Mounting things on roof w/o drilling a hole - Page 2 - Fiberglass RV
Old 10-12-2012, 09:17 AM   #15
Trailer: Born Free Fiberglass
By sanding..
I mean to "ruff up" the slick finish of the gel coat.
What VHB tape did you use? Whats the best?
I know some one that is going to refinish his MH using that Red Maxx stuf.
stev is offline   Reply With Quote
Old 10-12-2012, 09:19 AM   #16
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by stev View Post
Great idea Tom... thanks..
Would you "sand" some of the gel coat before?
Would sanding make for a better bond or not?
Once the VHB tape is stuck down... say in the years to come,
can it ever be removed from my fiberglass roof?
Like with a solvent or anything?
Or using a razor blade to remove?
I'd follow 3M's directions to the letter. My inclination would be to have the surface extremely clean and oil free, but not sanded.
I believe that the tape can be removed with mono filament line, using it to cut the tape. Application of heat would probably help, too.
http://solutions.3mindia.co.in/3MCon...bute=ImageFile
Old 10-13-2012, 05:12 AM   #17
Trailer: 2000 Scamp 13, 72 Alpine Sprite
Alabama
have a look at eternabond double sided tape. It's good stuff! I used the single sided eternabond tape to seal holes in the roof of an aluminum roof camper Im restoring and it worked like a charm. It's very strong.
bicklebok is offline   Reply With Quote
Old 10-17-2012, 08:01 AM   #18
Again thanks.
I was in Lowes.
They sell elevator bolts.
But were only in that black steel
I would imagine SS or plated would be better.
Old 10-17-2012, 12:09 PM   #19
honda03842's Avatar
Name: Norm and Ginny
Update on VHB Tape mounted Solar Panels
I was out looking at the roof and took the following picture to show what more than a year on the roof looks like. The panels have been thru 3-4 sand storms, 2 hail storms, 2 snow falls, Yuma sun, and and a loop of the USA.
They seem well attached to the roof of our Scamp 16, no difference since the first day they were attached.
Also the thru hull boat fitting used for the wires has never leaked.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 10-20-2012, 10:08 AM   #20
Paul Chet's Avatar
Trailer: Vixen Motor Coach
H Norm,
Thats a very nice, low-profile set up you have there! I am going to be mounting my new solar set up exactly as you have - VHB for the panel and just one hole through the roof for the wiring ...
Would you mind posting a link to the thru hull fitting you used and if you would recommend a different one in hindsight or are happy with what you used?
Thanks a bunch!
-Paul C
Paul Chet is offline   Reply With Quote
Old 10-20-2012, 10:31 AM   #21
honda03842's Avatar
Thru Fitting
Paul, Very happy with the fitting.
I used the RA140 shown on the following link.
Glomex - The best in Marine Antennas - GAMMA PRODOTTI
I drilled a pilot hole followed by a larger drill for the center cable hole.
I filled the RA140 with Lexal to seal it. I then drilled 3 pilot holes for stainless screws, filled the holes with more Lexal and screwed the into a Lexal bath, wiping it clean afterward.
I had 2-40 watt panels. If I were doing it over I would use a single panel. Incased the panel wires in split corrogated cable cover available at Walmarts.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 10-20-2012, 10:50 AM   #22
So where did you buy it at?
I see the link is in Italy.
Is there another brand available more locally?
Also. what is Lexal?
Googled it/ no luck.
What about a "cableclam"? For the wire.
Amazon has for sale.
Old 10-20-2012, 11:05 AM   #23
Paul Chet's Avatar
Thank you kindly Norm and for posting that detailed shot. Again a really smooth looking job on your part.
Steve - you can select English language on the Italian link but I also just googled "Glomex RA 140" and got several options here in the states. Buying mine today!
Thanks again for the help
Old 10-20-2012, 11:52 AM   #24
Paul... I am still fumbling around trying to find.
Could you please provide with a link on where you are going to buy.
Thanks.
Old 10-20-2012, 12:07 PM   #25
honda03842's Avatar
The caulking compound is 'Lexel' not Lexal, my mis-spelling. I use it to hold replacement caps on. It will not stick to Silicone and is supposed to be better.
When putting the caps on I had to remove the silicone the previous owner had used and did not work very well.
Sorry for the error. You cam buy it on Amazon, Home Depot and some hardware stores. It comes in white and clear. I use the clear.
My connector was a gift from a boat installer.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 10-20-2012, 12:21 PM   #26
Paul Chet's Avatar
Steve try here - both options are about the same price:
Glomex Wire Cover Feed-Thru
Old 10-21-2012, 01:59 PM   #27
Thanks... I ended up buying one on ebay.
If you want will let you know when I get it.
Mounting Solar Panels to Roof ? Dean & Mary Modifications, Alterations and Updates 11 06-28-2016 09:45 AM
drilling into fiberglass Diane G. Modifications, Alterations and Updates 11 07-22-2012 07:07 PM
Drilling into Fiberglass with a hole saw. WARNING freddo411 Problem Solving | Owners Helping Owners 8 05-05-2012 09:41 PM
Drilling hole in UHaul floor - sealing Thomas G. Modifications, Alterations and Updates 4 12-22-2011 05:21 AM
Large hole in roof trailerlust Problem Solving | Owners Helping Owners 15 12-15-2011 08:29 PM
