My most recent addition. - Fiberglass RV
Old 05-26-2007, 08:01 PM   #1
Trailer: Fiber Stream
Talking
Winegard HA-130 RV TV antenna
This was designed to mount on the flat side wall of a square RV. To mount it to my round egg, I bought a 6' x 1" x 1/8" aluminum bar, bent it into an inverted "L", and mounted the antenna to it. Then I mounted the whole assembly to the trailer, using pre-existing thru-hull screws; 2 on the side where the divider wall is between the kitchen and front room, and one on the Fan-Tastic Fan's mounting flange.
Closed for Travel
Open for Use
I'm here in Palm Springs for the Memorial Day weekend, and it is working well for the broadcast signals here.
Old 05-26-2007, 09:29 PM   #2
Frederick,
Looks pretty good! Even if the bracket might "whistle" while you are underway, you'll never hear it in your tug.
Please let us know how it works with weaker signals, in an area with poorer reception. Have you used a different antenna? It would be nice to get your comparisons.
Thanks for the pictures of the installation,
Kurt, & Ann K.
Old 05-28-2007, 07:22 PM   #3
Talking
It does work better than a set of "Rabbit Ears" that came with my TV set.
I have discovered that it is "Directional", contrary to the claims of the packaging. I can turn it within the tube mounting to find the "sweet spot". Since I found the Palm Springs outlet for PBS, I was a happy camper for the weekend, and did not experiment with several weaker signals. All of the local network broadcast channels came in clear!
I chose this because it looked to be simpler and easier than a crank-up "Batwing" antenna.
Top bunk addition Nick Z Problem Solving | Owners Helping Owners 10 06-12-2008 09:35 PM
Our New Addition Tony and Karolyn General Chat 11 05-22-2007 11:10 AM
Newest addition to the family! Legacy Posts General Chat 9 06-01-2003 09:20 PM
Top bunk addition Nick Z Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
