My 13' Scamp remodel - Page 3 - Fiberglass RV
Old 12-17-2009, 06:45 PM   #29
DannyH's Avatar
Trailer: 1976 Scamp 13 ft "Siesta"
Robert, I've been looking at your cabinet photo's and have a question on your piano hinges. The cabinet over the kitchen looks like the hinge is on the bottom, and the door rests open in the down position. I like this because you don't need anything to keep it open if the hinges were on top. If this is correct on your door, how did you put in your piano hinge to allow full opening of the door. If you install the hinge flush to the bottom of the door, I would think the door would only open 90 degrees before the bottom of the door would bind with the cabinet. You must have something going on that I cant see.
Dan H
DannyH is offline   Reply With Quote
Old 12-17-2009, 09:36 PM   #30
Greg A's Avatar
Trailer: 2015 Escape 19
Was this the same trailer that was just up on eBay?
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 12-17-2009, 10:14 PM   #31
peterh's Avatar
. . . I like this because you don't need anything to keep it open if the hinges were on top. If this is correct on your door, how did you put in your piano hinge to allow full opening of the door . . .
Danny, there are two ways you can top-hinge a door and still have it stay open. One is to buy cabinet hinges that are designed with a "dent" that keeps the door open. (You can find them at Lowes or Home Depot mixed in with their other cabinet hinge offerings.) The other is to make a door support from a cheap spring (also from Lowes or Home Depot) and two small eye hooks, like this:
Old 12-17-2009, 11:36 PM   #32
Robert Johans's Avatar
Trailer: Nest Caravans
Danny,
You have described the mechanics of the hinge correctly— and indeed, I cannot get a full 180° rotation. But I come close enough.
It's kinda hard for me to describe in words, and I hope I got this right, but here goes: the barrel of the hinge is proud of the cabinet face by about 1/8" and the thickness of my cabinet door is 3/8". The difference is 2/8 or 1/4". So my door drops down (and binds) to within 1/4" of the full 180°.
In other words, based upon the height of my 6" doors, and if I've done the math right, my doors swing open about 176°. (Whew! That's more geometry than I've had to pull out of my hat for quite a while!)
Old 12-18-2009, 10:24 AM   #33
DannyH's Avatar
Peter, thanks for the hinge idea. When closing do you have to give the spring a push from the side to close the door, or does pushing down on the door bend the spring enough to close. I found the stamped metal at lowes that you used and plan on useing a combination of roberts holes and your screen idea for the doors. My wife gets bruises so easy that cabinets without hardware in such a small place looks like the way to go.
Robert, thanks for the response. I understand what saying, I'm surprised that the door comes down that much. I did notice that your lower cabinet doors looked slightly pushed out, which must be from your proud 1/8" beyond the face that you explained.
Dan H
Old 12-19-2009, 07:11 AM   #34
I like KISS mods. One of the easiest to solve the problem of keeping cupboard doors in the up position I've seen was done by MichaelT on the CasitaForum. A simple notched piece of wood placed around the hinge. The wood rides inside the cupboard until needed, grabbed and placed... done.
Sorry, ya gotta be a member of CasitaForum to view this topic:
Cabinet Door Lift Mod
Besides being simple, it's free!
Old 12-20-2009, 04:53 PM   #35
peterh's Avatar
To close the door you just kinda "bump" the spring with your thumb and the weight of the door closes it. I used the spring support idea on the original Scamp upper cabinet doors until we replaced them with "dent" types hinges on the new uppers I made last year. They work really well.
We considered having the doors hinge downward, by the way. Having them hinge downward has a couple advantages, like stuff that's fallen forward onto the door while you're towing not coming crashing down when you open the door. On the downside, doors hinged on the bottom tend to be at the perfect height to collide with one's forehead. We chose an upward swing . . .
Good luck with your doors!
Old 12-27-2009, 05:28 PM   #36
Trailer: 1976 Boler 13 ft
Just got back from my first NOG, which commenced at Stub Stewart State Park, Oregon. Had a great time meeting folks from this forum and showing off my work on my Scamp.
I picked up this 1988 this past June. It was in relatively good shape, but I wanted to make it uniquely mine. Here are a few pics of the upgrades and changes I've made. Please feel free to comment or ask questions, if you have any. Cheers!
can you tell me all about the shower? I'm trying to think of an optimal way of doing one that doesnt require 'shore' water. It looks great by the way.Thanks.
cyndi H is offline   Reply With Quote
Old 12-27-2009, 07:18 PM   #37
Lotsa places carry outdoor RV showers. I found mine at a local RV retail store. There are many options online as well.
I installed mine just below my porch light, with all the fittings inside my vertical cabinet. My 6-gallon hot water heater sits below the shower, below the belly band. The entire trailer was re-plumbed with PEX to provide hot and cold water to both the galley sink and the shower.
To answer your specific question, when not "hooked up", water is provided by my on-board 10-gal tank via a Shur-Flo water pump. (FYI: A one-way valve prevents city water pressure from back-filling my tank.) You must have an appropriately strong water pump to deliver enough pressure from the tank to the shower for it to function properly. And obviously, one 10-gal tank will not provide many showers, but as long as you have a ready "refill" source available, much bathing can be had.
Old 01-14-2010, 07:34 PM   #38
Pam Garlow's Avatar
Trailer: U-Haul 1985
EXCELLENT job! My favorite details is one of the littlest and that is the clock on the cabinet door. I assume you just drilled through the door, mounted the clock movement on the back, and the hands/numbers on the front. It's brilliant - I just might do that on mine too!
Old 09-19-2017, 12:22 PM   #39
Wyoming
Perhaps I missed this but how did you do the door? What wood and attachment methods did you use? I am re-doing my 1981 Casita and I LOVE what you did!
Mustang Josi is offline   Reply With Quote
Old 09-19-2017, 12:40 PM   #40
Ice-breaker's Avatar
This is a pretty old thread that you are responding to Josi. The most recent previous post was made in 2010!
Ice-breaker is offline   Reply With Quote
Old 09-19-2017, 12:42 PM   #41
Wyoming
Yeah I'm new to this. I'll keep looking for other door mods. Thanks!
Old 09-19-2017, 12:50 PM   #42
Trailer: Looking for
Fantastc job. I agree lighter wood works best, especially in a small space such as this.
Pocket_jon is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Our 2008 13' Scamp remodel Rachaelholland Modifications, Alterations and Updates 8 06-02-2014 07:48 AM
Remodel vs Original Donna Adams Care and Feeding of Molded Fiberglass Trailers 9 11-02-2009 10:03 PM
Bath Remodel - 19' Scamp Richard W Plumbing | Systems and Fixtures 5 03-22-2008 07:26 PM
Scamp 13 Remodel is now ongoing Gary Carvajal Classified Archives 9 12-24-2006 07:11 AM
75 Boler Remodel Mike Montville General Chat 0 12-31-1969 07:00 PM
