My '74 project - Fiberglass RV
Old 09-03-2014, 06:52 PM   #1
Manitoba
My '74 project
Well I've started tearing into my Boler, with a lot of ideas and no particular plan of attack... I started tackling the saggy door today.
When the Boler first arrived, I drilled several holes in the bottom of the door to drain the water. I was shocked at the volume that came out.
Name:	<a title=Boler teardown 008.JPG Views: 86 Size: 182.6 KB ID: 75842" style="margin: 2px" />Click image for larger version
Name:	Boler teardown 018.JPG
Im going to build an aluminium frame to hold contour and glass it back in, but to do this I had to separate the outer and inner skins. With my dermal and several thin pry bars I accomplished the chore.
I thought I'd share some pics for anyone who has wondered what the inside of one of our doors looks like... after years of water infiltration.
Name:	boler work 027.JPG
ID:	75844Click image for larger version
Name:	boler work 029.JPG
ID:	75845Click image for larger version
Name:	boler work 030.JPG
ID:	75846 this looks like it could be a much larger undertaking than I'd anticipated, but there's a long cold winter ahead that I need to fill with projects
Humpty
Winnipeg
Humpty is offline   Reply With Quote
Old 09-03-2014, 06:54 PM   #2
David Tilston's Avatar
Ummm.... yuck!
Why not use fibreglass inside the door, instead of aluminum. It can be bought in sheets.
At first I thought you were referring to your skin, (dermal) but I think you meant Dremel.
Old 09-03-2014, 09:06 PM   #3
Don't know if you have a plan totally in mind, but I'd suggest you check out terrific write up and pictures by Con ... called the Boler Door Fix in the Document Center here: Fiberglass RV - Document Center - BolerDoorFix
Old 09-03-2014, 09:12 PM   #4
Manitoba
Yes, I meant Dremal. But I'll likely lose many dermal layers during this reno.
I'm not sure what you'd have in mind for using sheet fiberglass, or sheet anything actually? I require building a frame to hold the curve if the door.
Name:   ImageUploadedByFiberglass RV1409800225.167436.jpg
Like this one
I'm open to any ideas if you explain the "sheet" to me though
Thanks
Old 09-03-2014, 09:25 PM   #5
Looks like a fun project!!
I saw a boler that made the frame out of wood, it soaked up the water and made the door weigh a ton.
Nelmes is offline   Reply With Quote
Old 09-03-2014, 10:25 PM   #6
Manitoba
yeah, the entire inside was some kind of parkay/plywood/laminate material. 40 years turned most of it into some kind of compost. the fact that it was solid wood to start with would have made it heavy enough, add to that the moisture and I'm surprized it hadn't torn itself off its hinges.
If I made a new frame out of steel, it probably would end up weighing about the same
Old 07-04-2015, 12:16 AM   #7
Manitoba
The work continues... I spent a great deal of time bending and shaping, and bending some more Click image for larger version
ID:	86130Click image for larger version
but the frame pieces are done and waiting on my welder to put them together.
While I wait on that, I decided to go ahead and address another issue. Where the hinges attach to the body, seems to be an obvious weak area.
Relying on the fiberglass alone to support the door... a point that takes a lot of tourque must be reinforced. I chose to do this by adhering a 55" x 2" band of 1/8" thick aluminum to the inside surface.
I was able to carefully separate the ensolite from the body so it will be hidden when put back together.
Once the adhesive has cured I'll drill out the holes for the hinge bolts.
I'm using PL9000 Heavy Duty construction adhesive,
ID:	86137Click image for larger version
it was one that specifically said it bonds to metal and fiberglass. It has a 72 hour cure period so I clamp it together and wait.
Its my hope/expectation that the aluminum flat will spread the twisting force over the entire length of the hinge side, and give a lot more rigidity. At the very least, I have every confidence that it will prevent the hinges from breaking the delicate shell they were attached to.
Old 07-04-2015, 01:33 PM   #8
Manitoba
... And now to address something that's bothered me since the day I brought this egg home. The wildly mismatched wheel wells. I've not paid much attention to others, but mine appear to have been cut out by someone "eyeballing" now I'm aware some adjustments were considered because the door bottom is lower than the rest of the shell, but that's easily compensated for with a template.
Name:	ImageUploadedByFiberglass RV1436038076.060363.jpg
Name:	ImageUploadedByFiberglass RV1436038096.097767.jpg
The first photo shows my door side template, against the kitchen side wheel.
The second clearly shows the inconsistency between the two sides. 2-5-8" at the greatest.
You may also be able to see that the radius is nowhere near centred .
Humpty
Old 07-07-2015, 11:39 AM   #9
Manitoba
I very recently was lucky enough to pick up an original furnace from a '71. If you've ever wondered what's inside those magic heat makers, I can show you. When I bench tested it, I found it was working but the main burner was "crudded" up with something so began the delicate procedure of opening it up.
ATTACH]86341[/ATTACH]
There was some crispy blockage right inside the main burner
Name:	ImageUploadedByFiberglass RV1436290352.921995.jpg
After I cleaned it out, it fired up beautifully, obviously not reassembled yet but here's what a proper pilot flame and main burner lit look like
Name:	ImageUploadedByFiberglass RV1436290531.204384.jpg
Humpty
Old 08-09-2015, 06:51 PM   #10
Manitoba
Got my door frame back from my welder!
Name:	ImageUploadedByFiberglass RV1439167622.359171.jpg
Here's a photo of it clamped to the exterior for reference
Name:	ImageUploadedByFiberglass RV1439167721.407955.jpg
And the further reinforcement for the hinges
Name:	ImageUploadedByFiberglass RV1439167811.126008.jpg
I'm so looking forward to getting this glassed in and finally having a proper and strong door again.
Humpty
Old 08-09-2015, 08:10 PM   #11
Steve_N_Janna's Avatar
Name: Steve and Janna
Trailer: '02 Scamp 13
Glenn, it looks like you're taking your Boler to a whole new level!
IMHO this is part of the beauty of these old glass trailers; they offer a solid original design that - for better or worse, were built to a price point - but are easily improved upon.
I'll enjoy watching where you take this project (and may well steal some of your ideas!).
Steve
Steve_N_Janna is offline   Reply With Quote
Old 08-22-2015, 12:26 PM   #12
Manitoba
New aluminium frame glued to outer skin
Name:	ImageUploadedByFiberglass RV1440267625.004749.jpg
1" XPS foam board attached for moisture proof core
Name:	ImageUploadedByFiberglass RV1440267804.970656.jpg
Plywood will be glassed in where the handle attaches.
It's pouring rain today so I'll take that as an opportunity to start fiberglassing the interior skin.
Humpty
Old 08-22-2015, 12:40 PM   #13
charlsara's Avatar
Trailer: 2014 Lil Snoozy
Nice metal work !
Old 08-22-2015, 12:47 PM   #14
Manitoba
Thanks, but I can only take credit for figuring out how to do it and bending the radius... I'm very lucky to have a friend capable of welding aluminum who without his help, the whole thing would likely have been held together with duct tape lol
Humpty
Freebee Trails West Campster Project Russ Classified Archives 4 07-06-2009 08:49 PM
Amerigo 1971 Project Robin G Classified Archives 0 06-20-2009 09:05 PM
Split from Fiberglass Trailer Project $800 john flynn General Chat 3 06-02-2009 06:59 PM
Need help with a new Trillium 4500 project Gilles D General Chat 2 04-19-2009 08:37 PM
Super Cute project JenPB Classified Archives 3 03-30-2009 09:15 AM
