My Scamp AC install - Fiberglass RV
Old 05-17-2014, 08:16 PM   #1
Name: Kevin & Lisa
Trailer: Scamp16
Ohio
My Scamp AC install
Today was the day.... And a long one at that, but hey 3 different hardware stores in one day ain't bad.
Closet- fiberglass patch of old AC hole
Name:	ImageUploadedByFiberglass RV1400379066.043345.jpg
New hole
Name:	ImageUploadedByFiberglass RV1400379121.836985.jpg
New vent 12x12
Name:	ImageUploadedByFiberglass RV1400379159.801051.jpg
Risers to hold drip pan and allow more circulation
Name:	ImageUploadedByFiberglass RV1400379237.133967.jpg
Drip pan - came across a never used sink drain in the good ole garage bin of "ill use this one day" parts
Name:	ImageUploadedByFiberglass RV1400379358.082784.jpg
Name:	ImageUploadedByFiberglass RV1400379383.614746.jpg
summer scamp is offline   Reply With Quote
Old 05-17-2014, 08:23 PM   #2
Name: Kevin & Lisa
Trailer: Scamp16
Ohio
Installed two cleats to run a ratchet strap that will hold down AC unit.
Name:	ImageUploadedByFiberglass RV1400379465.796616.jpg
Name:	ImageUploadedByFiberglass RV1400379595.261021.jpg
Pan installed- shur-taped it down after pic
Name:	ImageUploadedByFiberglass RV1400379639.120984.jpg
Need another hole
Name:	ImageUploadedByFiberglass RV1400379682.780957.jpg
Name:	ImageUploadedByFiberglass RV1400379709.786818.jpg
Cowling made to fit
Name:	ImageUploadedByFiberglass RV1400379768.765883.jpg
Fits like a glove and strap holds it down great ... Hopefully it lasts.
Name:	ImageUploadedByFiberglass RV1400379826.968591.jpg
Old 05-17-2014, 08:27 PM   #3
Name: Kevin & Lisa
Trailer: Scamp16
Ohio
Ran out of shur-tape .... And energy...
Still need to button it up, install the supports for the shelf above the unit, make a face frame to seal up around front of unit, and install vent on outside
Name:	ImageUploadedByFiberglass RV1400380027.163694.jpg
Name:	ImageUploadedByFiberglass RV1400380061.885835.jpg
Old 05-18-2014, 03:54 PM   #4
Name: Kevin & Lisa
Trailer: Scamp16
Ohio
Finished duct work
Name:	ImageUploadedByFiberglass RV1400449831.475817.jpg
Shelf supports with an extra one attached to wall to keep back of shelf up
Name:	ImageUploadedByFiberglass RV1400449880.580030.jpg
Bottom shelf in place
Name:	ImageUploadedByFiberglass RV1400450021.161428.jpg
Time for a face frame
Old 05-18-2014, 04:39 PM   #5
Name: Kevin & Lisa
Trailer: Scamp16
Ohio
Forgot about the vent cover.
Name:	ImageUploadedByFiberglass RV1400452789.721470.jpg
Old 05-18-2014, 05:17 PM   #6
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Nice job Kevin, I like to know there are other folks that hold on to things that come in handy later. Still trying to convince my wife I'm not a horder. Just a thought for you, maybe put some 1/4" x 1/4" screen over the end of the drain tube to keep small pests out.
Borrego Dave is online now   Reply With Quote
Old 05-18-2014, 06:00 PM   #7
Name: Kevin & Lisa
Trailer: Scamp16
Ohio
Done... I found an old piece of screen laying around 😁
.... Not a hoarder ..... A keeper 😉
Old 05-18-2014, 07:37 PM   #8
Name: Kevin & Lisa
Trailer: Scamp16
Ohio
Face frame in same granite color as all cabinet doors..... The PO left me the gigantic hole to fit his storage bins.
Name:	ImageUploadedByFiberglass RV1400463417.398545.jpg
Old 05-18-2014, 09:01 PM   #9
Name: Kevin & Lisa
Trailer: Scamp16
Ohio
Befores and afters
Name:	ImageUploadedByFiberglass RV1400468454.433124.jpg
Old 05-18-2014, 10:10 PM   #10
Night Sailor's Avatar
Connecticut
Beautiful work. I wish I could do this on my camper. I suppose I could of I sacrificed a window.
And Dave, do you want a Motorhome to add to your hoard ? There is one at my uncles place in Las Vegas you could probably have for nothing.
Old 05-18-2014, 11:29 PM   #11
Good one Conrad and thanks for the thought. But I'm trying to cull the herd. Everyone collects something and much to my wifes ideas of collecting , mine seem to all have wheels . Now if they were all Corvettes she would be like this
Old 05-22-2014, 08:42 AM   #12
Trailer: U-Haul 13 ft ('Lil Eggo')
How well does this cool...
I had the understanding that you could not enclose the vents on the sides of the AC or it would basically exhaust hot air back into the cooled space...thinking of doing this in my uhaul if it works... thanks!
Sharon W is offline   Reply With Quote
Old 05-22-2014, 09:16 AM   #13
Name: Kevin & Lisa
Trailer: Scamp16
Ohio
All three parts of AC ( when installed like this and not hanging out a window) need to be separated. The vents on the sides of unit vent out the bottom of scamp and is separated from the in room intake and cold air blower on the front of the unit or yes, you are correct, the air would mix and reduce efficiency.
Old 05-22-2014, 09:19 AM   #14
Name: Kevin & Lisa
Trailer: Scamp16
Ohio
Name:	ImageUploadedByFiberglass RV1400771889.801009.jpg
Hopefully there is enough airflow with out adding a couple 12v fans.. I guess I'll find out soon enough
Shademaker 8 foot Awning Install 13 Scamp Greg A Modifications, Alterations and Updates 29 04-23-2016 04:15 PM
Yet another Scamp window A/C closet install. Allen Howell Modifications, Alterations and Updates 6 08-23-2014 05:39 PM
My Scamp AC Install - A tweak on Parker Buckley's design Nor_Cal_Todd Modifications, Alterations and Updates 0 09-02-2010 09:37 PM
Scamp AC install Gary Little General Chat 2 06-01-2006 08:58 AM
My 13' Scamp A/C in closet install Bob H Modifications, Alterations and Updates 9 03-29-2006 06:18 PM
