My Scamp Bunk/Dinette Mod - Page 2 - Fiberglass RV
Old 03-10-2010, 09:38 AM   #15
Trailer: Fiber Stream
Unhappy
We have a 2008 Scamp 16.
Has anyone modified the main bed to enlarge it?
[b]We have floor plan 4.
I do not remember anyone specifically modifying a 16' plan 4. The problem is cutting the fiberglass cabinetry.
However, several have modified 13' trailers by building a platform that fills in the floor space between the kitchen cabinets so they could rotate 90<sup>o</sup> and sleep with their feet in the aisle over this platform. They avoided cutting the cabinet that way.
Old 03-10-2010, 10:45 AM   #16
Raya's Avatar
I can't call a particular thread at the moment, but I have seen a few people modify the back of a 13' Boler/clone (in which that area is essentially the same as your Layout 4).
What was done was to shrink the kitchen and closet by about 6" so that the bed would be ~54" wide instead of ~48" wide. You'd want to recreate the structural support that is now provided by the back end of the kitchen and closet, but moving that forward 6" would not be a problem, in my opinion.
The Scamp Deluxes (wood cabinetry) often have this layout (shorter kitchen, narrower closet, and wider bed).
Raya
Old 03-10-2010, 11:28 AM   #17
US
It's being talked about on yahoo scampers, that must have been where I read about the mod. They said it was a lot of trouble to get the extra 6 or 7 inches of sleeping shoulder space. I can imagine so.
Old 06-29-2010, 12:28 AM   #18
Trailer: 1985 Scamp 13 and 1985 Scamp 16
Nebraska
Attachment 26714
I would be interested learning more about this platform over the floor and sleeping with our feet in the aisle.
Does anyone have a photo or a link to where it's been discussed here.
Thanks,
Julie
Julie T. is offline   Reply With Quote
Old 06-29-2010, 08:49 AM   #19
Trailer: 13 ft Scamp
Hi Julie,
We put a removable platform in the aisle of our 13' so we could sleep with our heads under the window. Did a quick and ugly modification of it to transfer it to our 16'. I can take some photos if you'd like, but because it will not fit the 16' like it did the 13', it's doesn't self-store any more. I will be making an new version.
Darnelle is offline   Reply With Quote
Old 06-29-2010, 09:28 AM   #20
Talking
Thanks,
Julie
Myron Leski's Burro Modification
Old 06-29-2010, 11:44 PM   #21
Nebraska
Thanks Darnelle, I would love to see some pictures.
Julie
Old 06-29-2010, 11:46 PM   #22
Nebraska
Frederick, thanks for the link. I really enjoyed reading that thread. It's been a few years now...I wonder how Myron has liked his new set up.
Julie
Old 07-20-2010, 08:07 PM   #23
Thanks Ken.
The fiberglass was amazingly hard to cut. I should have used a Rotozip and almost bought one for the job. Instead I used elbow grease and punished a few reciprocal saw blades. I taped the lines before cutting which prevented splintering but still had a little blade wandering. I tried a laminate type blade on a skill saw but the dust was prohibitive, even with a mask. (and without a twin strap respirator). One of the cut lines is from the previous door side which is probably straighter than mine.
The fiberglass was thick and thin and honestly up to 1/4" thick in some places and then reinforced by hardwood 1x2, also wrapped in glass. the 2x2 panel that came out is really heavy.
Part of the fun for me, of doing a camper mod, is saving money. Come to think of it saving money anytime is fun
I cut out a cabinet door with a Rotozip and burned through 3 blades.....the expensive ones. So, you did just fine with what you had. Fiberglass is rough to cut.
PVFunches is offline   Reply With Quote
Old 08-16-2010, 07:07 AM   #24
Trailer: 1980 16 ft Scamp (Restored)
Originally Posted by Michael D View Post
This is my 99 Scamp 16 bunk mod. We cut up the bunk to make a front dinette that can also be a spare bunk when needed. We were motivated by pure laziness, not wanting to remake the bed to a table each day.
The footwell size was limited by the Scamp floor design. On either side of the well the floor is raised and steel framed 10" high. Leg room is small but works ok as long as the table support is against the back side of the well. We had to cut the table side and place it off center a bit because the FTOC closet is restrictive.
We are living in temporary quarters so instead of removing the whole bench and building new, we used the few hand tools we have with us to cut up and modify the existing.
Thanks to everyone for all your postings which were mucho helpful.
It works well and best of all cost under $50.
Hi Michael:
I'm interested in your modification (for the same reasons you had!). I have a 1980 refurbished 16'er. I have some questions I hope you won't mind answering.
Was there a reason you didn't make the leg well deeper?
How wide is the leg well?
Is the table permanently mounted? If not, how do you lower it for bed?
I included a photo of our front and rear area. We removed the bunk bed configuration, just use it as a couch. The (front) working area seem to be the same size as yours.
Thanks for your feedback (and your great idea)!
Lawrence
Lawrence W is offline   Reply With Quote
Old 02-29-2012, 03:58 PM   #25
When cutting the fiberglass the Roto type saw does a great effortless job. Does create some dust tho. You will find it not necessary to tape the cut as the saw dosen't splinter the edges.
Ron
RRJR is offline   Reply With Quote
Old 02-29-2012, 05:08 PM   #26
aumpleby's Avatar
Trailer: '74 Boler
I've been thinking of doing this with my new Boler as one of the projects. I was wondering how easy it would be to cut the fibreglass, and this has answered my questions! One more thing to add to the list.
Thanks for sharing!
aumpleby is offline   Reply With Quote
Old 03-01-2012, 02:00 PM   #27
Name: Dave and Shelly
Trailer: 2001 Spirit Deluxe Casita "New Name: Eggspensive"
Iowa
Good idea and nice job on the work.
sfoss is offline   Reply With Quote
Old 10-27-2012, 09:02 PM   #28
GaryG's Avatar
Trailer: 89 13' Scamp
Bunk dinette
Curious as to what material was used to cover the footwell. Looks like fiberglass panels? Where can I get some please. I want to do this mod to my 13' Scamp.
Thanks, Gary
GaryG is offline   Reply With Quote
Scamp Bunk Beds Into Dinette? Melissa Miller Care and Feeding of Molded Fiberglass Trailers 19 06-09-2010 12:26 PM
Bunk over Rear Dinette jenniferm Problem Solving | Owners Helping Owners 1 07-28-2008 05:01 PM
Scamp dinette/bunk cushions fit Perris Pacer perfectly Angelo F. Modifications, Alterations and Updates 8 06-13-2008 08:35 PM
Bunk bed over rear dinette Steph taylor Modifications, Alterations and Updates 15 08-16-2006 08:28 PM
Trillium bunk over main dinette? Legacy Posts Problem Solving | Owners Helping Owners 2 06-11-2003 06:37 PM
