05-26-2020, 03:48 PM
#61
Trailer: Trillium 4500
Metal plates
Hi Dave. I know this is an old thread, but I am working may way through your awesome posts. I started to grind my belly band today. It's an unpleasant job on a miserably hot day. This is likely a naive newby question, but have you ever known anyone to grind down the wavey imperfections and leave the plates in that don't cause bumps- then just glass over that? I am wondering if, over time the plates would cause more issues with rusting? My thought is that they shouldn't because it will be sealed up. I'm still planning on doing it as you suggest, but am curious. Thanks very much!
05-26-2020, 04:17 PM
#62
Where is David? I've noticed he hasn't been around for quite some time. Definitely one of the all time Trillium experts.
Previously Owned: Trillium 4500, Scamp 19', Bigfoot 17', Boler 17', Bonair Oxygen, Hymer Touring GT, Scamp 13 Deluxe, Casita 16.
05-27-2020, 02:30 PM
#63
Trailer: Casita 16', Sunrader 18'
I am looking for 1" rubber molding with 3m tape on back side as a cosmetic molding for my bellyband replacement on my Sunrader. I have found 1" flat molding but would be happier with L shape molding since there is a small 1/16" lip where top half of the camper over hangs bottom half. The largest L molding I have found was 3/8" wide, would perfer 1" wide. Anyone ever use a rubber molding like this.
05-27-2020, 04:04 PM
#64
Try looking at a Lil Snoozy or the new Snoozy 2 belly band trim piece. If it looks like it could work for you, you could order from them.
Good Luck
Dave & Paula
05-27-2020, 07:34 PM
#65
Trailer: 2013 Escape 19
Head to ebay on body side moldings. There are endless supply of them.
As to the question of going to the trouble of grinding and repairing the belly band area, but leaving the steel plates in place, I just ask why? Once you have done the tough work of grinding the band down, leaving the plates behind is living with fire in my book. Any pinhole penetration, water gets in, plates rot, they expand, and you have a nasty hump on the outside of your trailer. I don't see the benefit of taking the chance, even if it is small. Once you grind the band, the plates are right there. It really won't save that much time.
05-28-2020, 05:33 AM
#66
Good Luck
Dave & Paula
Thank You Dave, I did look into Snoozy #1. It required a backer strip. I believe it was sold at H/D and lowes. In the patio screen department. I'll look at it again. Thanks
05-28-2020, 11:33 AM
#67
Trailer: 1978 Boler
Almonte, Ontario
Caution: this does not have relevance for land locked readers!!! But I purchased a super decorative rubber moulding for my Boler belly band cover-up from a local marine supply store in Ottawa. Looks great and works really well where the door swings back as a bumper. It fits tight and has gripper teeth. The ends are held in place by stainless pins (SS nails).
05-28-2020, 06:40 PM
#68
Thanks , can you post a picture or link. for a better idea of what you purchased. I live near the water and have access to marine stores.
05-29-2020, 12:00 PM
#69
Trailer: 1978 Boler
Almonte, Ontario
Curse Covid-19. My Boler is out at our daughter’s property at the moment. Somewhere in my garage I should have a piece of the moulding (the key here is “somewhere”) However, I was able to call our marine store and ask. The moulding is a Trim-Lok edge trim that is available in various openings (we suspect that what I have is the .135 to .250 gap) in white with pebble texture.
Here is the link to the Trim-Lok page:
https://www.trimlok.com/plastic-extr...tom/size-range
Photos to follow when next I’m out to the property.
05-29-2020, 02:17 PM
#70
I am very familiar with this product and the company. All my interiorwindows are surrounded with this vinyl. Thanks I'll look into it.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Polishing That Belly Band
steve J |
22 |
10-13-2014 07:03 AM |
Trillium Belly Band
Randy Bishop |
9 |
05-16-2013 05:00 PM |
Help: Trillium Belly Band
msinger919 |
11 |
11-13-2012 09:35 PM |
Belly Band
Ruth C. |
2 |
06-19-2011 07:17 PM |
Belly Band Trillium
Johny Bg |
3 |
05-11-2010 11:45 AM |
