My Boler Updating/Resto Project - Fiberglass RV
Old 04-19-2015, 11:01 PM   #1
Mr_Magoo's Avatar
Hey All,
Since I've been spending so much time working on the Boler I picked up last year I haven't had a chance to introduce myself:
Hi my name is Mike and I spend too much time working on my Boler Here's some photos of what I've done so far.
Name:   ImageUploadedByFiberglass RV1429505346.642940.jpg
Prepped for its first trip
Name:   ImageUploadedByFiberglass RV1429505447.727787.jpg
Building some custom LED lights
Name:   ImageUploadedByFiberglass RV1429505523.985404.jpg
One of the main lights mounted
Name:   ImageUploadedByFiberglass RV1429505567.316331.jpg
LED FTW!
Name:   ImageUploadedByFiberglass RV1429505637.627978.jpg
I hated the fluorescent kitchen light so I built my own LED one
Name:   ImageUploadedByFiberglass RV1429505707.804234.jpg
I also hate particle board, so I made some new pine/oak shaker doors
Name:   ImageUploadedByFiberglass RV1429505788.148585.jpg
Tear everything out!
Name:   ImageUploadedByFiberglass RV1429505840.313041.jpg
To help with the usual Boler door issues I made some custom ribs
Name:   ImageUploadedByFiberglass RV1429505902.445010.jpg
Machining up a new spacer plate for the door assembly
Name:   ImageUploadedByFiberglass RV1429505966.139180.jpg
Cutting up some PVC pipe for...
Name:   ImageUploadedByFiberglass RV1429506005.705255.jpg
Cable runs!
Mr_Magoo is offline   Reply With Quote
Old 04-19-2015, 11:08 PM   #2
Mr_Magoo's Avatar
Name:   ImageUploadedByFiberglass RV1429506144.856400.jpg
My Boler had no fusing, circuit breakers AND had aluminum wiring!
Name:   ImageUploadedByFiberglass RV1429506191.934464.jpg
Now I made custom 2ga and 6ga wiring, breakers and a heavy duty fuses
Name:   ImageUploadedByFiberglass RV1429506233.448752.jpg
My temp setup until I get my switch and info panels built. It's all marine grade equipment.
Name:   ImageUploadedByFiberglass RV1429506296.534628.jpg
Squeezed another trip in
Name:   ImageUploadedByFiberglass RV1429506345.123545.jpg
Part of my solar setup (no my motorcycle trailer isn't part of it
Name:   ImageUploadedByFiberglass RV1429506388.253605.jpg
Needed a place for coats, dog leashes and keys!
Name:   ImageUploadedByFiberglass RV1429506493.353206.jpg
Some little lights which are going in the closet and cupboards
Old 04-20-2015, 01:42 AM   #3
Borrego Dave's Avatar
Trailer: Casita SD17 2006
NICE work Mike, really like how you did PVC for wire runs. If someone gutted their trailer for resto this makes good sence for future use. Did you leave a couple pull strings in it?
Old 04-20-2015, 06:00 PM   #4
Trailer: Boler 1974 13 ft
Hi Mike, you do nice work. Could I see more pics of your LED kitchen light and a description of how you made it? Thanks, and remember copying someone's work is the highest flattery. (Hope ur chuckling)
Lisa in FL is offline   Reply With Quote
Old 04-22-2015, 08:23 AM   #5
Mr_Magoo's Avatar
Dave, I didn't bother with rope pulls since each section is fairly short. I found 1"ID pipe was the perfect size to just fit under the profile of the rear bench mounting flanges and allow lots of wires to pass through. Thanks for the compliment!
As for how the lights are made, they're constructed from aluminum U-channel and household LED strip lights. Both were sourced from a hardware store.
The kitchen light was made from the u-channel riveted to a thick aluminum sheet for the top, plexiglass for the cover and many cut pieces of the u-channel to make guides for the plexiglass. The top of the plate was covered with shiny aluminum ducting tape to reflect the light better.
Name:   ImageUploadedByFiberglass RV1429711934.793904.jpg
Name:   ImageUploadedByFiberglass RV1429711959.224336.jpg
Name:   ImageUploadedByFiberglass RV1429711980.734036.jpg
Name:   ImageUploadedByFiberglass RV1429712014.362808.jpg
The other lights were made from smaller u-channel and end potted using Araldite 2011 (you could cap it other ways too). These lights are multi-colour and I've wired a switch which allows me to select ON-OFF-REMOTE. The remote mode means I can use the fancy light patterns and the ON mode is just white. As with the kitchen light, aluminum ducting tape was used on the inside.
Name:   ImageUploadedByFiberglass RV1429712376.378989.jpg
Name:   ImageUploadedByFiberglass RV1429712409.861895.jpg
Old 04-22-2015, 11:38 AM   #6
Thanks for that great info and pictures. We all learn so much from each other.
Old 04-25-2015, 08:26 PM   #7
Keaner's Avatar
Trailer: 1973 13' Boler
Hi Mike.. what did you do to cut the ribs? Did you make a template? I need to do the same but not sure how to go about it.
Cheers
Keaner is offline   Reply With Quote
Old 04-25-2015, 11:13 PM   #8
Mr_Magoo's Avatar
Hey there. Yup, I made a template. Here's some pics:
Name:   ImageUploadedByFiberglass RV1430024851.443255.jpg
Used a piece of scrap drywall to make the template
Name:   ImageUploadedByFiberglass RV1430024893.590430.jpg
Shaped it
Name:   ImageUploadedByFiberglass RV1430024930.471198.jpg
Then used it to make two pieces
Name:   ImageUploadedByFiberglass RV1430024985.361603.jpg
A few nails and a bent rod gave me a nice curve for the inside
Name:   ImageUploadedByFiberglass RV1430025031.346114.jpg
A lot of sanding and finagling later, voila!
I will echo what others have said before, check your door for trapped water and that the lower rail under your floor that connects the frame to the outside panel is okay.
boler
new boler owner resto Siris Modifications, Alterations and Updates 72 08-18-2014 05:23 PM
73 Boler interior resto Burke R. Modifications, Alterations and Updates 41 03-24-2014 08:54 AM
AB | old boler resto project for sale $1000 Siris Classified Archives 3 08-16-2012 04:48 PM
Shower in 1974 Boler Resto David Konduc Modifications, Alterations and Updates 8 02-04-2012 02:15 PM
Our 75 Boler resto also Debbie H Modifications, Alterations and Updates 5 03-24-2008 01:41 PM
