My ambitious Boler restoration - '79 Model - Page 8 - Fiberglass RV
Old 02-02-2014, 09:39 AM   #99
Luis's Avatar
Trailer: Boler 1300 79'
One pic at a time!!!! Ughrhhhhh
Again
Luis is offline   Reply With Quote
Old 02-02-2014, 09:41 AM   #100
Luis's Avatar
And again
Anyone knows how to post multiple pics in one post with an IPad.?
Old 02-03-2014, 07:44 PM   #101
slavandheather's Avatar
Trailer: 1978 Boler
Luis, great to see you active again!
Slav
1978 Boler - work in progress...
slavandheather is offline   Reply With Quote
Old 07-02-2014, 10:34 PM   #102
Luis's Avatar
Two months lost!
We'll folks, it's me again!
I had finally booked a local trailer shop for work to install all windows, fan, seals etc. So that we could take the Boler outside and continue the build.
This contractor was also supposed to install insulation and headliner.
Long story short, the shop quoted low, so I guess they were In a Struggle to make money, and I instead of discussing it, they had excuse after excuse for not progressing work.
IMO the owner is really disorganized and it's a shame to see otherwise skillful and well intentioned folks run their Bussiness to the ground. At the end I decided to get council with the police and Best Bussiness Bureau, a Canadian institution for customer protection/ vendor satisfaction ranking, and it turned out this shop had over 13 complains in the last year and a lowest ranking of F.
So much for me waiting for two years to book the job,and not doing my homework.
When I finally decided to cut my losses (over two months, next to cero progress!), and threatened with calling the cops for what I felt was a scam, the owner pushed my trailer and all parts outside and asked me to remove the trailer from his yard! Same day.
The trailer was not vandalized not was there any stolen parts, luckily. It was exposed to a thunderstorm water downpour and it was a crazy workday afternoon to haul it back.
Good riddance!
Work is now under my control and some work has already starter to happen.
Old 07-02-2014, 10:38 PM   #103
Luis's Avatar
New door windows roughed in
Hehr sliding window for the door.
Thinking of using expansive foam inside the door panels for insulation.
Any experience out there?
Would it make the door too heavy? Thoughts...
Old 07-02-2014, 10:39 PM   #104
Luis's Avatar
Windows!
The right pic now!
Old 07-02-2014, 10:41 PM   #105
Luis's Avatar
Fan frame
Prepping for a max fan install.
Old 07-02-2014, 10:45 PM   #106
Luis's Avatar
Crazy top frame
I decided to glue some kind of anchor frame at the top, acting as railings these supports will allow me to support various components of the cabinetry to the shell.
The trick is to trace 8' long plywood pieces to the inside of the ceiling...
The answer a custom made rig, fixed to the fan opening, and fro which I can keep the horizontal and parallel references.
It sounds complicated, but I stocked built the frame in half an afternoon and am now waiting for 3M adhesives to attached the fixtures.
Old 07-06-2014, 04:56 PM   #107
Ian G.'s Avatar
Luis, sorry to hear about your experience with the shop.
Please identify the name of the shop so no one else experiences what you did.
You cannot get into trouble for mentioning facts.
Old 07-13-2014, 11:23 PM   #108
Luis's Avatar
Elements of rig used for fixing top railings ....and end result
Name:	ImageUploadedByFiberglass RV1405315380.412231.jpg
Old 07-14-2014, 05:55 AM   #109
Rick Mooyman's Avatar
Trailer: 1971 Boler 13' / 2013 Ford Escape
Manitoba
Hi Luis, sorry to hear about your trouble with the shop. Yes Like Ian mentioned do tell us all who that shop is so others can avoid the troubles you had.
By the looks of your pics your skill level looks like you should be able to do it all yourself. GREAT work by the way. I am following your progress as I love to see these trailers saved. I went through a complete restore on my 1971 Boler and still working on it.
Rick
Rick Mooyman is offline   Reply With Quote
Old 07-14-2014, 09:11 AM   #110
Luis's Avatar
Windows are ready to go in
...Tried the large side windows in with the insulation and carpeting (imagined) for fit and they look great.
the new HERH windows have a bottom opening which allow for air circulation even in rainy conditions.
Need to buy the seal to install the plexi glass front and back window now.
Anyone knows where to source this from and specs. hopefully?
Please help.
Old 07-21-2014, 01:59 PM   #111
Luis's Avatar
Ceiling supports glued in. SHOULD I FIX THEM WITH SCREWS THROUGH THE FG?
My design philosophy calls for NO PENETRATIONS to FG other than windows, door and Minimal services.
however, structurally I am concerned with overhead support anchors coming loose and affecting a lot of finished work should I need to uncover carpeting etc. to repair.
I am feeling inclined to risk water penetration and deviate from design philosophy and have one or two screwed supports on each anchor.
What design solutions have you all used in the past to screw through the FG and seal for water damage, etc....
Please help! thanks,
Luis
Old 07-21-2014, 06:34 PM   #112
GMike A's Avatar
Attaching wood to FG
I considered using these and glassing right into the ceiling or side and then put a corresponding threaded insert in the wood. wont go anywhere me thinks
STUDS - BONDABLE bigHead® THREADED - STAINLESS - Bondable Bolts for Insert Molding - EFC SCREWS, BOLTS, STUDS & PINS
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
boler
Boler Restoration hudson Modifications, Alterations and Updates 13 07-03-2012 04:43 PM
Total Boler Restoration Jenny Jones Modifications, Alterations and Updates 16 09-02-2011 07:44 PM
Boler Restoration Kevin Dunno Modifications, Alterations and Updates 2 06-21-2009 04:42 PM
1976 Boler Restoration petramarc Modifications, Alterations and Updates 7 06-04-2006 10:33 PM
Boler Restoration Expert Legacy Posts Care and Feeding of Molded Fiberglass Trailers 3 09-30-2002 10:28 AM
