My best add-on: Air conditionned in my U-haul CT-13 - Page 6 - Fiberglass RV
Old 08-22-2015, 12:15 PM   #71
Trailer: In market
Vent - caps
Thank you for your detailed posting. Where did you get your vent/plastic caps? And how did you secure it on? Have you seen any moisture build up in exhaust chamber?
Thank you in advance,
Tommy
Tommy72a is offline   Reply With Quote
Old 08-23-2015, 07:28 AM   #72
Youhauler's Avatar
Trailer: U-Haul CT-13 1985
Quebec
Tommy
Hello Tommy
I purchased them on amazon. There are "Marine Smooth Center Screw-out Deck Plate". I secured them with a plywood circular framing behind the hole in the fiberglass frame. Also use silicon in between to seal everything. Finally I installed a screen to prevent any bug infiltration. I have not seen any moisture. inside but I also made some deflectors that I install outside when it rains. Hope it helps.
Youhauler is offline   Reply With Quote
Old 08-24-2015, 10:24 PM   #73
Trailer: Scamp - The Haunted Mansion
We followed this install for our Scamp and it works great....The set up at camp is easy and it keeps the exterior clean and simple - no bulky could hanging out....
I do have another question: what did you use for the rain deflectors?
Sohkraites is offline   Reply With Quote
Old 08-25-2015, 08:44 AM   #74
Youhauler's Avatar
Quebec
Hi,
It is important to keep rain out of the access holes so I did two deflectors made of an old PVC pipe. Here are the pics of this setup. The diameter of the drain is a little bit bigger than the inside wall of the covers which is great. By removing some of the sidewall of the tube, I can bent it inside when I install it to make a good grip (spring effect). Also, I store them on the propane tank when not in use.
Old 08-25-2015, 10:43 AM   #75
Timber Wolf's Avatar
North Florida
Originally Posted by Youhauler View Post
Hi, It is important to keep rain out of the access holes so I did two deflectors made of an old PVC pipe.
Hauler, I don't know you, but I hereby bestow upon you my Father's highest praise. He would call you "a clever fellow". Believe me, this is indeed an accolade of the highest order reserved for only the most deserving. Dad is gone now, but as his representative I am authorized to act on his behalf in the matter.
Old 08-25-2015, 10:54 AM   #76
Youhauler's Avatar
Quebec
Hi Timber,
Sorry for your Father but all I can say is that I am honored by your kind words. However, I would also transfer this accolade to every member of this forum. They inspired me in every mod I did to my camper.
Old 09-02-2015, 10:36 AM   #77
Trailer: Uhaul
Very nice job! I have recently purchased an 86 CT and am wanting to also install a window A/C unit in the same spot as you did. Can you tell me if you also installed any exhaust fans? If not, have you had any problems with the unit not cooling properly? Also, can you give me a better idea of what kind of vents you installed through the shell?
Thanks!
Uhaul Mike is offline   Reply With Quote
Old 09-02-2015, 10:43 AM   #78
Youhauler's Avatar
Quebec
Thanks!
Hi Mike.
No need of any exhaust fans. The built in A/C fan is perfectly adequate for the task. The BTU size of the unit (5000) is also very good. It cools AND remove humidity which is great. One point to be careful when installing it is the drain. Make sure there is not water accumulation under the seat. The water must be dropped under the floor. The vents are "Marine Smooth Center Screw-out Deck Plate" purchased on amazon.
Old 09-02-2015, 10:46 AM   #79
Trailer: Uhaul
Sorry
Upon further reading, I see you provided a full explanation of what kind of vents you intalled and how you installed them. Ignore that question!
Do you have any more photos of your mounting plate with the drain holes?
Old 09-02-2015, 08:03 PM   #80
Youhauler's Avatar
Quebec
Here are some additionnal pics I took during installation. Hope it helps.
Old 09-02-2015, 08:43 PM   #81
Thanks for the pics of the deflectors! We will have to do that when we get back from our weekend trip.
Old 09-03-2015, 05:45 AM   #82
Trailer: Uhaul
Thank you so much for all your help! I am going to begin the A/C install today.
I have a question about the drain underneath...from your picture, it appears that you added a 90 degree adapter and a length of PVC? Where does it go? Why not allow it to drain straight down?
Old 09-03-2015, 06:09 PM   #83
Trailer: Uhaul
Dan?
I am not trying to be a pest, but can you tell me what you used to make the black "cup" that catches the runoff condensation water?
Old 09-03-2015, 06:50 PM   #84
Youhauler's Avatar
Quebec
Dan?
It is a ABS reducer with a thread on the small hole.
u-haul
Air conditioner add? Tom Myers Problem Solving | Owners Helping Owners 7 09-03-2015 04:46 PM
Air conditioer installation in Cloud/Burro/U-Haul DonDeutsch Care and Feeding of Molded Fiberglass Trailers 6 07-08-2010 07:17 AM
best technique for air flow with Maxx Air Fan with 13 footer lloyd cicetti General Chat 4 06-18-2010 05:04 PM
Add Solar Air Conditioning Bigfoot Mike General Chat 8 02-24-2007 11:09 AM
Add On Air Conditioning Idea Patrick M. General Chat 1 08-20-2006 11:38 AM
