Moving Fresh Water Tank to Outside of 16' Scamp - Page 3 - Fiberglass RV
Old 09-30-2015, 07:05 AM   #29
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
It's pseudo Latin, from the Red Green show, alledgedly meaning "when all else fails, play dead."
Quando omni flunkus, moritati
Old 09-30-2015, 09:40 AM   #30
Trailer:
How could it be pseudo-Latin if it's from the Red Green show? Didn't he invent Latin?
Old 09-30-2015, 11:41 AM   #31
ArneB's Avatar
Trailer: Boler 1975
Email
Steve I'm struggling with the same issues that you are. I removed my tank from under the seat/table area. The tank is in great shape but considering it dates back to 1975 I'm thinking its time to replace it. I do lean towards Ian's setup for many of the reasons discussed here.
The original tank was held tight against the bottom of the trailer with a sheet of 3/4" plywood and fastened with bolts. Seemed to work well.
Name:	ImageUploadedByFiberglass RV1443634578.479138.jpg
The tank I removed is about the same dimension as the one you are considering.
Name:	ImageUploadedByFiberglass RV1443634698.658508.jpg
This is the only wood that held the tank tight against the underside of the Boler.
ArneB is offline   Reply With Quote
Old 09-30-2015, 12:54 PM   #32
Kai in Seattle's Avatar
Hi! Say, thanks! Wasn't far off, just missed the "play" aspect of "moritati." My husband uses this strategy quite a bit...I must seem like a grizzly or something.
Kai in Seattle
Old 10-28-2015, 08:55 AM   #33
Hi Ian,
I'm thinking about doing this. I've got an electric pump and am wondering if on of the outside city water connectors with the back flow valve will work. Will the little pumps have enough suction to open it. It's probably just a metal and spring in there. Kinda like this: Valterra A01-0170LFVP White 2-3/4" Plastic Lead-Free Flange Water Inlet. Thoughts? Thanks, Steve
SteveZimmerman is offline   Reply With Quote
Old 10-28-2015, 09:20 AM   #34
The pump has to draw air then water to prime and run and it doesn't have that kind of capability as does the pressure side. I'd doubt if it could draw enough to overcome what is, basically, a pressure valve.
I used a standard RV drain fitting with a male hose fitting for my external tank./
Old 10-29-2015, 07:23 AM   #35
Thanks Bob. After looking some more at the current set up (diner tore out right now, need to replace floor due to water damage) I believe the pump has a back flow regulator so a drain on the outside like has been suggested should work.
Old 10-29-2015, 09:29 AM   #36
RV water pumps, in a pressurized system, have to have a backflow valve, otherwise they couldn't hold pressure and would run continually.
scamp, vin
Need to know about upgrading Scamp 16 fresh water tank to 20 gallons SharonM Modifications, Alterations and Updates 21 02-25-2013 04:22 AM
Considering moving water tank LauraW Plumbing | Systems and Fixtures 19 04-10-2011 10:21 AM
Auxiliary Fresh Water Tank, Transferring Water Adrian W General Chat 0 09-05-2010 02:36 PM
Moving the Scamp's "kitchen" to the outside, freeing up Tirah Problem Solving | Owners Helping Owners 28 03-18-2009 11:03 AM
Trouble adding water to a fresh water tank Dan Tracy Problem Solving | Owners Helping Owners 1 05-05-2008 08:11 PM
