UPS delivered my 90 watt portable
solar system today, and I am just thrilled with it. The two hinged 45 watt panels came in a very nice padded aluminum case.
It is plug and play. The PMW charge controller is already connected to the back of the panels.
All I had to do was connect the little ring fittings to the
battery posts, run the little plug out the vents in the
battery box, plug in the
solar panel... and it was good to go!
I didn't use the folding legs that are attached to the back of the panels because at my latitude an 11 degree tilt is optimum this time of year. So I just put a couple of boards under it to slightly slant it.
At 5:30 this evening, it was charging my
battery at 13.80 volts. At 6:00 clouds had moved in and the sky was overcast, and I was still getting a 13.33 reading.
After agonizing for months about how to mount and install a permanent
solar system, this was the perfect solution for me.
I got it from
CEA Solar. The people there are wonderful to deal with, and will be happy to answer all the questions you can come up with!
