath to carry away excess heat. If it's as it appears, your method seals the area under the panel. That will significantly shorten the life of the panel.
Morgan is offline   Reply With Quote
Old 06-29-2008, 12:16 PM   #4
peterh's Avatar
Peter,
The side rails of the panel frame don't actually touch the trailer roof and sides, so as long as they don't get clogged with debris there should be circulation underneath, but thanks for mentioning that.
Old 06-29-2008, 01:04 PM   #5
brian m.'s Avatar
Trailer: 17 ft Casita Spirit Deluxe
See if this link gives you any ideas:
http://www.casitaclub.com/forums/index.php...+panel+mounting
He used 3M brand VHB tape to mount his panel permanently to the roof of his Casita.
brian
2003 Casita SD 17'
http://www.coolcampcreations.com/
brian m. is offline   Reply With Quote
Old 06-29-2008, 02:25 PM   #6
Trailer: 1970 Campster
If you google "solar panel mounts" you will find a variety of products and resources that will inform and assist you in your quest.
Good luck!
Lisa H. is offline   Reply With Quote
Old 06-29-2008, 03:53 PM   #7
A thanks for the quick reply’s & please keep them coming.
I have the mounts/brackets that came with the kit. Using those brackets I will have the recommended 2 inch spacing underneath each panel. Right now I plan on using 6 brackets for each panel.
The main question is how to attach the bracket to the fiberglass. Brain, I found the link to the Casita forum very useful - thanks. Basically, he just used “3M 4941 1/2"X36 YD VHB TAPE for $53.00 from Uline” and it is working. I am not that trusting of just tape over the long haul. I could use tape on all 6 mounts, but just drill the 4 corners? Probably a good compromise. If I drill a hole for a screw, what product is good for sealing the entry point?
Old 06-29-2008, 06:17 PM   #8
Lyle Brunson's Avatar
Trailer: Scamp 2008 Custom Deluxe 19 ft 5th Wheel
The West Marine catalog has a solar panel mounting kit that employs Sikaflex 252 adhesive.
A flexible single part adhesive like that might be better than through fastening in terms of leak resistence. I'd think you'd want to test it though, to make sure you had confidence in it in that application, but it should glue just about anything to ...well...just about anything.
Lyle Brunson is offline   Reply With Quote
Old 06-29-2008, 09:24 PM   #9
I found the Sikafex 252 adhesive here http://www.westmarine.com/webapp/wcs/store...;classNum=10890
Looks like it will hold up to moisture very well since it can be used below water line.
However, the following was listed as part of its specification:
Material Incompatibilities: Acrylic plastics (ABS, Lexan)
Old 07-01-2008, 08:21 AM   #10
Here is the link for the suggested 3M 4941 VHB Acrylic Foam Tape: Click here!
This looks like a great product. I will order the tape and then decide how many screws if any are needed. I just don’t like the idea of drilling holes in the roof nor do I like the idea of having the panels blow off because I didn’t use screws.
Old 06-28-2016, 06:09 AM   #11
Trailer: 2008 OutBack 13ft., Camp Inn 560
Illinois
Solar panel mounting
For those of you that are mounting your panels on the roof with tape.
What are you doing for the connection wire?
Drilling a hole seams to be the only option without a vent to run it through.
What you you using to seal the hole after running the wire, just sealing with sealant or using some type of compression connection.
I have a 2008 Out Back (Trillium). The roof is sloped to the back and not sure if I need to get the panel perfectly level or is it okay to go with the slope?
I was thinking about using the "sticky feet" but there is not enough adjustment on the back feet if I need to get the panel flat.
Any thought?
David O. is offline   Reply With Quote
Old 06-28-2016, 09:45 AM   #12
The Minimalist's Avatar
Louisiana
David, you might try one of the through hull marine 'cable clam' fittings as shown here:
https://www.amazon.com/s/ref=nb_sb_n...k%3Acable+clam
I used the first one shown and filled it with sealer. It works fine and mine is mounted on the top where it begins to turn down to the front of the trailer. In that position, if it were to leak, rain would be driven in while driving. It doesn't.
I also like the looks of the SeaChoice thru hull fitting about half way down the page, but you would have to go through the hull in a location where the inner part would not be visible. With the side entry cable clam, I turned the cable at a sharp right angle where it entered and ran it behind the rat fur.
Clif
solar, solar panel
Adding Solar Panels Bigfoot Mike Problem Solving | Owners Helping Owners 50 09-25-2009 08:59 PM
Chinese Solar Panels Lisa H. Care and Feeding of Molded Fiberglass Trailers 10 05-31-2009 12:05 AM
Solar Charger and Panels Frederick L. Simson Modifications, Alterations and Updates 109 08-11-2008 10:41 PM
Solar Panels Barbara Gardin Electrical | Charging, Systems, Solar and Generators 7 06-02-2007 09:30 PM
Solar Panels Legacy Posts Electrical | Charging, Systems, Solar and Generators 13 04-24-2003 09:09 AM
