My 77 B15 Beachcomber - Page 3 - Fiberglass RV
Old 08-12-2011, 07:05 AM   #29
willisworms's Avatar
Trailer: Beachcomber B15
Kelowna, B.C. Canada
You are really making me envious of your progress! I wish I had time to be tearing into my trailer build. You had asked about the condition of my interior. When I bought it, the trailer had been stored inside and not used for 3 years.I bought it right before winter, and moved it to my storage yard.over the winter the back window leaked a bit and made a mess of the two lower wall panels and the floor at the back.I have gotten as far as removing the front bed/bench,and tearing out the rear table/bed, and the rear of the floor.My plan is for a permanent bed at the back,with storage under. and a small couch/larger kitchen at the front. At this point though, I started a new job in april that has me working 6 days a week! as the new guy,I have to work all the overtime that the senior guys don't want. I have started asking around to see if I could find anyone willing to make the repairs I need so I could use the trailer if I got a weekend off,but have not found anyone yet.
willisworms is offline   Reply With Quote
Old 08-22-2011, 09:07 PM   #30
Trailer: 77 Beachcomber B15
Hi everyone: I'm finally getting around to some updates. I now have my cedar roof support all in and it is pretty solid. I can hang my weight (175 lbs) from the roof vent opening and it supports me well. I have attached a few pics.
I also made a few major decisions, whether right or wrong, I am now committed. I Purchased a new 12 volt DC fridge (with a Danfoss compressor) from Getaway RV in Abbottsford. They were on sale for Half price. I plan to put it between the door and the window on the curbside. It will be raised up so that we will not have to get on our knees to see whats in the fridege. The weight (about 55 lbs.) will be almost directly over the axle. Just a little ahead. This means as some pics show, that I can close in the huge vent holes on the drivers side.
Squidley is offline   Reply With Quote
Old 08-22-2011, 09:14 PM   #31
Rick n's Avatar
Trailer: Beachcomber TM15
Looking good Sid
Can you believe the amount of work it takes
Looks like you're doing a great job too, wait until it's complete you'll have a far superior trailer to anything you can buy today for $20,000 and yours will be custom made, stronger and last way longer for a fraction of the price.
Rick.
Rick n is offline   Reply With Quote
Old 08-22-2011, 09:19 PM   #32
Hi again: I included a couple pics of my TV. You can see why I need to keep the weight down. It's rated to pull up to 2,000 lbs. Rick I almost look at your Bronco with envy.
To follow up my previous post, I plan to move the water tank to just behind the drivers side wheel well. Therefore I have another hole to Fibre Glass in (the water filler spout on the curb side.) This old square egg B15 is getting a lot of patching done. Obviously I will need to sand and paint the whole trailer after all the body work is done. I have read over many of the posts on painting and am looking forward to getting that done so that I can re install all the windows etc. and get it all sealed up before winter.
I'll try to keep my posts more up to date.
Sid
Old 09-28-2011, 08:48 PM   #33
Aug. 28/11
Hi All FG Enthusiasts:
I've been putting in a lot of time on my B15. Sure glad I don't need to do this for a living. To date, I have the framing almost completed. All but the very corners on the upper half. Enough at least so that I can concentrate on painting the outside. Fall with poor weather is approaching rapidley and I need to get everything sealed up to keep the water out. I am attaching a few pics. Will post more shortly.
Old 09-28-2011, 08:57 PM   #34
Oops, I'll try those pics again.
Sorry, now I'mtold there is an internet problem.
I'll shut down and try again. The pics don't want to upload.
Old 09-28-2011, 09:06 PM   #35
Attempt # 3
Old 09-28-2011, 09:32 PM   #36
It was a big job sanding down what I believe was Tremclad RV white. That paint is amazingly hard when you don't want it to be.It was still very shiney, but there were some runs and a lot of pinholes in numerous areas. With all the FG patching/repairs, it needed a whole new paint job. The weather here has been extremely hot (mid thirties) and very low humidity. I tried painting outdoors, but the interlux pre-cote was touch dry in about 20-30 minutes and therefor had a lot of brush marks. I found a large shop to work in for a few days and applied a second pre -kote. Even inside the temp was about 25 degrees C. so it still dried quickly.
I had used about 5-6% y333 brushing liquid as suggested by interlux. The brush marks of course were still evident. My 3rd coat was a 50/50 mix of pre-kote and Brightside.. Then I hoped to finish up with 2 more coats of Brightside. On thr roof I didn't tip with the brush and it seemed to turn out a lot better. I finished 2 more coats of Brightside on the roof. Rather than tipping I rolled about 2-3 sq. ft. and after about 2 minutes went back anf very lightly rolled again and the bubbles seemed to disappear. I also had upped the 333 brushing liquid to about 10%. The roof looked good enough to try this method on the walls. The first coat of Brightside was applied to the sides, but the brush marks were still very obvious. You can't see them on the pics, but they are there. Pics attached.
Sid
Old 09-28-2011, 09:33 PM   #37
Rick n's Avatar
Talking Excellent pictures Sidney and great progress.
Attempt # 3
I see you used my idea of using the gang nail strips, they work pretty good eh?
What's next on your to do list?
Old 09-28-2011, 10:03 PM   #38
These posts are a bit disjointed as I'm trying to catch up re: a couple of hiccups in our time schedule over the last few weeks.
Regarding the unsatisfactory paint job, I called my car painter brother and explained my dilemma. He said "why did you wait so long to call me? Bring the trailer over and we'll see what we can do." On Sept. 18th we took the B15 to Oliver BC. (2 hours away). After 6-7 hours of work with an air driven oscillating sander, the brush marks were gone. My brother then re undercoated and repainted the trailer.
We had to purchase another quart of paint and some Y216 thinner/reducer for spray painting. Because I had already thinned with the 333, the paint was now very slow drying. Repainting took several hours extra time and Harry said he wouldn't use that kind of paint again.
The moral of the story is - If you want a good paint job using interlux Brightside, make sure the conditions are just right. Altogether with reducers, paint and pre-kote, I spent over $400.00 to get a decent paint job. If there were a next time, I would let my brother choose the paint. Probably automotive. The rolling and tipping method is not for me.
I am currently installing the windows, lights etc. I have attached a few pics with the new paint job and with the windows installed.
Sid
Old 10-02-2011, 10:09 PM   #39
Hi All: Does anyone know where I could purchase the plastic strips for the belly band on the B15 Beachcomber?? The strips that I removed are not in the best shape. I find that there is lots of 3/4 in. available, but the correct width is 5/8 in. Two strips around the trailer equals about 72+ ft. This plastic strip covers the screw heads that hold the belly band on.
Thanks
Sid
Old 10-03-2011, 05:39 AM   #40
Rick n's Avatar
Talking Campkins in Ontario has them.
Thanks
Sid
RV Dealer in Whitby Ontario - Campkin's RV Centre.
Ask for parts manager, I believe the have it in white or black.
In box me when you're installing it, there's a trick to it.
Rick.
Old 10-28-2011, 06:17 PM   #41
Hi All: I thought it was about time to update the posts on my B15 Reno. I haven't accomplished a lot in the last month or so. In Aug. my wife was diagnosed with breast cancer. I am happy to report that 3 weeks ago a lumpectomy was performed and the reports are very good. Radiation treatments are planned for the near future, but we are optimistic that the threat is past.
Now on to the Beachcomber. I am sending some pics to show that the exterior is almost completed. I have just finished most of the wiring and today picked up the R-Tech rigid insulation in Spokane (2- 1/2 hrs away). I am planning to start installing that to-morrow. I'm not sure how long the weather will last. I'll probably need a heater to work inside. The panelling inside will have to wait until spring.
Rick, I liked your idea for hiding wiring behind behind a vertical blind strip, but didn't feel it would work for me. Note on some of the pics, I fished the wires through the space left behind the framing along the belly band. Where the wires had to cross a frame member, I cut a Channel and then covered the wire with a "U" shaped piece of metal to protect them from nails etc. The original wiring lasted for 34 years even with all the wood rot problems etc. so I figured if I did a careful re-wiring job, it should last for another 20 or 30 years. That's probably longer than I will need it.
I really appreciate all the information, suggestions and ideas shared by all the members. It seems like each idea inspires one or more new ones.I am looking forward to an "egg" meet, to see and share first hand all the different approaches people take.
At the present I am trying to figure out how the top and bottom halves (at the front and back ends of the trailer) meet or overlap. I would really like to see one that is still intact or original. It would certainly help to plan that step of the rebuild. Maybe Willis in Kelowna could help in this regard.
Donna, I am trying the note pad "cut and paste" you suggested. Always something new to learn right??
Sid
Old 10-28-2011, 06:29 PM   #42
Sid
The prognosis sounds good and we'll all keep out fingers crossed!
Yep Sid, there's always something new to learn!
Thanks for the update and sharing the pictures... looks like your trailer is really coming along nicely
beachcomber
1978 beachcomber b15 cathielee Problem Solving | Owners Helping Owners 9 08-09-2017 02:01 PM
1975 Beachcomber b15 Fiberglass - $4650 (NW Calgary ) Pat B Ohio Classified Archives 0 02-28-2009 04:09 PM
1976 Beachcomber B15 camanderson10 Classified Archives 1 10-20-2007 03:03 PM
What is a Beachcomber like KLaas Focker General Chat 3 10-19-2007 09:40 AM
Beachcomber B15 Chad F Problem Solving | Owners Helping Owners 5 04-23-2007 09:38 AM
